- Platform information:
- Hardware: RPI3
- OS: raspian jessie
- Java Runtime Environment: 1.8.0_152
- openHAB version: openHAB 2.3.0-1 (Release Build)
I am facing an issue with integrating a AEOTEC water sensor in openhab. I successfully integrated the sensor into openhab and configured the thing successfully. In the z-wave debug log I see events when putting the sensor into water and removing it from the water:
2018-07-17 17:12:59.927 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-07-17 17:12:59.929 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2018-07-17 17:12:59.956 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-07-17 17:12:59.959 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-07-17 17:12:59.964 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class BASIC
2018-07-17 17:12:59.967 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Received Basic Request
2018-07-17 17:12:59.969 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Basic Set sent to the controller will be processed as Basic Report
2018-07-17 17:12:59.972 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Basic report, value = 0xFF
2018-07-17 17:12:59.978 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-07-17 17:12:59.980 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2018-07-17 17:13:09.824 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-07-17 17:13:09.828 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-07-17 17:13:09.838 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class BASIC
2018-07-17 17:13:09.842 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Received Basic Request
2018-07-17 17:13:09.845 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Basic Set sent to the controller will be processed as Basic Report
2018-07-17 17:13:09.849 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Basic report, value = 0x00
2018-07-17 17:13:09.857 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-07-17 17:13:09.862 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
2018-07-17 17:13:09.911 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Application Command Request (ALIVE:DONE)
2018-07-17 17:13:09.915 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 17: Starting initialisation from DONE
2018-07-17 17:13:09.923 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 17: Incoming command class BASIC
2018-07-17 17:13:09.926 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Received Basic Request
2018-07-17 17:13:09.930 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Basic Set sent to the controller will be processed as Basic Report
2018-07-17 17:13:09.932 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 17: Basic report, value = 0x00
2018-07-17 17:13:09.937 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-07-17 17:13:09.940 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
But the connected items do not receive any event. Here is my item configuration in .items file:
Switch Wasser_binary “Wasser Schalter” { channel=“zwave:device:fc7b8887:node17:sensor_binary” }
Switch Flut_binary “Flut Schalter” { channel=“zwave:device:fc7b8887:node17:alarm_flood” }
Here a screenshot of the Thing from paperUI
Does anyone have an idea on what is wrong with my configuration here?
