Adjust text size in Paper UI?
Dear all,
I’ve got a questions with regards to text size in Paper UI. Please have a look to the following: any ide how to make this look even more beautiful?
Many thanks.
Cheers,
Matthias
You have no control over the presentation of the ControlUI
This UI only represents channels to witch items are bound
You will need to create your own UI eventually via a sitemap for BasicUI or ClassicUI:
https://www.openhab.org/docs/tutorial/sitemap.html
or through HABpanel:
As for the tex size in Paper UI I created this issue in the Eclipse SmartHome issue tracker: Paper UI: reduce font size for item state text · Issue #6142 · eclipse-archived/smarthome · GitHub
