Hi all, I am currently writing rules to control a LED RGB strip. The device is controlled via MQTT and expects RGB values. The current value is reported back via MQTT. So I have a String item that sends and receives the raw RGB data to/from the device and a proxy Color item to control the device. The proxy item has autoupdate="false" set, so it always reflects the current color set by the device. Conversion between both is done via rules. This all works quite well.
However, when I wrote a rule to cycle through colors by incrementing the hue of the proxy Color item (modulo 360), I noticed that the brightness will change with each step until it reaches zero (aka lights off). I figured that there seems to be a problem regarding the accuracy of the HSB to RGB conversion. The following test code:
val red = 134
val green = 255
val blue = 4
val color = HSBType.fromRGB(red, green, blue)
val redAfter = color.red.intValue * 255 / 100
val greenAfter = color.green.intValue * 255 / 100
val blueAfter = color.blue.intValue * 255 / 100
logInfo("RGB", "in: {},{},{}", red, green, blue)
logInfo("RGB", "out: {},{},{}", redAfter, greenAfter, blueAfter)
gives the following result:
21:48:44.914 [INFO ] [rg.eclipse.smarthome.model.script.RGB] - in: 134,255,4
21:48:44.970 [INFO ] [rg.eclipse.smarthome.model.script.RGB] - out: 137,255,5
Note the difference in the red and blue values. The error accumulates with every step and leads to the behaviour described above.
Am I making some sort of stupid mistake or is this due to accuracy that HSBType uses internally?
If it is indeed due to the internals of HSBType, is there an alternative solution to achieve accurate conversion?
Thank you!
PS: I am on openHAB 2.3
