Hello people!
I design a UI for a small touchscreen with HABpanel and I have found myself a few times accidentally selecting the text of buttons/labels click “click&drag” with my finger…
Is there a way to stop that really ugly outcome?
Thanks kubawolanin,
is that on a widget-level that needs to be applied in each widget or panel-level applied only once? Any rough directions where I can add this (Im CSS-literate) ?
Will submit an issue together with the workaround once I test it works.
Thank you everyone! kubawolanin, could you please check the PR guide link and fix it. I would like to start contributing but GitHub seems intimidating without some guidance.
