Ive setup the MQTT event but to stop the issues with a single zwave system and socat/ser2net. So far, its working really well
To do so, I moved the working stick with all the working devices into a new 2.4.0 Stable system with the same Zwave binding as the other system.
All the devices rediscovered and downloaded their XML without an issue except for ONE
ZW111, Aeotec Dimmer of which I have a few in the house. This one is a Firmware 2.3 though, the others are 2.2 firmware. But given the same OH versions and the same Binding it should work.
I tried heals, restarts, copying over the XML from the working system, reinilisation you name it. Wont detect!
Both database entries (up to firmware 2.2 & 2.3+) have been updated since 2.4. The zwave developer has been recommending for some time to update to a later binding since 2.4 is almost a year old.
The latest testing version is 2.5 rc1 and 2.5 stable is scheduled to be released on December 15.
Let me rephrase it. It was working up until 2 days ago when I moved the z stick to a new machine and copied the binding. I’m not making this shit up.
