Activating TLS on your mosquitto (and Owntracks)
All,
This tutorial’s intention is to make life easier for those, who would like to enable TLS on their mosquitto.
I struggled a lot and gave up many times until I finally merged information from various sites to the one which works for me.
(That’s no guarantee that it works for your specific setup though :wink:
In general it’s required to generate some certificate files on the host running mosquitto (actually all the activities below have been done on my raspberry 2 running openHABian and OH2.
It might be trivial for most of the people here, but I am sure that there must be some out there who had similar problems than I had.
So you need:
  1. Mosquitto running (it ran for quite a while on port 1883 without TLS).
  2. Generate server certificates (e.g. ca.crt see below)
  3. Copy the files to the mosquitto subdir (see below as well)
  4. Activate TLS on mosquitto
  5. Encrypt and transfer the files …otrp and ca.crt to the phone
  6. Activate TLS in owntracks (activate iPhone.otrp with passphrase)
Actually most of the documentation is a patchwork from multiple sites, like
and
http://rockingdlabs.dunmire.org/exercises-experiments/ssl-client-certs-to-secure-mqtt
(By the way, thanks to the creators of the sources mentioned above!)
So let‘s start with rockingdlabs first (I did not put all steps here so please check the site as well).:
Before step 2 (Setup a CA and generate the server certificates):
Modify Generate-CA.sh:
IPLIST=“192.168.178.50 127.0.0.1”
HOSTLIST="localhost yourhostname something.from-outside.org "
(I am not really sure if this is required, but keeping the problems in mind I had, it’s pretty likely: Those were that I haven’t been able to connect from outside my LAN.
Maybe some expert can confirm or refute this)
Anyway…
Use generate-CA.sh for certificate generation after change above
You will get:
ca.crt, ca.key, ca.srl, myhost.crt, myhost.csr, myhost.key
(ca.crt will be needed on your phone later and the .key needs to be kept in a secret place).
Copy the files:
sudo cp ca.crt /etc/mosquitto/ca_certificates/
sudo cp myhost.crt myhost.key /etc/mosquitto/certs/
Adjust mosquito conf accordingly:
cafile /etc/mosquitto/ca_certificates/ca.crt
certfile /etc/mosquitto/certs/myhost.crt
keyfile /etc/mosquitto/certs/myhost.key
Connection without TLS is already ok:
sudo mosquitto_sub -d -h something.from-outside.org -p 1883 -t ‘owntracks/#’ -d
(please make sure to open 1883 on your router)
Generate client certificates (see also Step 4 on the website mentioned above):
sudo openssl genrsa -out iPhone.key 2048
sudo openssl req -new -out iPhone.csr -key iPhone.key -subj “/CN=iPhone/O=example.com”
sudo openssl x509 -req -in iPhone.csr -CA ca.crt -CAkey ca.key -CAserial ./ca.srl -out iPhone.crt -days 3650 -addtrust clientAuth
This will create the following files:
iPhone.crt, iPhone.csr, iPhone.key
Connection is ok (localhost):
sudo mosquitto_sub -d -h localhost -p 8883 --tls-version tlsv1 --cafile /etc/mosquitto/ca_certificates/ca.crt --cert iPhone.crt --key iPhone.key -t ‘owntracks/#’ –d
as well as from outside:
sudo mosquitto_sub -d -h something.from-outside.org -p 8883 --tls-version tlsv1 --cafile /etc/mosquitto/ca_certificates/cart --cert iPhone.crt --key iPhone.key -t ‘owntracks/#’ –d
To transport the phone related certificate files safely:
openssl pkcs12
-export
-in iPhone.crt
-inkey iPhone.key
-name “NCO’s certificate/key”
-out iPhone.otrp
This will ask for a passphrase you need to put into your phone later (TLS Settings → Client certificate → passphrase)
Transfer the ca.crt and iPhone.otrp to your phone.
The otrp file can be imported into owntracks directly.
The ca.crt needs to be installed as a certificate on the phone as well.
That should be it to be able to connect with TLS to your mosquitto broker.
Hope it helps.
For those who would like to check out Let’s encrypt as alternative certificates please check out a short hint from @rlkoshak:
Just to add a bit of security, I suggest to see Tlscert - OwnTracks Booklet
  1. add the “two-factor authentication”
adding in the mosquitto.conf:
require_certificate true
use_identity_as_username true
you already have your client certs, so no too much extra effort
  1. activate the pinning certificate
  • enabling Use Custom Security Policy - “certificate” option
  • adding a .otre certificate as follow:
openssl x509 -in ca.crt -out ca.otre -outform DER
Hope this helps
Andrea
I posted a related tutorial on how to configure Openhab to connect to an MQTT broker with ssl/tls:
Another point to be added:
  • consider MQTT binding is not supporting the same TLS connection. So idea is to stay with TLS+pinning certificate on your mobile, and use clear connection between mosquitto and openHAB (usually on the same network/device).
  • for doing that, mosquitto needs to be configured with port 1883 and listener 8883
HTH
Andrea
I agree, the mqtt broker will normally be on the same network/device but in my case I needed a cloud mqtt broker because my mobile/cellular provider doesn’t give access to some/most IP ports. I therefore had to use cloudMQTT which works great but I didn’t want to send my location (I am using owntracks) un-encrypted from cloudMQTT to my broker, therefore I had to configure openHAB to accept a tls connection with the mqtt binding.
Vincent,
What about change the port of your mosquitto, or better map a different external port with 8883 internal? Do you have access to your router?
In case let me know if I can help. If you have access, let me know router model.
Andrea
Sorry, but I need to dig this out again…
I had the OwnTracks setup with Mosquitto and openHAB running for ages now, but since changing my phone last week I can’t get it up again.
I created new certificates but somehow it doesn’t work.
What I did so far:
  1. generated certificates by using the generate-CA script from OwnTracks. I used the format ./generate_sh mydomain.no-ip.info
  2. then I generated the client certificates with the client option of the generate_sh script
  3. copied the ca.crt and the mydomain.crt and .key into /mosquitto/ca_certificates and /mosquitto/certs respectively
  4. changed the permissions of these files to 744 and restarted mosquitto
  5. generated a pcks12 file with the client certs as described in the first post
  6. copied the ca.cert and the iPhone.otrp to the phone and installed both
No success.
The mosquitto log shows this error:
OpenSSL Error[0]: error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown
Client <unknown> disconnected: Protocol error.
I know this is not an openHAB issue, but hoped someone here could help me.
Many thanks
Matthias
Have a look at http://www.steves-internet-guide.com/mosquitto-tls/ there are a few hints for this error message.
