Dear Colleagues, looks stupid but I can’t get it work. I need to add time then rule execute (i’m getting time valur) to a textual Item (KegeratorTime), but I tried:
However it didn’t update my item to print it on my sitemap. Entire Rule below
rule “Kegerator Check”
System started or
Time cron "0 0/30 * 1/1 * ? *" or
Item SonoffKegerator_TempKeg received update or
Item Kegerator_SetPoint received update or
Item SonoffKegerator_PowerKegerator received update
//var Number set_keg = (SonoffKegerator_TempKeg.state as DecimalType).intValue
var Number set_keg = Kegerator_SetPoint.state as DecimalType
//var Number keg = SonoffKegerator_TempKeg.state as DecimalType
var Number keg = (SonoffKegerator_TempKeg.state as QuantityType<Number>).doubleValue
//get time last change
var hour = now.getHour
var minute = now.getMinute
//logInfo("Kegerator", "Validation:" + keg)
if (keg >= set_keg ) {
//logInfo("Kegerator", "keg>set" + set_keg +"-" + keg )
if (SonoffKegerator_PowerKegerator.state == OFF){
sendCommand(SonoffKegerator_PowerKegerator, ON)
//sendCommand(KegeratorTime, "Power ON: " + hour + ":" + minute )
KegeratorTime = "Power ON: " + hour + ":" + minute
logInfo("Kegerator", "Temperature < set - power on" + keg)
}else if (keg < (set_keg -1)) {
//logInfo("Kegerator", "keg<set" + set_keg +"-" + keg )
if (SonoffKegerator_PowerKegerator.state == ON){
sendCommand(SonoffKegerator_PowerKegerator, OFF)
//sendCommand(KegeratorTime, "Power OFF: " + hour + ":" + minute )
KegeratorTime = "Power OFF: " + hour + ":" + minute
Please mark code as code, otherwise code will be truncated or maybe changed slightly.as seen in your posting…
And it’s more readably without that much commented out lines…
System started or
Time cron "0 0/30 * * * ?" or
Anyway…
The two vars minute and hour are of type Integer, as this is the type of .getHour and .getMinute. If you want to use them as string, you have to use now.getHour.toString and now.getMinute.toString
You also use KegeratorTime as a simple var, but it isn’t. As it’s an Item, you have to use postUpdate instead.
Please be aware that the code can be optimized:
// No need of System started, as any change will trigger the rule
Time cron "0 0/30 * * * ?" or // even this is waste...
Item SonoffKegerator_TempKeg changed or // changed will suffice
Item Kegerator_SetPoint changed or // changed will suffice
Item SonoffKegerator_PowerKegerator changed // changed will suffice
val Number set_keg = Kegerator_SetPoint.state as DecimalType
val Number keg = (SonoffKegerator_TempKeg.state as QuantityType<Number>).doubleValue
val strTime = ": " + now.getHour.toString + ":" + now.getMinute.toString
var Switch myState = NULL // use a var to minimize code duplication
if (keg >= set_keg)
myState = ON
else if(keg < set_keg - 1)
myState = OFF
if(myState != NULL && SonoffKegerator_PowerKegerator.state != myState) {
SonoffKegerator_PowerKegerator.sendCommand(myState.toString)
val strText = "Power " + myState.toString + strTime
KegeratorTime.postUpdate(strText)
logInfo("Kegerator", "Temperature ({}) {} set ({}) - power {} "keg,if(myState == ON) ">" else "<" ,set_keg,myState)
Thanks so much for your support, I’m not very programmatic guys but now I learn good tricks. I’m getting bellow error, may you help me to find the issue?
Script execution of rule with UID ‘kegeretor-1’ failed: Unknown variable or command ‘!==’; line 19, column 8, length 16 in kegeretor
I tried to add != and !== and didn’t work, its for below validation:
if(myState !== NULL && SonoffKegerator_PowerKegerator.state !== myState) {
var OnOffType myState = null // use a var to minimize code duplication
if (keg >= set_keg)
myState = ON
myState = OFF
if(myState !== null && SonoffKegerator_PowerKegerator.state != myState) {
Please be aware of the additional changes about myState (!== null instead of != NULL)
