Inmar
(Inmar)
February 11, 2020, 1:39pm
1
Hi
I found 2 jar files that I would like to add to my binding list.
I put the jar files in the folder \OPENHAB\openHAB-share\openhab2-addons
I reboot the OH and clear the cache.
But still I don’t see the new bindings in the addon page on paperUI.
I am running my system on Resp pi 4.
Any suggestion what can be the problem?
Thanks in advanced
sihui
(SiHui)
February 11, 2020, 4:10pm
2
That is pretty normal, they won’t show up.
If you want to see if they are active log into karaf and check the console
Inmar
(Inmar)
February 11, 2020, 4:37pm
3
Is it enough to put it on the folder?
Don’t I need to activate /install the jar?
sihui
(SiHui)
February 11, 2020, 4:44pm
4
Yes.
No, but you can check if it is activated like I described above.
HaKuNa
(Remo M)
5
you should see it in PaperUI / Configuration / Bindings
Inmar
(Inmar)
February 11, 2020, 7:25pm
6
I don’t see it in the paper UI
sihui
(SiHui)
February 11, 2020, 8:13pm
7
You should see them active with bundle:list
through Karaf.
HaKuNa
(Remo M)
February 11, 2020, 10:01pm
8
The 2 bindings in the addons folder are visible in PaperUI, see screenshot
H102
(CM6.5 H102)
February 12, 2020, 12:54am
9
Does the user openhab have correct permissions to the jar file?
If you installed via openhabian image then use openhabian-config tool and select fix permissions, that will solve the issue.
