After deeper look, look like suppose clamp 3 missing from parameter,
Anyway, which should I set the 101/111 parameter value for automatically everything (whole or one clamp) updates every sec?
[edit]
My bad I forgot to set the Association Groups. Now it is work realtime updating.
I still think the parameter limit is wrong from the database, you should able allow over 65535 for parameter 101,102,103.
but luckily I have one clamp so set the value 15 will be fine.
