Platform information:
- Hardware: x86 server
- OS: ubuntu, manual install
- Java Runtime Environment: java-11-openjdk-amd64
- openHAB version: 3.3.0
Issue of the topic:
I added IKEA ICPSHC24-30EU-IL-1 and zigbee2mqtt detects correctly, and I can switch light on/off through its interface.
When I add it to openhab, I don’t get any channel to switch it on/off. Reading documentation (https://www.zigbee2mqtt.io/devices/ICPSHC24-30EU-IL-1.html) I expectedstateandbrightness.
I don’t know if zigbee2mqtt forgets to announce them, or openhab don’t get them.
Could some channels be added manually? (and how, never done before) -
Please post configurations (if applicable):
UID: mqtt:homeassistant_zigbee2mqtt_5F0x0c4314fffe0f8ab6:mqtt-broker:encimeraCuina
label: encimeraCuina
thingTypeUID: mqtt:homeassistant_zigbee2mqtt_5F0x0c4314fffe0f8ab6
configuration:
topics:
- sensor/0x0c4314fffe0f8ab6/update_state
- sensor/0x0c4314fffe0f8ab6/power_on_behavior
- select/0x0c4314fffe0f8ab6/power_on_behavior
- binary_sensor/0x0c4314fffe0f8ab6/update_available
- update/0x0c4314fffe0f8ab6/update
- light/0x0c4314fffe0f8ab6/light
- sensor/0x0c4314fffe0f8ab6/linkquality
- select/0x0c4314fffe0f8ab6/effect
basetopic: homeassistant
bridgeUID: mqtt:broker:mqtt-broker
- If logs where generated please post these here using code fences:
de gen. 17 09:53:11 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:11: MQTT publish: topic 'zigbee2mqtt/encimeraCuina', payload '{"device":
{"applicationVersion":17,"dateCode":"20190401","friendlyName":"encimeraCuina","hardwareVersion":2,"ieeeAddr":"0x0c4314fffe0f8ab6","manufacturerID":4476,"man
ufacturerName":"IKEA of Sweden","model":"ICPSHC24-30EU-IL-1","networkAddress":32704,"powerSource":"Mains (single phase)","softwareBuildID":"1.2.245","stackV
ersion":87,"type":"Router","zclVersion":1},"linkquality":75,"power_on_behavior":null,"state":null,"update":{"installed_version":-1,"latest_version":-1,"stat
e":null},"update_available":null}'
de gen. 17 09:53:11 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:11: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/rename', pay
load '{"data":{"from":"0x0c4314fffe0f8ab6","homeassistant_rename":true,"to":"encimeraCuina"},"status":"ok","transaction":"9ve88-7"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/light/0x0c4314fffe0f8ab6/light/co
nfig', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"brightness":true,"brightness_scale":254,"command_topic":"zigbee2mqtt/encimeraCuina/s
et","device":{"identifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer":"IKEA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-I
L-1)","name":"encimeraCuina","sw_version":"1.2.245"},"effect":true,"effect_list":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"
json_attributes_topic":"zigbee2mqtt/encimeraCuina","name":"encimeraCuina","schema":"json","state_topic":"zigbee2mqtt/encimeraCuina","unique_id":"0x0c4314fff
e0f8ab6_light_zigbee2mqtt"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/select/0x0c4314fffe0f8ab6/effect/
config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/encimeraCuina/set/effect","device":{"identifiers":["zi
gbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer":"IKEA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","name":"encimeraCuina","sw
_version":"1.2.245"},"enabled_by_default":false,"icon":"mdi:palette","json_attributes_topic":"zigbee2mqtt/encimeraCuina","name":"encimeraCuina effect","opti
ons":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"unique_id":"0x0c4314fffe0f8ab6_effect_zigbee2mqtt"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe0f8ab6/power_o
n_behavior/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer
":"IKEA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","name":"encimeraCuina","sw_version":"1.2.245"},"enabled_by_default":fa
lse,"entity_category":"config","icon":"mdi:power-settings","json_attributes_topic":"zigbee2mqtt/encimeraCuina","name":"encimeraCuina power on behavior","sta
te_topic":"zigbee2mqtt/encimeraCuina","unique_id":"0x0c4314fffe0f8ab6_power_on_behavior_zigbee2mqtt","value_template":"{{ value_json.power_on_behavior }}"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/select/0x0c4314fffe0f8ab6/power_o
n_behavior/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/encimeraCuina/set/power_on_behavior","devic
e":{"identifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer":"IKEA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","nam
e":"encimeraCuina","sw_version":"1.2.245"},"entity_category":"config","icon":"mdi:power-settings","json_attributes_topic":"zigbee2mqtt/encimeraCuina","name"
:"encimeraCuina power on behavior","options":["off","on","toggle","previous"],"state_topic":"zigbee2mqtt/encimeraCuina","unique_id":"0x0c4314fffe0f8ab6_powe
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe0f8ab6/linkqua
lity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer":"IKE
A","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","name":"encimeraCuina","sw_version":"1.2.245"},"enabled_by_default":false,"e
ntity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/encimeraCuina","name":"encimeraCuina linkquality","state_class":"measu
rement","state_topic":"zigbee2mqtt/encimeraCuina","unique_id":"0x0c4314fffe0f8ab6_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{
value_json.linkquality }}"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/sensor/0x0c4314fffe0f8ab6/update_
state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer":"IK
EA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","name":"encimeraCuina","sw_version":"1.2.245"},"enabled_by_default":false,"
entity_category":"diagnostic","icon":"mdi:update","json_attributes_topic":"zigbee2mqtt/encimeraCuina","name":"encimeraCuina update state","state_topic":"zig
bee2mqtt/encimeraCuina","unique_id":"0x0c4314fffe0f8ab6_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/binary_sensor/0x0c4314fffe0f8ab6/
update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufa
cturer":"IKEA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","name":"encimeraCuina","sw_version":"1.2.245"},"device_class":"u
pdate","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/encimeraCuina","name":"encimeraCuina update available"
,"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/encimeraCuina","unique_id":"0x0c4314fffe0f8ab6_update_available_zigbee2mqtt","value_templa
te":"{{ value_json['update']['state'] == \"available\" }}"}'
de gen. 17 09:53:13 homeserver npm[4024]: Zigbee2MQTT:info 2023-01-17 09:53:13: MQTT publish: topic 'homeassistant/update/0x0c4314fffe0f8ab6/update/
config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"id
entifiers":["zigbee2mqtt_0x0c4314fffe0f8ab6"],"manufacturer":"IKEA","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","name":"enc
imeraCuina","sw_version":"1.2.245"},"device_class":"firmware","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attr
ibutes_topic":"zigbee2mqtt/encimeraCuina","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/encim
eraCuina","name":"encimeraCuina","payload_install":"{\"id\": \"0x0c4314fffe0f8ab6\"}","state_topic":"zigbee2mqtt/encimeraCuina","unique_id":"0x0c4314fffe0f8
ab6_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
