- Platform information:
- Hardware: x86_64/
- OS: Fedora Core 27
- Java Runtime Environment: openjdk 1.8.0
- openHAB version: 2.1
- Issue of the topic:
I want to debug some issues I’m having with the lutron binding (keypad not working), and have installed the development environment through the Eclipse Installer.
It seems to install ok, and I can run the demo system. However, I can’t work out how to get it to load the lutron addon. The Add-Ons tab in the PaperUI lists around 10 bindings with cryptic 5 letter names (seemingly random letters).
Adding an explicit Thing for lutron:ipbridge:radiora2 as shown in the docs has no effect. The binding is silently ignored.
I do see one m2e build error in the IDE, which I’m assuming is the problem:
“Plugin execution not covered by lifecycle configuration: org.commonjava.maven.plugins:directory-maven-plugin:0.2:highest-basedir (execution: directories, phase: initialize)”
I tried a full re-install just in case something went wrong there, with identical results.
Is the m2e error related to the missing add-ons ? If so, what is the correct way to fix it ?
If the m2e error isn’t really an issue, how can I update the config to pull in the lutron binding ?
Jon
