Hi All,
Could someone provide a quick overview of how I could embed a chart.js into a habpanel widget?
I found this:
http://jtblin.github.io/angular-chart.js/
But I dont know much about angular.
Thanks,
Paul
Hi All,
I found this:
Thanks,
Paul
If none of them makes sense, it will be extremely difficult for you.
Well, that does seem too complicated. I opted to go with a simpler option to build some bars.
I am now stumped with calculating the min and max for a json array.
<div ng-init="hours = $eval(itemState('WeatherHourly_json'));"></div>
How do i get the max and min of hours.temp.metric ?
My JSON looks a bit like this:
"hours": [
"temp": {"english": "38", "metric": "3"},
"feelslike": {"english": "33", "metric": "1"},
"pop": "0",
"pop": "0",
Hi @luckymallari could you provide some insight as to why my custom widget doesn’t refresh when the Item that contains the JSON string gets updated?
I assign my variables in an ng-init="", however, from my reading it seems that it is not refreshed regularly.
How can I set variables in a widget for convenience but still have it refresh when the item refreshes?
My widget can be found here:
http://faure.ca/~paul/WeatherHourly.widget.json
I have described the full setup here:
