I have been working to get my Z-wave me Z-Uno device to work with openHAB. The issue is that this device is not supported by openHAB given that the user defines endpoints. So a custom binding needs to be created and installed with a custom device .xml file.
My Process
I have been following this post but got stuck on Step 6: 4 - 6:
4. Stop OpenHAB
sudo systemctl stop openhab2.service
5. Add new jar to the addons folder (for my install, it is located at /usr/share/openhab2/addons)
6. Start OpenHAB
sudo systemctl start openhab2.service
I cannot figure out the password to use sudo because password doesn’t seem to work. Also the addons file path in karaf will not be the same /openhab2/ even if I got to the next step.
However, I don’t think this is a problem because I was able to add the jar file to the openhab-3.3.0/addons folder and it showed up in my bundle:list. I then activated it with bundle:start, and my controller and Z-Uno were ‘online’ without a UI-Installed z-wave binding.
246 │ Active │ 80 │ 3.4.0.202207181739 │ openHAB Add-ons :: Bundles :: ZWave Binding
The Issue
The issue is that my Z-Uno does not have the channel options that I defined in the .xml. I found the xml files in this (org.openhab.binding.zwave\src\main\resources\OH-INF\thing\zwaveme) folder of the z-wave binding and packaged the jar file with Maven (Packaged File Name: org.openhab.binding.zwave-3.4.0-SNAPSHOT). For reference here is the Github repo of the zwave binding and the .xml that I added to the folder above.
<?xml version="1.0" encoding="UTF-8"?>
<thing:thing-descriptions bindingId="zwave"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0
http://eclipse.org/smarthome/schemas/thing-description/v1.0.0">
<thing-type id="zwaveme_zuno_sensor_001" listed="false">
<label>Z-Uno Sensor Node</label>
<description>
<![CDATA[
<h2>Z-Uno RGB LED Strip</h2>
<ul>
<li>Temperature Sensor 1: Unassigned</li>
<li>Temperature Sensor 2: Unassigned</li>
<li>Voltage Sensor 1: Unassigned</li>
<li>Voltage Sensor 2: Unassigned</li>
<li>Humidity Sensor 1: Unassigned</li>
<li>Humidity Sensor 2: Unassigned</li>
<li>Pressure Sensor 1: Unassigned</li>
<li>Pressure Sensor 2: Unassigned</li>
</ul>
<br />
<h2>Inclusion Information</h2>
<p>Push 3 times</p>
<br />
<h2>Exclusion Information</h2>
<p>Push 3 times</p>
<br />
<h2>Wakeup Information</h2>
<p>Push 3 times</p>
</description>
<category>ZunoSensorNode</category>
<!-- CHANNEL DEFINITIONS -->
<channels>
<channel id="sensor_temperature" typeId="sensor_temperature">
<label>Temperature Sensor 1</label>
<properties>
<property name="binding:*:QuantityType">COMMAND_CLASS_SENSOR_MULTILEVEL:1,COMMAND_CLASS_BASIC:1;type=TEMPERATURE</property>
</properties>
</channel>
<channel id="sensor_temperature1" typeId="sensor_temperature">
<label>Temperature Sensor 2</label>
<properties>
<property name="binding:*:QuantityType">COMMAND_CLASS_SENSOR_MULTILEVEL:2,COMMAND_CLASS_BASIC:2;type=TEMPERATURE</property>
</properties>
</channel>
<channel id="sensor_voltage" typeId="sensor_voltage">
<label>Voltage Sensor 1</label>
<properties>
<property name="binding:*:QuantityType">COMMAND_CLASS_SENSOR_MULTILEVEL:3,COMMAND_CLASS_BASIC:3;type=VOLTAGE</property>
</properties>
</channel>
<channel id="sensor_voltage1" typeId="sensor_voltage">
<label>Voltage Sensor 2</label>
<properties>
<property name="binding:*:QuantityType">COMMAND_CLASS_SENSOR_MULTILEVEL:4,COMMAND_CLASS_BASIC:4;type=VOLTAGE</property>
</properties>
</channel>
<channel id="sensor_humidity" typeId="sensor_relhumidity">
<label>Humidity Sensor 1</label>
<properties>
<property name="binding:*:PercentType">COMMAND_CLASS_SENSOR_MULTILEVEL:5,COMMAND_CLASS_BASIC:5;type=RELATIVE_HUMIDITY</property>
</properties>
</channel>
<channel id="sensor_humidity1" typeId="sensor_relhumidity">
<label>Humidity Sensor 2</label>
<properties>
<property name="binding:*:PercentType">COMMAND_CLASS_SENSOR_MULTILEVEL:6,COMMAND_CLASS_BASIC:6;type=RELATIVE_HUMIDITY</property>
</properties>
</channel>
<channel id="pressure_Sensor" typeId="sensor_barpressure">
<label>Pressure Sensor 1</label>
<properties>
<property name="binding:*:QuantityType">COMMAND_CLASS_SENSOR_MULTILEVEL:7,COMMAND_CLASS_BASIC:7;type=BAROMETRIC_PRESSURE</property>
</properties>
</channel>
<channel id="pressure_Sensor1" typeId="sensor_barpressure">
<label>Pressure Sensor 2</label>
<properties>
<property name="binding:*:QuantityType">COMMAND_CLASS_SENSOR_MULTILEVEL:8,COMMAND_CLASS_BASIC:8;type=BAROMETRIC_PRESSURE</property>
</properties>
</channel>
</channels>
<!-- DEVICE PROPERTY DEFINITIONS -->
<properties>
<property name="vendor">Z-Wave.Me</property>
<property name="modelId">z_uno</property>
<property name="manufacturerId">0115</property>
<property name="manufacturerRef">0110:0001</property>
<property name="versionMin">0</property>
<property name="versionMax">10</property>
<property name="dbReference">9999</property>
</properties>
<!-- CONFIGURATION DESCRIPTIONS -->
<config-description>
<!-- STATIC DEFINITIONS -->
<parameter name="node_id" type="integer" min="1" max="232" readOnly="true" required="true">
<label>Node ID</label>
<advanced>true</advanced>
</parameter>
</config-description>
</thing-type>
</thing:thing-descriptions>
I have looked at many threads about the Z-Uno but had no such luck. I did see that dependencies have to be declared if using the openhab-3-3-0/addons folder, but I wouldn’t know how to do that even if that were the issue. I also tried using the jsondb files to configure the channels which worked one day but hasn’t worked since.
If you have any ideas as to where I went wrong, pls let me know. I suspect that there is a database file of supported devices that I need to add the zuno xml file to or something similar.
Environment: Windows 10 install of openHAB 3.3.0; Zwave binding version is 3.4.0; Java 11
There are a few related posts, but I can only use 2 links
