Adding Switch Item
In OH2, in trying to work out a rule, I added to my items file a generic TestSwitch like below
Switch TestSwitch					"Test Switch"
The Switch is not associated with any kind of binding or group.
I add the switch to my sitemap and it shows there. But when I toggle it On and Off, I do not see any kind of entries in the log on it? So I’m sorta stuck in confirming if this rule is working
rule "Testing"
	TestSwitch received update
	if (TestSwitch.state==ON) {
		sendCommand(FF_Light_FamilyLeft,ON)
Try
Item TestSwitch received command
in the when clause and the built-in variable receivedCommand to access it.
Shouldn’t it read like that?
rule “Testing”
FF_Light_FamilyLeft.sendCommand(ON)
Hello!
Since you’re going to use it only when it receives ON, I think it would be much easier to do it this way:
rule "Testing"
   Item TestSwitch changed to ON
Do you have FF_Light_FamilyLeft item defined in your Items file? And what happens if you change TestSwitch to OFF? Do you just ignore OFF state?
Best regards,
Davor
Edit: @DocFraggle: I forgot it too. Thank you for the correction.
Hi, you forgot the “Item” at the beginning!
rule "abcd"
  Item TestSwitch received update
This implied (to me) that it is being sent a command, so received command would be the more appropriate trigger.
