Adding unrecognized zwave device
I’m not the reviewer but have done a few. Some suggestions
  1. shorten the description to match other devices (move into the body somewhere)
  2. Add the parameters and Association group 1 (with controller as default) per the manual
  3. Mark for review on the first tab (or it will never get added)
  4. You can use the “gear” to download an XML that you can add to your current zwave jar with this procedure. (Either procedure) if you want to get going now.
