I have zwave device that’s not in database. I cut a ticket to request permissions to add new devices. However, I don’t know how long it takes to process that request. Could somebody with the access add the device for me so I can start using it? Here is the XML file:
I’m not the reviewer but have done a few. Some suggestions
shorten the description to match other devices (move into the body somewhere)
Add the parameters and Association group 1 (with controller as default) per the manual
Mark for review on the first tab (or it will never get added)
You can use the “gear” to download an XML that you can add to your current zwave jar with this procedure. (Either procedure) if you want to get going now.
I see. I was expecting some table. I added the values and submitted it for review. I’ll use the procedure that you linked to update my files locally. Thanks for your help!
