Accidentally uninstalled a critical bundle! help
Hi All
i typed bundle:uninstall 21 instead of 212
Its removed a stack fo core things. Can I reinstall these without too much drama? openhab2 is running…
6:14:36.044 [ERROR] [org.openhab.binding.bom              ] - FrameworkEvent ERROR - org.openhab.binding.bom
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.bom [257]
  Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:="optional"
  Unresolved requirement: Import-Package: org.eclipse.smarthome.core.thing
    -> Export-Package: org.eclipse.smarthome.core.thing; bundle-symbolic-name="org.eclipse.smarthome.core.thing"; bundle-version="0.10.0.oh240"; version="0.0.0"
       org.eclipse.smarthome.core.thing [109]
         Unresolved requirement: Import-Package: org.eclipse.smarthome.config.core
           -> Export-Package: org.eclipse.smarthome.config.core; bundle-symbolic-name="org.eclipse.smarthome.config.core"; bundle-version="0.10.0.oh240"; version="0.0.0"
              org.eclipse.smarthome.config.core [97]
                Unresolved requirement: Import-Package: com.google.gson
  Unresolved requirement: Import-Package: org.eclipse.smarthome.config.discovery
    -> Export-Package: org.eclipse.smarthome.config.discovery; bundle-symbolic-name="org.eclipse.smarthome.config.discovery"; bundle-version="0.10.0.oh240"; version="0.0.0"
openhab> bundle:install 198
Bundle IDs:
Error executing command: Error installing bundles:
        Unable to install bundle 198: org.osgi.framework.BundleException: Error reading bundle content.
openhab>
Easiest option might be to backup your config and reinstall.
Indeed, if you dont purge your install it keeps all the settings, more or less.
could also try just installing over the top. It might fix the core dependency.
Yeah all sorted, i think best to remove then reinstall. just remember DO NOT PURGE!
For future reference… Removing the contents of tmp and cache usually does the trick for me.
