Hi
I can´t see how I create an items for an EnOcean switch, i use a USB300 enocean gateway
when I press the frykket, I receive this command in the log:
18:54:13.474 [DEBUG] [.enocean.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[02, FF, FF, FF, FF, 36, 00], crc8d=82], raw=[55, 00, 00, 07, 01, 6C, 02, FF, FF, FF, FF, 36, 00, 52], [sender=00:2D:3E:50, repeaterCount=0]
And when I release I receive this:
18:54:15.908 [DEBUG] [.enocean.internal.bus.EnoceanBinding] - Packet received: RadioPacketRPS[header=[Header: dataLength=00, optionalDataLength=07, packetType=01, crc8h=6C], payload=Payload: data=[], optionaldata=[02, FF, FF, FF, FF, 37, 00], crc8d=71], raw=[55, 00, 00, 07, 01, 6C, 02, FF, FF, FF, FF, 37, 00, 47], [sender=00:2D:3E:50, repeaterCount=0]
I’ve seen you have to set it up like so, but I do not know where to find the different things in the received command:
{ enocean="{id=00:00:00:00, eep=F6:02:01, channel=A, parameter=O}" }
can anyone help,
