Adding channel/item to ESPHome generated thing
Hi.
Running OH3.0.0 on a windows environment with an external MQTT broker (On a separate Debian machine)
I have this auto generated thing from ESPHome
Which contains a relay, and a DHT12 (temp and humidity sensor)
Auto Discovery got me to this point. :slight_smile:
When editing the “OGS_04” thing, I get this:
When you are green as I, then messages easily scare you off :slight_smile:
I don’t know if/how it matters.
Any suggestion?
Bug?
As seen in lower part of picture OH3 knows about the IO’s
And I could easily items from them from the model view.
I can only see measurements flow as expected, but why the message?
Great product :slight_smile:
Just a hard coded message that always appears! If it’s working fine, you can ignore it!
I get the same message for all my perfectly fine Things:
Screenshot_20210213-173721
