xchwarze
(xchwarze)
January 19, 2018, 1:21am
#1
Hello! I want to migrate from domoticz to OA2 but some off my sensor they are not supported!
I have several of these https://products.z-wavealliance.org/products/1953
someone knows how to use the domoticz zwave config file to create a valid zwave openhab xls?
domoticz file:
<?xml version="1.0" encoding="utf-8"?>
<Product xmlns='http://code.google.com/p/open-zwave/'>
Dome Z-Wave Plus Motion Detector
<!-- Configuration Parameters -->
<CommandClass id="112">
<Value type="byte" genre="config" index="1" label="Sensitivity Level" value="8" min="8" max="255" size="1">
<Help>
This parameter sets the sensitivity of the Motion Detector.
It is a unitless parameter ranging in values from 8 up to 255, with 8 being the highest sensitivity level and 255 being the lowest.
After physical installation, make sure the farthest part of the coverage area is still visible to the Motion Detector by adjusting this parameter.
</Help>
</Value>
<Value type="short" genre="config" index="2" label="Motion Cleared Time Delay" value="30" units="Seconds" min="5" max="600" size="2">
<Help>
This parameters sets the amount of time after a motion event before the Motion Detector reports no activity to the main controller.
This also sets the amount of time before a BASIC_SET(00) command is sent to Association Group 2 to turn off any activated devices.
This value must be higher than the value of Parameter 6, and if this parameter is reset to default settings, Parameter 6 will also be reset.
This file has been truncated. show original
OH2 file:
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="zwave"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0
http://eclipse.org/smarthome/schemas/thing-description/v1.0.0">
<thing-type id="eco_pir1_00_000" listed="false">
<label>PIR Z-Wave PIR Motion Sensor</label>
<description><![CDATA[
Z-Wave PIR Motion Sensor<br /><h1>Overview</h1><p>The sensor has two Association groups available for up to five Z-Wave Node IDs each.<br />Association group one is intended for but not limited to controllers. All nodes whose Node ID<br />that have been set in Association group one will receive all unsolicited Alarm Report frames,<br />and Basic Report frames of 0x00 and 0xFF. Association group two is intended for any device</p> <p>that is controllable with a Basic Set of 0xFF such as lights, sirens, or chimes.<br />When a sensor such as a door or window sensor is opened/faulted, the sensor will send a Basic<br />Report to nodes in Association group one and a Basic Set of 0xFF to Association group two.<br />When the door or window is closed the sensor will send a Basic Report of 0x00 to only group<br />one. The Configuration command class can configure the sensor to send Basic Sets of 0x00 to<br />nodes in group two (turning devices off). See Configuration Command Class.</p> <br /><h2>Wakeup Information</h2><p>By default, a sensor is configured to send Wake Up Notification frames every three hours. A<br />controller may change the duration between Wake Up Notification frames to be between one<br />hour and one week in increments of two hundred seconds with the Wake Up Interval Set<br />command. The sensor will send Wake Up Notification frames to the Node ID specified in the<br />Wake Up Set Interval command or 255 if no valid nodes have been set.</p>
]]></description>
<category>MotionDetector</category>
<!-- CHANNEL DEFINITIONS -->
<channels>
<channel id="sensor_door" typeId="sensor_door">
<label>Binary Sensor</label>
<properties>
<property name="binding:*:OpenClosedType">SENSOR_BINARY</property>
any help is appreciated!
sihui
(SiHui)
January 19, 2018, 8:52am
#2
I guess it is this one?
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/584
You don’t need to create it, those are in the database and available as soon as you include the device into your network.
xchwarze
(xchwarze)
January 20, 2018, 12:40am
#3
hello sihui!
visually it is similar but it is not that!
the device appears to me as unknown in OH2 but in domoticz is detected as Dome PIR sensor
sihui
(SiHui)
January 20, 2018, 7:10am
#4
Then you need to upload your xml file (in userdata/zwave
) to the database.
xchwarze
(xchwarze)
January 20, 2018, 5:23pm
#5
there is documentation that explains how they are made they XML?
sihui
(SiHui)
January 20, 2018, 5:26pm
#6
It’s coming from the device as soon as you add it to your network.
No need for manual intervention …
