Does anyone have any experience with the configuration parameters of this device, or have any ideas on my issue? I was trying to adjust the configuration temperature and the swing setting, but those settings don’t seem work. For example, if I provide a calibration value, it appears to save, but the temperature on the unit does not change. The swing setting also seems to update correctly, but it operates as if still on its default value. Here is a debug log after updating parameter 7 (Swing) to 15, with the intention of setting the swing to 1.5 degrees:
2020-03-05 15:09:27.258 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Configuration update received
2020-03-05 15:09:27.269 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Configuration update set config_7_4 to 15 (BigDecimal)
2020-03-05 15:09:27.272 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 82: Creating new message for application command CONFIGURATION_SET
2020-03-05 15:09:27.275 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY not supported
2020-03-05 15:09:27.278 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2020-03-05 15:09:27.280 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2020-03-05 15:09:27.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 6026 to queue - size 29
2020-03-05 15:09:27.286 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-05 15:09:27.292 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0F 00 13 52 08 70 04 07 04 00 00 00 0F 25 85 61
2020-03-05 15:09:27.296 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 0F 00 13 52 08 70 04 07 04 00 00 00 0F 25 85 61
2020-03-05 15:09:27.299 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-03-05 15:09:27.302 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-03-05 15:09:27.302 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 6026: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 133
2020-03-05 15:09:27.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-05 15:09:27.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-05 15:09:27.308 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 82: Creating new message for application command CONFIGURATIONCMD_GET
2020-03-05 15:09:27.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 6026: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 133
2020-03-05 15:09:27.310 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-03-05 15:09:27.312 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-03-05 15:09:27.312 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY not supported
2020-03-05 15:09:27.314 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.314 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-05 15:09:27.315 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-05 15:09:27.316 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2020-03-05 15:09:27.318 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-05 15:09:27.319 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 6026: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 133
2020-03-05 15:09:27.319 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Adding to device queue
2020-03-05 15:09:27.322 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Added 6027 to queue - size 29
2020-03-05 15:09:27.325 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-05 15:09:27.328 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-05 15:09:27.330 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 6026: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 133
2020-03-05 15:09:27.332 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-05 15:09:27.335 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2020-03-05 15:09:27.337 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 6026: Advanced to WAIT_REQUEST
2020-03-05 15:09:27.340 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 6026: Transaction not completed
2020-03-05 15:09:27.342 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.344 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-05 15:09:27.355 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 85 00 00 05 6B
2020-03-05 15:09:27.359 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=133, payload=85 00 00 05
2020-03-05 15:09:27.364 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=133, payload=85 00 00 05
2020-03-05 15:09:27.369 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 6026: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 133
2020-03-05 15:09:27.375 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-05 15:09:27.377 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 6026: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 133
2020-03-05 15:09:27.379 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 6026: (Callback 133)
2020-03-05 15:09:27.381 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-03-05 15:09:27.383 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 6026: callback 133
2020-03-05 15:09:27.385 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=133, payload=85 00 00 05
2020-03-05 15:09:27.387 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 133, Status = Transmission complete and ACK received(0)
2020-03-05 15:09:27.389 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2020-03-05 15:09:27.391 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 6026: Transaction COMPLETED
2020-03-05 15:09:27.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Response processed after 90ms
2020-03-05 15:09:27.394 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 6026: Transaction completed
2020-03-05 15:09:27.396 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:6026 DONE
2020-03-05 15:09:27.399 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-03-05 15:09:27.401 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.402 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-05 15:09:27.406 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 52 03 70 05 07 25 86 66
2020-03-05 15:09:27.409 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 82: Sending REQUEST Message = 01 0A 00 13 52 03 70 05 07 25 86 66
2020-03-05 15:09:27.411 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-03-05 15:09:27.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 6027: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 134
2020-03-05 15:09:27.412 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-03-05 15:09:27.414 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-05 15:09:27.416 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-05 15:09:27.417 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 6027: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 134
2020-03-05 15:09:27.419 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-03-05 15:09:27.419 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-03-05 15:09:27.420 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.422 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-05 15:09:27.422 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-05 15:09:27.424 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-05 15:09:27.425 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 6027: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 134
2020-03-05 15:09:27.427 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-05 15:09:27.428 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 6027: [WAIT_RESPONSE] priority=Config, requiresResponse=true, callback: 134
2020-03-05 15:09:27.430 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-05 15:09:27.432 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: sentData successfully placed on stack.
2020-03-05 15:09:27.433 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 6027: Advanced to WAIT_REQUEST
2020-03-05 15:09:27.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 6027: Transaction not completed
2020-03-05 15:09:27.436 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.438 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-05 15:09:27.462 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 86 00 00 04 69
2020-03-05 15:09:27.465 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=134, payload=86 00 00 04
2020-03-05 15:09:27.467 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=134, payload=86 00 00 04
2020-03-05 15:09:27.468 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 6027: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 134
2020-03-05 15:09:27.476 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-05 15:09:27.477 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 6027: [WAIT_REQUEST] priority=Config, requiresResponse=true, callback: 134
2020-03-05 15:09:27.479 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 6027: (Callback 134)
2020-03-05 15:09:27.483 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-03-05 15:09:27.485 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 6027: callback 134
2020-03-05 15:09:27.487 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=134, payload=86 00 00 04
2020-03-05 15:09:27.488 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 82: SendData Request. CallBack ID = 134, Status = Transmission complete and ACK received(0)
2020-03-05 15:09:27.490 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2020-03-05 15:09:27.491 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 6027: Advanced to WAIT_DATA
2020-03-05 15:09:27.492 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: TID 6027: Transaction not completed
2020-03-05 15:09:27.493 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.495 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-05 15:09:27.539 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 52 08 70 06 07 04 2A 00 00 00 F0
2020-03-05 15:09:27.544 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 08 70 06 07 04 2A 00 00 00
2020-03-05 15:09:27.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=82, callback=0, payload=00 52 08 70 06 07 04 2A 00 00 00
2020-03-05 15:09:27.548 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-05 15:09:27.550 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Application Command Request (ALIVE:DONE)
2020-03-05 15:09:27.551 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: resetResendCount initComplete=true isDead=false
2020-03-05 15:09:27.553 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2020-03-05 15:09:27.554 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 82: SECURITY not supported
2020-03-05 15:09:27.555 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 82: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2020-03-05 15:09:27.557 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 82: Node configuration report, parameter = 7, value = 704643072, size = 4
2020-03-05 15:09:27.558 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2020-03-05 15:09:27.560 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@f1dd3f
2020-03-05 15:09:27.561 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Update CONFIGURATION 7/4 to 704643072
2020-03-05 15:09:27.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Commands processed 1.
2020-03-05 15:09:27.565 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6be648.
2020-03-05 15:09:27.567 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6be648.
2020-03-05 15:09:27.568 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 82: notifyTransactionResponse TID:6027 DONE
2020-03-05 15:09:27.570 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 82: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-03-05 15:09:27.572 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2020-03-05 15:09:27.573 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2020-03-05 15:09:27.574 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-05 15:09:27.575 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
