DrMoe
(DrMoe)
June 16, 2021, 12:26pm
1
Hi all,
I am trying to add Nuki Opener through Main UI. I followed the following installation guide: https://www.openhab.org/addons/bindings/nuki/
As documented:
This binding supports just one thing type: The Nuki Smart Lock.
Is there a way to add the Nuki-opener in the Main UI?
Thanks!!
DrMoe
(DrMoe)
June 20, 2021, 9:05am
2
Can anyone help here? any tips would be appreciated
mstormi
(Markus Storm)
July 13, 2021, 8:30am
4
Create a Switch type item for the nuki:smartlock:.....:lock channel, then reference that item from the Main UI like you do with any other item.
DrMoe
(DrMoe)
July 13, 2021, 12:46pm
5
mstormi:
Thanks Markus, can you please elaborate more?
mstormi
(Markus Storm)
July 13, 2021, 12:48pm
6
No. What is unclear about that ?
DrMoe
(DrMoe)
July 13, 2021, 1:03pm
7
What is unclear are the steps to follow?
When trying to add a new item from the Nuki binding (MainUI), I selected the “Nuki Smart lock” item and update the configurations with the Nuki ID from the opener (Again this is because the opener is not available), but then I usually receive the error that the BRIDGE_UNITIALIZED. Meanwhile, when I follow the same steps and used the Nuki ID from the “smart lock”, it works fine.
mstormi
(Markus Storm)
July 13, 2021, 1:24pm
8
I don’t understand what you mean by “opener” ?
Use the channel from the lock’s thing for your item.
DrMoe
(DrMoe)
July 13, 2021, 1:31pm
9
Nuki Opener is a device used to open the building door (intercom buzzer). Nuki | Opener | Buy Smart Locks & accessories online | Nuki The Smart Lock
Nuki Smart Lock is a device used to open the apartment door. Nuki | Electronic door lock for smart access | Nuki The Smart Lock
On the MainUI, only the Nuki Smart Lock is available, and my question was “is there a way to add Nuki Opener” using the MainUI?
mstormi
(Markus Storm)
July 13, 2021, 1:36pm
10
I don’t know that one. Do you need to add it after all ?
What’s happening if you use the switch/channel I wrote about, does it open the door ? That’s what the “opener” device is all about, isn’t it.
DrMoe
(DrMoe)
July 13, 2021, 6:15pm
11
What do you mean by “use the switch/channel”?
mstormi
(Markus Storm)
July 13, 2021, 9:15pm
12
Create a switch item, link it to the channel and then switch it. Does it open the door?
