Is there a possibility to work with RGB colors in the HABpanel? Actually I added a Color Picker widget to the UI, but this uses HSL instead of RGB. I want to send the colors per MQTT to an Arduino, which controls a RGB stripe (so I need to have RGB).
In the Widget itself I set an OpenHAB Item which defines a Color object.
I got the idea for the RGB controller here: RGB LED strip control using Arduino and MQTT
But here they use 3 items:
/* LED STRIPS */
Color LivSoffitLight "Living Room Soffit Color" (Lights_LivingRoom)
String LivSoffitLightColor (Lights_LivingRoom) {mqtt=">[mosquitto:control/arduino_LED/livingroom/color:command:*:default]"}
Number LivSoffitAnimation "Living Room Soffit Animation" (Lights_LivingRoom) {mqtt=">[mosquitto:control/arduino_LED/livingroom/animation:command:*:default]"}
With this items file my MQTT didn’t sent anything, so I changed the above to use just one item:
Color LivSoffitLight "Living Room Soffit Color" (Lights_LivingRoom) {mqtt=">[broker:control/arduino_LED/livingroom/color:command:*:default]"}
So, my questions here are:
- Is there a possibility to use a RGB Color Wheel, instead the HSL one?
- Why does the three items of the tutorial not work for me?
- And is it ok to use just the one item “Color” instead of all three of the tutorial?
