Hello I am trying to create a Global Cache IR Thing in OpenHab2.
However, I continuously get the following error: UNINITIALIZED_HANDLER_INITIALIZATION_ERROR.
The logs say:
An error occurred while calling method “ThingHandler.initialize()” on org.openhab.binding.globalcache.handler.GlobalCacheHandler: null
Java.lang.NullPointerException: null
at org.openhab.binding.globalcache.handler.GlobalCacheHandler.initialize(GlobalCacheHandler.java:104)
Would anyone know how to establish a connection with Global Cache IR?
Or how to approach these null pointer exceptions? The impression I get is that it is unable to associate a binding to the Thing.
Sorry you’re having trouble. Just a couple questions to understand your setup…
What version of openHAB are you running?
How are you adding the globalcache thing? Was it added from the inbox after it was automatically discovered? Did you add it manually using Paper UI? Did you add it using a .things file?
Which globalcache device are you using (e.g. IP2IR, WF2IR, Flex, etc.)?
