Hello Team,
So I have zwave binding 1.8.2, latest OH and paired device with Aeon labs zstick2 as device 7. Latest z-stick firmware. Activating the sensor in any fashion does nothing. No Joy!
Getting:
2016-04-01 13:32:23.823 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyUSB0
2016-04-01 13:32:23.823 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 2
2016-04-01 13:32:23.834 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2016-04-01 13:32:23.855 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2016-04-01 13:32:23.858 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2016-04-01 13:32:23.859 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyUSB0
2016-04-01 13:32:24.199 [INFO ] [b.z.i.protocol.ZWaveController] - Serial port is initialized
2016-04-01 13:32:26.747 [INFO ] [.o.b.w.i.s.WeatherJobScheduler] - Starting and scheduling weatherJob-home with interval of 15 minutes
2016-04-01 13:32:27.386 [INFO ] [rialApiGetInitDataMessageClass] - NODE 1: Node found
2016-04-01 13:32:27.387 [INFO ] [rialApiGetInitDataMessageClass] - NODE 7: Node found
2016-04-01 13:32:27.390 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2016-04-01 13:32:27.391 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2016-04-01 13:32:27.391 [INFO ] [rialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2016-04-01 13:32:27.392 [INFO ] [rialApiGetInitDataMessageClass] - # Nodes = 2
2016-04-01 13:32:27.393 [INFO ] [rialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2016
Items:
Contact MailBox "MailBox: [%s]" {zwave="7:command=basic,respond_to_basic=true"}
Contact Tamper "Tamper: [%s]" {zwave="7:command=ALARM"}
Number Battery "Battery: [%d %%]" <contact> {zwave="7:command=BATTERY"}
Sitemap:
Frame label="Mailbox" {
Text item=MailBox
Text item=Tamper
Text item=Battery
What am i doing wrong?
