One thing to try before scratching everyting: what do you get from the things endpoint in the rest api?
Easiest is to check via the rest docs, in the GET things/{thingUID} section. Mine for example looks like:
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"editable": true,
"label": "Wasroom_Multisensor",
"bridgeUID": "zwave:serial_zstick:z-stick",
"configuration": {
"config_52_1": 50,
"config_54_2": 100,
"config_202_1": 0,
"config_204_1": 0,
"group_1": [
"controller",
"node_9"
"group_3": [],
"group_2": [],
"config_112_4": 3600,
"config_39_1": 20,
"config_9_2_00000100": 1,
"config_56_1": 4,
"config_58_1": 5,
"config_201_2_000000FF": 1,
"config_43_2": 100,
"config_64_1": 1,
"config_252_1": 0,
"config_60_1": 2,
"config_81_1": 0,
"config_41_4_0000FF00": 1,
"wakeup_interval": 3600,
"config_50_4_7FFF0000_wo": 0,
"config_255_4_wo": 0,
"action_heal": false,
"config_102_4": 0,
"config_9_2": 256,
"config_3_2": 120,
"config_45_1": 2,
"config_5_1": 1,
"config_41_4_wo": 20,
"config_55_1": 8,
"binding_cmdrepollperiod": 1500,
"config_53_2": 1000,
"config_51_1": 60,
"config_100_1_wo": 0,
"config_201_2": 1,
"config_203_2": 0,
"config_50_4_wo": 0,
"config_201_2_0000FF00": 0,
"wakeup_node": 1,
"config_113_4": 3600,
"config_9_2_00000001": 0,
"config_111_4": 3600,
"config_49_4_wo": 0,
"config_59_1": 10,
"config_49_4_7FFF0000_wo": 280,
"config_57_2": 5121,
"config_42_1": 10,
"config_41_4_00FF0000": 0,
"config_44_1": 10,
"config_50_4_0000FF00_wo": 1,
"config_61_1": 0,
"config_40_1": 0,
"config_49_4_0000FF00_wo": 1,
"action_failed": false,
"config_110_1_wo": 0,
"action_remove": false,
"binding_pollperiod": 86400,
"config_2_1": 0,
"config_101_4": 241,
"config_8_1": 15,
"config_46_1": 0,
"config_4_1": 5,
"config_48_1": 0,
"config_103_4": 0,
"node_id": 10
"properties": {
"zwave_class_basic": "BASIC_TYPE_ROUTING_SLAVE",
"zwave_class_generic": "GENERIC_TYPE_SENSOR_MULTILEVEL",
"zwave_neighbours": "1,3,4,5,6,7,9,11",
"zwave_lastwakeup": "2019-11-25T06:59:49Z",
"modelId": "ZW100",
"zwave_version": "1.11",
"zwave_plus_devicetype": "NODE_TYPE_ZWAVEPLUS_NODE",
"versionMin": "1.10",
"vendor": "AEON Labs",
"defaultAssociations": "1",
"zwave_routing": "true",
"zwave_beaming": "true",
"zwave_secure": "false",
"zwave_class_specific": "SPECIFIC_TYPE_ROUTING_SENSOR_MULTILEVEL",
"zwave_devicetype": "2",
"zwave_frequent": "false",
"zwave_listening": "false",
"manufacturerId": "0086",
"manufacturerRef": "0002:0064,0102:0064,0202:0064",
"dbReference": "778",
"zwave_deviceid": "100",
"zwave_nodeid": "10",
"zwave_lastheal": "2019-11-25T02:04:52Z",
"zwave_plus_roletype": "ROLE_TYPE_SLAVE_SLEEPING_REPORTING",
"zwave_manufacturer": "134"
"UID": "zwave:device:z-stick:node10",
"thingTypeUID": "zwave:aeon_zw100_01_010",
"channels": [
"linkedItems": [
"WashRoom_MultiSensor_Temperature"
"uid": "zwave:device:z-stick:node10:sensor_temperature",
"id": "sensor_temperature",
"channelTypeUID": "zwave:sensor_temperature",
"itemType": "Number:Temperature",
"kind": "STATE",
"label": "Sensor (temperature)",
"description": "Indicates the current temperature",
"defaultTags": [],
"properties": {
"binding:*:QuantityType": "COMMAND_CLASS_SENSOR_MULTILEVEL;type=TEMPERATURE"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:z-stick:node10:sensor_ultraviolet",
"id": "sensor_ultraviolet",
"channelTypeUID": "zwave:sensor_ultraviolet",
"itemType": "Number",
"kind": "STATE",
"label": "Sensor (ultraviolet)",
"description": "Indicates the current ultraviolet level",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_SENSOR_MULTILEVEL;type=ULTRAVIOLET"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:z-stick:node10:sensor_luminance",
"id": "sensor_luminance",
"channelTypeUID": "zwave:sensor_luminance",
"kind": "STATE",
"label": "Sensor (luminance)",
"description": "Indicates the current light reading",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_SENSOR_MULTILEVEL;type=LUMINANCE"
"configuration": {}
"linkedItems": [
"WashRoom_MultiSensor_Humidity"
"uid": "zwave:device:z-stick:node10:sensor_relhumidity",
"id": "sensor_relhumidity",
"channelTypeUID": "zwave:sensor_relhumidity",
"kind": "STATE",
"label": "Sensor (relative humidity)",
"description": "Indicates the current relative humidity",
"defaultTags": [],
"properties": {
"binding:*:DecimalType": "COMMAND_CLASS_SENSOR_MULTILEVEL;type=RELATIVE_HUMIDITY"
"configuration": {}
"linkedItems": [
"WashRoom_MultiSensor_Motion"
"uid": "zwave:device:z-stick:node10:alarm_motion",
"id": "alarm_motion",
"channelTypeUID": "zwave:alarm_motion",
"itemType": "Switch",
"kind": "STATE",
"label": "Motion Alarm",
"description": "Indicates if a motion alarm is triggered",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_ALARM;type=BURGLAR, event=8"
"configuration": {}
"linkedItems": [],
"uid": "zwave:device:z-stick:node10:alarm_tamper",
"id": "alarm_tamper",
"channelTypeUID": "zwave:alarm_tamper",
"kind": "STATE",
"label": "Tamper Alarm",
"description": "Indicates if the tamper alarm is triggered",
"defaultTags": [],
"properties": {
"binding:*:OnOffType": "COMMAND_CLASS_ALARM;type=BURGLAR, event=3"
"configuration": {}
"linkedItems": [
"WashRoom_MultiSensor_Battery"
"uid": "zwave:device:z-stick:node10:battery-level",
"id": "battery-level",
"channelTypeUID": "system:battery-level",
"kind": "STATE",
"label": "Battery Level",
"defaultTags": [],
"properties": {
"binding:*:PercentType": "COMMAND_CLASS_BATTERY"
"configuration": {}
"location": "Washroom"
Check especially for the "editable": true parameter, and if you have all the entries in the "configuration: {} section.
If there’s somethin odd here, that might cause the isses you have.
