Based on my test with SNAPSHOT build #1713, I think this is a bug with this build. I didn’t get so far as to get build #1713 working here, but I may try repeating the first entry in each of my addons.cfg file configuration items.
My log contains repeated occurrences of the following error sequence:
2019-10-08 05:17:52.246 [ERROR] [ool-25-thread-1] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-package-= minimal': No matching features for openhab-package-= minimal/0
2019-10-08 05:17:52.300 [ERROR] [ool-25-thread-1] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-lutron, openhab-misc-= ruleengine, openhab-transformation-= jsonpath, openhab-transformation-regex, openhab-binding-zwave, open
hab-ui-restdocs, openhab-binding-= astro, openhab-binding-mqtt, openhab-persistence-rrd4j, openhab-transformation-map, openhab-binding-ntp, openhab-ui-habmin, openhab-binding-expire1, openhab-ui-= basic, openhab-ui-paper, openhab-persistence-= mapdb, op
enhab-transformation-scale': Error:
Error downloading mvn:org.openhab.ui.bundles/org.openhab.ui.paper/2.5.0-SNAPSHOT
2019-10-08 05:18:52.247 [ERROR] [ool-27-thread-1] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-package-= minimal': No matching features for openhab-package-= minimal/0
2019-10-08 05:18:52.307 [ERROR] [ool-27-thread-1] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-lutron, openhab-misc-= ruleengine, openhab-transformation-= jsonpath, openhab-transformation-regex, openhab-binding-zwave, open
2019-10-08 05:19:52.246 [ERROR] [ool-28-thread-1] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-package-= minimal': No matching features for openhab-package-= minimal/0
2019-10-08 05:19:52.290 [ERROR] [ool-28-thread-1] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-lutron, openhab-misc-= ruleengine, openhab-transformation-= jsonpath, openhab-transformation-regex, openhab-binding-zwave, open
My addons.cfg (works just fine for SNAPSHOT build #1706):
# The installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB
# Note: If you want to specify your add-ons yourself through entries below, set the package to "minimal"
# as otherwise your definition might be in conflict with what the installation package defines.
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other add-ons. Use this for custom setups.
# - simple : Setup for using openHAB purely through UIs - you need to expect MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from openHAB 1.x
# - demo : A demo setup which includes UIs, a few bindings, config files etc.
# See https://www.openhab.org/docs/configuration/packages.html for a detailed explanation of these packages.
package = minimal
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
legacy = true
# A comma-separated list of bindings to install (e.g. "binding = sonos,knx,zwave")
binding = astro,expire1,lutron,mqtt,ntp,zwave
# A comma-separated list of UIs to install (e.g. "ui = basic,paper")
ui = basic,habmin,paper,restdocs
# A comma-separated list of persistence services to install (e.g. "persistence = rrd4j,jpa")
persistence = mapdb,rrd4j
# A comma-separated list of actions to install (e.g. "action = mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "transformation = map,jsonpath")
transformation = jsonpath,map,regex,scale
# A comma-separated list of voice services to install (e.g. "voice = marytts,freetts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "misc = myopenhab")
misc = ruleengine
