Advanced Irrigation Control Widget
IMG_0DCCBBFE1DCE-1
IMG_115621387BB8-1
IMG_D0AE15491271-1
IMG_091A9D525ED7-1
IMG_44746FBD16D2-1
This comprehensive irrigation widget provides complete control and monitoring for multi-zone irrigation systems with smart water usage tracking. Perfect for garden automation with soil moisture monitoring, zone-based watering, and detailed water consumption statistics.
Features
:white_check_mark: Multi-zone irrigation control (up to 5 zones)
:white_check_mark: Flexible configuration - zones 2-5 and water outlets are optional
:white_check_mark: Individual zone timers with adjustable duration
:white_check_mark: Soil moisture monitoring per zone
:white_check_mark: Water consumption statistics with color-coded alerts
:white_check_mark: Automatic/manual modes with winter mode support
:white_check_mark: Expandable/collapsible interface for clean UI
:white_check_mark: Water outlet control with separate timer
:white_check_mark: Smart water usage tracking (daily, weekly, monthly, yearly)
Widget Configuration
The widget uses a flexible parameter system where you can configure only the zones and features you need:
Required Parameters
  • Zone 1: Always required as the primary irrigation zone
  • Automation Control: Switch for automatic irrigation
  • Seeding Mode: Switch for special seeding irrigation mode
  • Winter Mode: Switch to disable irrigation during winter
Optional Parameters (Zones 2-5)
  • Zone X Control: Switch item for zone activation
  • Zone X Moisture: Soil moisture sensor reading
  • Zone X Duration: Timer duration for the zone
Optional Water Outlets
  • Water Outlets Control: Switch for manual water outlets
  • Water Outlets Timer: Duration control for outlets
Optional Water Statistics
  • Water Meter: Total water meter reading
  • Daily/Weekly/Monthly/Yearly: Consumption tracking
  • Daily Average: Average daily consumption with color alerts
uid: widget_irrigation_control_v1
tags: []
props:
  parameters:
    # Required Parameters
    - context: item
      description: Switch for automatic irrigation
      label: Irrigation Automation
      required: true
      type: TEXT
    - context: item
      description: Switch for seeding automation
      label: Seeding Automation
      required: true
      type: TEXT
    - context: item
      description: Switch for winter mode
      label: Winter Mode
      required: true
      type: TEXT
    # Zone 1 (Required)
    - context: item
      description: Switch for Zone 1
      label: Zone 1 Control
      required: true
      type: TEXT
    - context: item
      description: Soil moisture sensor for Zone 1
      label: Zone 1 Soil Moisture
      required: false
      type: TEXT
    - context: item
      description: Zone 1 irrigation duration in minutes
      label: Zone 1 Duration
      required: false
      type: TEXT
    # Zone 2 (Optional)
    - context: item
      description: Switch for Zone 2
      label: Zone 2 Control
      required: false
      type: TEXT
    - context: item
      description: Soil moisture sensor for Zone 2
      label: Zone 2 Soil Moisture
      required: false
      type: TEXT
    - context: item
      description: Zone 2 irrigation duration in minutes
      label: Zone 2 Duration
      required: false
      type: TEXT
    # Zone 3 (Optional)
    - context: item
      description: Switch for Zone 3
      label: Zone 3 Control
      required: false
      type: TEXT
    - context: item
      description: Soil moisture sensor for Zone 3
      label: Zone 3 Soil Moisture
      required: false
      type: TEXT
    - context: item
      description: Zone 3 irrigation duration in minutes
      label: Zone 3 Duration
      required: false
      type: TEXT
    # Zone 4 (Optional)
    - context: item
      description: Switch for Zone 4
      label: Zone 4 Control
      required: false
      type: TEXT
    - context: item
      description: Soil moisture sensor for Zone 4
      label: Zone 4 Soil Moisture
      required: false
      type: TEXT
    - context: item
      description: Zone 4 irrigation duration in minutes
      label: Zone 4 Duration
      required: false
      type: TEXT
    # Zone 5 (Optional)
    - context: item
      description: Switch for Zone 5
      label: Zone 5 Control
      required: false
      type: TEXT
    - context: item
      description: Soil moisture sensor for Zone 5
      label: Zone 5 Soil Moisture
      required: false
      type: TEXT
    - context: item
      description: Zone 5 irrigation duration in minutes
      label: Zone 5 Duration
      required: false
      type: TEXT
    # Water Outlets (Optional)
    - context: item
      description: Switch for water outlets
      label: Water Outlets Control
      required: false
      type: TEXT
    - context: item
      description: Water outlets timer in minutes
      label: Water Outlets Timer
      required: false
      type: TEXT
    # Water Statistics (Optional)
    - context: item
      description: Garden water meter total reading
      label: Water Meter
      required: false
      type: TEXT
    - context: item
      description: Garden water consumption today
      label: Water Today
      required: false
      type: TEXT
    - context: item
      description: Garden water consumption yesterday
      label: Water Yesterday
      required: false
      type: TEXT
    - context: item
      description: Garden water consumption this week
      label: Water This Week
      required: false
      type: TEXT
    - context: item
      description: Garden water consumption this month
      label: Water This Month
      required: false
      type: TEXT
    - context: item
      description: Garden water consumption this year
      label: Water This Year
      required: false
      type: TEXT
    - context: item
      description: Garden water daily average consumption
      label: Water Daily Average
      required: false
      type: TEXT
timestamp: Aug 2, 2025, 9:00:00 PM
component: f7-card
  noBorder: true
  noShadow: true
  style:
    --f7-list-item-border-color: transparent
    margin-left: 5px
    margin-right: 5px
slots:
  default:
    - component: f7-card-content
      slots:
        default:
          - component: f7-row
              class:
                - display-flex
                - justify-content-space-between
                - align-items-center
              style:
                margin-bottom: "=vars.expandedIrrigation === 'true' ? '10px' : '0px'"
                margin-top: -5px
                padding: "=vars.expandedIrrigation === 'true' ? '0px 16px 8px 16px' : '0px 16px 25px 16px'"
            slots:
              default:
                - component: f7-col
                    width: 60
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 18px
                            font-weight: bold
                          text: 🌱 Irrigation
                - component: f7-col
                    style:
                      text-align: center
                    width: 25
                  slots:
                    default:
                      - component: f7-icon
                          f7: drop_fill
                          style:
                            color: "#2196F3"
                          visible: =((props.zone1_control_item && items[props.zone1_control_item].state === 'ON') ||
                            (props.zone2_control_item && items[props.zone2_control_item].state === 'ON') ||
                            (props.zone3_control_item && items[props.zone3_control_item].state === 'ON') ||
                            (props.zone4_control_item && items[props.zone4_control_item].state === 'ON') ||
                            (props.zone5_control_item && items[props.zone5_control_item].state === 'ON') ||
                            (props.water_outlets_control_item && items[props.water_outlets_control_item].state === 'ON'))
                - component: f7-col
                    style:
                      text-align: right
                    width: 15
                  slots:
                    default:
                      - component: oh-button
                          action: variable
                          actionVariable: expandedIrrigation
                          actionVariableValue: "=vars.expandedIrrigation === 'true' ? 'false' : 'true'"
                          style:
                            --f7-button-bg-color: transparent
                            --f7-button-border-radius: 50%
                            --f7-button-height: 30px
                            --f7-button-width: 30px
                            align-items: center
                            display: flex
                            height: 30px
                            justify-content: center
                            min-height: 30px
                            width: 30px
                        slots:
                          default:
                                f7: "=vars.expandedIrrigation === 'true' ? 'chevron_up' : 'chevron_down'"
                                style:
                                  color: "#666"
          - component: f7-block
              style:
                height: "=vars.expandedIrrigation === 'true' ? 'auto' : '0px'"
                opacity: "=vars.expandedIrrigation === 'true' ? '1' : '0'"
                overflow: hidden
                padding: "=vars.expandedIrrigation === 'true' ? '10px' : '0px'"
                transition: all 0.3s ease
            slots:
              default:
                # Zone 1 (Always visible)
                - component: Label
                    style:
                      color: "#333"
                      font-size: 14px
                      font-weight: bold
                      margin-bottom: 5px
                      margin-top: 15px
                    text: "=(props.zone1_moisture_item) ? ('Zone 1: Main Lawn Area ' + items[props.zone1_moisture_item].state + '%') : 'Zone 1: Main Lawn Area'"
                - component: f7-row
                    style:
                      margin-bottom: 15px
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: center
                          width: 30
                        slots:
                          default:
                                action: command
                                actionCommand: "=(props.zone1_control_item && items[props.zone1_control_item].state === 'ON') ? 'OFF' : 'ON'"
                                actionItem: =props.zone1_control_item
                                style:
                                  --f7-button-bg-color: "=(props.zone1_control_item && items[props.zone1_control_item].state === 'ON') ? '#2196F3' : 'rgba(224,224,224,0.8)'"
                                  --f7-button-border-radius: 8px
                                  --f7-button-height: 50px
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 50px
                                  min-height: 50px
                                  width: 100%
                              slots:
                                default:
                                  - component: oh-icon
                                      color: "=(props.zone1_control_item && items[props.zone1_control_item].state === 'ON') ? 'white' : '#666'"
                                      height: 24
                                      icon: classic:mp-rotator
                                      width: 24
                      - component: f7-col
                          width: 45
                      - component: f7-col
                          style:
                            text-align: center
                          width: 25
                        slots:
                          default:
                            - component: f7-chip
                                style:
                                  background: "=(props.zone1_control_item && items[props.zone1_control_item].state === 'ON') ? '#2196F3' : '#90A4AE'"
                                  color: white
                                  font-size: 14px
                                  font-weight: bold
                                  margin-top: 12px
                                text: "=(props.zone1_duration_item) ? (items[props.zone1_duration_item].state + ' min') : '20 min'"
                # Zone 2 (Conditional)
                - component: Label
                    style:
                      color: "#333"
                      font-size: 14px
                      font-weight: bold
                      margin-bottom: 5px
                      margin-top: 15px
                    text: "=(props.zone2_moisture_item) ? ('Zone 2: Upper Slope ' + items[props.zone2_moisture_item].state + '%') : 'Zone 2: Upper Slope'"
                    visible: =props.zone2_control_item ? true : false
                - component: f7-row
                    style:
                      margin-bottom: 15px
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: center
                          width: 30
                        slots:
                          default:
                                action: command
                                actionCommand: "=(props.zone2_control_item && items[props.zone2_control_item].state === 'ON') ? 'OFF' : 'ON'"
                                actionItem: =props.zone2_control_item
                                style:
                                  --f7-button-bg-color: "=(props.zone2_control_item && items[props.zone2_control_item].state === 'ON') ? '#2196F3' : 'rgba(224,224,224,0.8)'"
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 50px
                                  min-height: 50px
                                  width: 100%
                              slots:
                                default:
                                      color: "=(props.zone2_control_item && items[props.zone2_control_item].state === 'ON') ? 'white' : '#666'"
                                      height: 24
                                      width: 24
                      - component: f7-col
                          width: 45
                      - component: f7-col
                          style:
                            text-align: center
                          width: 25
                        slots:
                          default:
                                style:
                                  background: "=(props.zone2_control_item && items[props.zone2_control_item].state === 'ON') ? '#2196F3' : '#90A4AE'"
                                  color: white
                                  font-size: 14px
                                  font-weight: bold
                                  margin-top: 12px
                                text: "=(props.zone2_duration_item) ? (items[props.zone2_duration_item].state + ' min') : '20 min'"
                # Zone 3 (Conditional)
                - component: Label
                    style:
                      color: "#333"
                      font-size: 14px
                      font-weight: bold
                      margin-bottom: 5px
                      margin-top: 15px
                    text: "=(props.zone3_moisture_item) ? ('Zone 3: Middle Lawn Area ' + items[props.zone3_moisture_item].state + '%') : 'Zone 3: Middle Lawn Area'"
                    visible: =props.zone3_control_item ? true : false
                - component: f7-row
                    style:
                      margin-bottom: 15px
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: center
                          width: 30
                        slots:
                          default:
                                action: command
                                actionCommand: "=(props.zone3_control_item && items[props.zone3_control_item].state === 'ON') ? 'OFF' : 'ON'"
                                actionItem: =props.zone3_control_item
                                style:
                                  --f7-button-bg-color: "=(props.zone3_control_item && items[props.zone3_control_item].state === 'ON') ? '#2196F3' : 'rgba(224,224,224,0.8)'"
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 50px
                                  min-height: 50px
                                  width: 100%
                              slots:
                                default:
                                      color: "=(props.zone3_control_item && items[props.zone3_control_item].state === 'ON') ? 'white' : '#666'"
                                      height: 24
                                      width: 24
                      - component: f7-col
                          width: 45
                      - component: f7-col
                          style:
                            text-align: center
                          width: 25
                        slots:
                          default:
                                style:
                                  background: "=(props.zone3_control_item && items[props.zone3_control_item].state === 'ON') ? '#2196F3' : '#90A4AE'"
                                  color: white
                                  font-size: 14px
                                  font-weight: bold
                                  margin-top: 12px
                                text: "=(props.zone3_duration_item) ? (items[props.zone3_duration_item].state + ' min') : '20 min'"
                # Zone 4 (Conditional)
                - component: Label
                    style:
                      color: "#333"
                      font-size: 14px
                      font-weight: bold
                      margin-bottom: 5px
                      margin-top: 15px
                    text: "=(props.zone4_moisture_item) ? ('Zone 4: Lower Slope ' + items[props.zone4_moisture_item].state + '%') : 'Zone 4: Lower Slope'"
                    visible: =props.zone4_control_item ? true : false
                - component: f7-row
                    style:
                      margin-bottom: 15px
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: center
                          width: 30
                        slots:
                          default:
                                action: command
                                actionCommand: "=(props.zone4_control_item && items[props.zone4_control_item].state === 'ON') ? 'OFF' : 'ON'"
                                actionItem: =props.zone4_control_item
                                style:
                                  --f7-button-bg-color: "=(props.zone4_control_item && items[props.zone4_control_item].state === 'ON') ? '#2196F3' : 'rgba(224,224,224,0.8)'"
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 50px
                                  min-height: 50px
                                  width: 100%
                              slots:
                                default:
                                      color: "=(props.zone4_control_item && items[props.zone4_control_item].state === 'ON') ? 'white' : '#666'"
                                      height: 24
                                      width: 24
                      - component: f7-col
                          width: 45
                      - component: f7-col
                          style:
                            text-align: center
                          width: 25
                        slots:
                          default:
                                style:
                                  background: "=(props.zone4_control_item && items[props.zone4_control_item].state === 'ON') ? '#2196F3' : '#90A4AE'"
                                  color: white
                                  font-size: 14px
                                  font-weight: bold
                                  margin-top: 12px
                                text: "=(props.zone4_duration_item) ? (items[props.zone4_duration_item].state + ' min') : '20 min'"
                # Zone 5 (Conditional)
                - component: Label
                    style:
                      color: "#333"
                      font-size: 14px
                      font-weight: bold
                      margin-bottom: 5px
                      margin-top: 15px
                    text: "=(props.zone5_moisture_item) ? ('Zone 5: Lower Lawn Area ' + items[props.zone5_moisture_item].state + '%') : 'Zone 5: Lower Lawn Area'"
                    visible: =props.zone5_control_item ? true : false
                - component: f7-row
                    style:
                      margin-bottom: 15px
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: center
                          width: 30
                        slots:
                          default:
                                action: command
                                actionCommand: "=(props.zone5_control_item && items[props.zone5_control_item].state === 'ON') ? 'OFF' : 'ON'"
                                actionItem: =props.zone5_control_item
                                style:
                                  --f7-button-bg-color: "=(props.zone5_control_item && items[props.zone5_control_item].state === 'ON') ? '#2196F3' : 'rgba(224,224,224,0.8)'"
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 50px
                                  min-height: 50px
                                  width: 100%
                              slots:
                                default:
                                      color: "=(props.zone5_control_item && items[props.zone5_control_item].state === 'ON') ? 'white' : '#666'"
                                      height: 24
                                      width: 24
                      - component: f7-col
                          width: 45
                      - component: f7-col
                          style:
                            text-align: center
                          width: 25
                        slots:
                          default:
                                style:
                                  background: "=(props.zone5_control_item && items[props.zone5_control_item].state === 'ON') ? '#2196F3' : '#90A4AE'"
                                  color: white
                                  font-size: 14px
                                  font-weight: bold
                                  margin-top: 12px
                                text: "=(props.zone5_duration_item) ? (items[props.zone5_duration_item].state + ' min') : '20 min'"
                # Water Outlets (Conditional)
                - component: Label
                    style:
                      color: "#333"
                      font-size: 14px
                      font-weight: bold
                      margin-bottom: 5px
                      margin-top: 15px
                    text: 🚰 Water Outlets
                    visible: =props.water_outlets_control_item ? true : false
                - component: f7-row
                    style:
                      margin-bottom: 15px
                  slots:
                    default:
                      - component: f7-col
                          style:
                            text-align: center
                          width: 30
                        slots:
                          default:
                                action: command
                                actionCommand: "=(props.water_outlets_control_item && items[props.water_outlets_control_item].state === 'ON') ? 'OFF' : 'ON'"
                                actionItem: =props.water_outlets_control_item
                                style:
                                  --f7-button-bg-color: "=(props.water_outlets_control_item && items[props.water_outlets_control_item].state === 'ON') ? '#2196F3' : 'rgba(224,224,224,0.8)'"
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 50px
                                  min-height: 50px
                                  width: 100%
                              slots:
                                default:
                                      color: "=(props.water_outlets_control_item && items[props.water_outlets_control_item].state === 'ON') ? 'white' : '#666'"
                                      height: 24
                                      icon: faucet
                                      width: 24
                      - component: f7-col
                          width: 45
                      - component: f7-col
                          style:
                            text-align: center
                          width: 25
                        slots:
                          default:
                                style:
                                  background: "=(props.water_outlets_control_item && items[props.water_outlets_control_item].state === 'ON') ? '#2196F3' : '#90A4AE'"
                                  color: white
                                  font-size: 14px
                                  font-weight: bold
                                  margin-top: 12px
                                text: "=(props.water_outlets_timer_item) ? (items[props.water_outlets_timer_item].state + ' min') : '30 min'"
                # Control Buttons Row
                - component: f7-row
                    style:
                      align-items: center
                      display: flex
                      flex-direction: row
                      justify-content: space-around
                      margin-top: 20px
                  slots:
                    default:
                      - component: f7-col
                          width: 30
                        slots:
                          default:
                            - component: oh-link
                                action: popover
                                popoverOpen: "#irrigationSettings"
                                style:
                                  align-items: center
                                  background: rgba(33, 150, 243, 0.1)
                                  border-radius: 8px
                                  display: flex
                                  height: 40px
                                  text-decoration: none
                                  width: 100%
                              slots:
                                default:
                                      f7: gear
                                      style:
                                        color: "#2196F3"
                                        font-size: 20px
                      - component: f7-col
                          width: 30
                        slots:
                          default:
                                action: popover
                                popoverOpen: "#timerSettings"
                                style:
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 40px
                                  width: 100%
                              slots:
                                default:
                                      f7: timer
                                      style:
                                        color: "#2196F3"
                                        font-size: 20px
                      - component: f7-col
                          width: 30
                          visible: =props.garden_water_meter_item ? true : false
                        slots:
                          default:
                                action: popover
                                popoverOpen: "#waterStatistics"
                                style:
                                  align-items: center
                                  border-radius: 8px
                                  display: flex
                                  height: 40px
                                  width: 100%
                              slots:
                                default:
                                      f7: drop
                                      style:
                                        color: "#2196F3"
                                        font-size: 20px
    # Settings Popover
    - component: f7-popover
        closeByBackdropClick: true
        closeByOutsideClick: true
        closeOnEscape: true
        style:
          height: 400px
          width: 300px
      slots:
        default:
              style:
                align-items: center
                display: flex
                flex-direction: column
                height: 100%
                justify-content: flex-start
                margin: 0
                padding: 20px 16px
            slots:
              default:
                - component: Label
                    style:
                      font-size: 18px
                      font-weight: bold
                      margin-bottom: 20px
                      text-align: center
                    text: ⚙️ Settings
                    style:
                      width: 100%
                  slots:
                    default:
                      - component: f7-list
                          style:
                            margin: 0
                        slots:
                          default:
                            - component: f7-list-item
                                title: Irrigation Automation
                              slots:
                                after:
                                  - component: oh-toggle
                                      item: =props.irrigation_auto_item
                                title: Seeding Automation
                              slots:
                                after:
                                      item: =props.seeding_auto_item
                                title: Winter Mode
                              slots:
                                after:
                                      item: =props.winter_mode_item
    # Timer Settings Popover
        closeOnEscape: true
        style:
          height: 500px
          width: 350px
      slots:
        default:
              style:
                align-items: center
                display: flex
                height: 100%
                margin: 0
                padding: 15px 16px
            slots:
              default:
                # Zone 1 Timer
                    style:
                      margin-bottom: 8px
                      margin-top: 0px
                      width: 100%
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 14px
                            margin-bottom: 3px
                          text: "Zone 1: Main Lawn Area"
                      - component: f7-row
                          style:
                            align-items: center
                        slots:
                          default:
                            - component: f7-col
                                width: 70
                              slots:
                                default:
                                  - component: oh-slider
                                      item: =props.zone1_duration_item
                                      max: 30
                                      min: 1
                                      step: 1
                                      style:
                                        --f7-range-bar-active-bg-color: "#FF9800"
                                        --f7-range-bar-bg-color: rgba(0,0,0,0.15)
                                        --f7-range-bar-border-radius: 8px
                                        --f7-range-bar-size: 25px
                                        --f7-range-knob-color: "#333333"
                                        --f7-range-knob-size: 18px
                                        height: 25px
                                        width: 100%
                            - component: f7-col
                                style:
                                  text-align: center
                                width: 30
                              slots:
                                default:
                                      style:
                                        background: "#FF9800"
                                        color: white
                                        font-size: 11px
                                        font-weight: bold
                # Zone 2 Timer (Conditional)
                    style:
                      margin-bottom: 8px
                      margin-top: 0px
                      width: 100%
                    visible: =props.zone2_duration_item ? true : false
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 14px
                            margin-bottom: 3px
                          text: "Zone 2: Upper Slope"
                      - component: f7-row
                          style:
                            align-items: center
                        slots:
                          default:
                            - component: f7-col
                                width: 70
                              slots:
                                default:
                                      item: =props.zone2_duration_item
                                      max: 30
                                      min: 1
                                      step: 1
                                      style:
                                        height: 25px
                                        width: 100%
                            - component: f7-col
                                style:
                                  text-align: center
                                width: 30
                              slots:
                                default:
                                      style:
                                        color: white
                                        font-size: 11px
                                        font-weight: bold
                # Zone 3 Timer (Conditional)
                    style:
                      margin-bottom: 8px
                      margin-top: 0px
                      width: 100%
                    visible: =props.zone3_duration_item ? true : false
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 14px
                            margin-bottom: 3px
                          text: "Zone 3: Middle Lawn Area"
                      - component: f7-row
                          style:
                            align-items: center
                        slots:
                          default:
                            - component: f7-col
                                width: 70
                              slots:
                                default:
                                      item: =props.zone3_duration_item
                                      max: 30
                                      min: 1
                                      step: 1
                                      style:
                                        height: 25px
                                        width: 100%
                            - component: f7-col
                                style:
                                  text-align: center
                                width: 30
                              slots:
                                default:
                                      style:
                                        color: white
                                        font-size: 11px
                                        font-weight: bold
                # Zone 4 Timer (Conditional)
                    style:
                      margin-bottom: 8px
                      margin-top: 0px
                      width: 100%
                    visible: =props.zone4_duration_item ? true : false
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 14px
                            margin-bottom: 3px
                          text: "Zone 4: Lower Slope"
                      - component: f7-row
                          style:
                            align-items: center
                        slots:
                          default:
                            - component: f7-col
                                width: 70
                              slots:
                                default:
                                      item: =props.zone4_duration_item
                                      max: 30
                                      min: 1
                                      step: 1
                                      style:
                                        height: 25px
                                        width: 100%
                            - component: f7-col
                                style:
                                  text-align: center
                                width: 30
                              slots:
                                default:
                                      style:
                                        color: white
                                        font-size: 11px
                                        font-weight: bold
                # Zone 5 Timer (Conditional)
                    style:
                      margin-bottom: 8px
                      margin-top: 0px
                      width: 100%
                    visible: =props.zone5_duration_item ? true : false
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 14px
                            margin-bottom: 3px
                          text: "Zone 5: Lower Lawn Area"
                      - component: f7-row
                          style:
                            align-items: center
                        slots:
                          default:
                            - component: f7-col
                                width: 70
                              slots:
                                default:
                                      item: =props.zone5_duration_item
                                      max: 30
                                      min: 1
                                      step: 1
                                      style:
                                        height: 25px
                                        width: 100%
                            - component: f7-col
                                style:
                                  text-align: center
                                width: 30
                              slots:
                                default:
                                      style:
                                        color: white
                                        font-size: 11px
                                        font-weight: bold
                # Water Outlets Timer (Conditional)
                    style:
                      margin-bottom: 8px
                      margin-top: 0px
                      width: 100%
                    visible: =props.water_outlets_timer_item ? true : false
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 14px
                            margin-bottom: 3px
                      - component: f7-row
                          style:
                            align-items: center
                        slots:
                          default:
                            - component: f7-col
                                width: 70
                              slots:
                                default:
                                      item: =props.water_outlets_timer_item
                                      max: 120
                                      min: 5
                                      step: 5
                                      style:
                                        height: 25px
                                        width: 100%
                            - component: f7-col
                                style:
                                  text-align: center
                                width: 30
                              slots:
                                default:
                                      style:
                                        color: white
                                        font-size: 11px
                                        font-weight: bold
    # Water Statistics Popover (Conditional)
        closeOnEscape: true
        style:
          height: 450px
          width: 350px
      slots:
        default:
              style:
                align-items: center
                display: flex
                height: 100%
                margin: 0
                padding: 15px 16px
            slots:
              default:
                - component: Label
                    style:
                      font-size: 18px
                      font-weight: bold
                      margin-bottom: 15px
                      text-align: center
                    text: 🚰 Garden Water Statistics
                    content: false
                    noBorder: true
                    noShadow: true
                    outline: false
                    style:
                      width: 100%
                  slots:
                    default:
                          noHairlines: true
                          noHairlinesBetween: true
                          style:
                            margin: 0
                        slots:
                          default:
                            - component: oh-list-item
                                after: "=(props.garden_water_meter_item) ? (items[props.garden_water_meter_item].displayState || items[props.garden_water_meter_item].state) : 'N/A'"
                                style:
                                  font-size: 14px
                                title: Meter Reading
                                after: "=(props.garden_water_today_item) ? (items[props.garden_water_today_item].displayState || items[props.garden_water_today_item].state) : 'N/A'"
                                color: "=(props.garden_water_today_item && items[props.garden_water_today_item].state > 200) ? 'red' : (props.garden_water_today_item && items[props.garden_water_today_item].state > 150) ? 'orange' : 'green'"
                                style:
                                  font-size: 14px
                                title: Today
                                visible: =props.garden_water_today_item ? true : false
                                after: "=(props.garden_water_yesterday_item) ? (items[props.garden_water_yesterday_item].displayState || items[props.garden_water_yesterday_item].state) : 'N/A'"
                                style:
                                  font-size: 14px
                                title: Yesterday
                                visible: =props.garden_water_yesterday_item ? true : false
                                after: "=(props.garden_water_week_item) ? (items[props.garden_water_week_item].displayState || items[props.garden_water_week_item].state) : 'N/A'"
                                style:
                                  font-size: 14px
                                title: This Week
                                visible: =props.garden_water_week_item ? true : false
                                after: "=(props.garden_water_month_item) ? (items[props.garden_water_month_item].displayState || items[props.garden_water_month_item].state) : 'N/A'"
                                style:
                                  font-size: 14px
                                title: This Month
                                visible: =props.garden_water_month_item ? true : false
                                after: "=(props.garden_water_year_item) ? (items[props.garden_water_year_item].displayState || items[props.garden_water_year_item].state) : 'N/A'"
                                style:
                                  font-size: 14px
                                title: This Year
                                visible: =props.garden_water_year_item ? true : false
                                after: "=(props.garden_water_daily_avg_item) ? (items[props.garden_water_daily_avg_item].displayState || items[props.garden_water_daily_avg_item].state) : 'N/A'"
                                color: "=(props.garden_water_daily_avg_item && items[props.garden_water_daily_avg_item].state > 150) ? 'red' : (props.garden_water_daily_avg_item && items[props.garden_water_daily_avg_item].state > 120) ? 'orange' : 'green'"
                                style:
                                  font-size: 14px
                                title: Ø Daily Consumption
                                visible: =props.garden_water_daily_avg_item ? true : false
