Is it possible add support for RTX Zigbee sensor temperature, because now, afer the discovery I got:
“No supported clusters found”.
The sensor:
Fingerprint:
| |> Logical Type END_DEVICE
| |> MAC Capabilities [REDUCED_FUNCTION_DEVICE]
| |> Stack Compliance 22
| |> Server Capabilities []
| |> Buffer Size 82
| |> Incoming Transfer Size 82
| |> Outgoing Transfer Size 82
|>| Power Descriptor
| |> Available Power Sources [MAINS]
| |> Current Power Source MAINS
| |> Current Power Mode RECEIVER_ON_IDLE
| |> Power Level FULL
|>| ZDO
| |> ManagementBindRequest SUCCESS
| |> IeeeAddressRequest SUCCESS
| |> ManagementLqiRequest SUCCESS
| |> ManagementRoutingRequest SUCCESS
|>| Basic Information
| |> Generic Device Class
| |> Generic Device Type
| |> Manufacturer Name _TZE200_qyflbnbj
| |> Model Indentifier TS0601
| |> Product Code
| |> Product URL
| |> Date Code
| |> Application Version 70
| |> Software Build ID
| |> Hardware Version 1
| |> Zcl Version 3
| |> Stack Version 0
| |>| Endpoint 1
| | |> Profile 0104 ZIGBEE_HOME_AUTOMATION
| | |> Device Type 0051 SMART_PLUG
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Server [Input]
| | | | |> Manufacturer Spec. No
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | | |> FAILURE
| | | | |>| Attributes Supported
| | | | | |> 0000 ZCL Version >> UNSIGNED_8_BIT_INTEGER 3
| | | | | |> 0001 Application Version >> UNSIGNED_8_BIT_INTEGER 70
| | | | | |> 0002 Stack Version >> UNSIGNED_8_BIT_INTEGER 0
| | | | | |> 0003 HW Version >> UNSIGNED_8_BIT_INTEGER 1
| | | | | |> 0004 Manufacturer Name >> CHARACTER_STRING _TZE200_qyflbnbj
| | | | | |> 0005 Model Identifier >> CHARACTER_STRING TS0601
| | | | | |> 0006 Date Code >> CHARACTER_STRING
| | | | | |> 0007 Power Source >> ENUMERATION_8_BIT 3
| | | | | |> FFDE >> UNSIGNED_8_BIT_INTEGER 11
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 2
| | | | | |> FFFE Attribute Reporting Status >> ENUMERATION_16_BIT 0
| | | |>| Cluster 0004 Groups
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | | |> FAILURE
| | | | | |> 0000 Scene Count >> UNSIGNED_8_BIT_INTEGER 0
| | | | | |> 0001 Current Scene >> UNSIGNED_8_BIT_INTEGER 0
| | | | | |> 0002 Current Group >> UNSIGNED_16_BIT_INTEGER 0
| | | | | |> 0003 Scene Valid >> BOOLEAN false
| | | | | |> 0004 Name Support >> BITMAP_8_BIT 0
| | | |>| Cluster EF00
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | |>| Cluster 000A Time
| | | | |> Type Client [Output]
| | | | |> Unsupported locally
| | | |>| Cluster 0019 Ota Upgrade
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | | |> FAILURE
| | | | | |> 0000 Upgrade Server ID >> IEEE_ADDRESS FFFFFFFFFFFFFFFF
| | | | | |> 0001 File Offset >> UNSIGNED_32_BIT_INTEGER -1
| | | | | |> 0006 Image Upgrade Status >> ENUMERATION_8_BIT 0
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 3
