hi all! I’m trying to add a zoneminder monitor to my overview page but I can’t get anything to play. I’m completely lost in this. I just want to be able to view my camera on my overview page on the wall-mounted tablet I set up. Which Channel do I even add as a “point”? What widget type do I use?
Should be the VideoURL channel, and you’ll want to use the Image Card and select the Item for whatever monitor you want(VideoURL) and it should display.
Tried the image card and it just shows a missing\corrupted image icon in the corner.
The video card just displays a message about no source. The camera plays fine in zoneminder. The computer has FFmpeg installed so transcoding shouldn’t be an issue.
I also tried adding the camera thru the IP camera binding with the same results. Adds to things fine but can’t get it to show video in openhab.
I’m wondering if it is because I am running ZM on the same machine?
I can load ZM and see the video just fine and openhab says it’s online it just won’t display it.
Wish I had another computer to run ZM on and see if it fixes it.
sorry for the late reply - life happened.
If I put the URL in my web browser it works fine.
I do have authentication on my zm but I have tried with auth turned off.
Ok so another reboot and now it works.
but what widget settings do i use to make it show in the overview page? I have a card in the overview page for it now but it does nothing. I’m trying to set up wall mounted tablets for home control and monitoring and learning things along the way.
I can’t find that as an option in the page editor. I have that selected for the “standalone widget” in the model. It’s working there. But the card on the overview page does nothing.
In my case it’s on a separate page where I put the video from all the cameras. I’m far from an expert on the new UI, but I don’t see why it wouldn’t work on the overview page.
