I’m trying to make sensor working, and I succeeded to some extent. I have all sensors working except for alarm and motion.
I can see alarm triggering in logs, but not changing state of item. My conf is:
Switch Hr_Kitchen_AMS_Alarm “Alarm [%s]” (gH_Kitchen) {channel=“zwave:device:c76af4c3:node5:alarm_general”}
I tried contact, switch and even string items. No luck
Another problem is with motion sensing, it’s not triggering. I thought that sensor may be faulty, but after connecting to Aeon firmware update tool, I’m getting motion triggered. I tried on USB power as well as battery.
I also have another problem, that I cannot change any configuration. I’m waking the device, but configuration changes are not preserved
first thing.
please note that you should use the device with the power source you included it
so.. if you included it USB powererd you should use it by USB .. same for battery.
otherwise the device may not work correct. reinclude if you want to switch power source is recommended.
I have “Send Basic Set CC” in option 5, cannot currently change it to other options from OH2, I will try ozwcp. My conf is exactly the same:
Switch Hr_Kitchen_AMS_Motion “Motion [%s]” (Motion, gH_Kitchen, gH_Motion) {channel=“zwave:device:c76af4c3:node5:sensor_binary”}
2016-10-24 19:49:15.330 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 7: Updating channel state zwave:device:c76af4c3:node7:alarm_general to OFF [OnOffType]
So, alarm is triggered, but channel is set to OFF. Why is that? It should be the other way around
Also, after removing sensor from network, removing it from OH2, including on battery I was able to change configurations, but motion sensor stooped working. I will report any progress I made.
Not necessarily. When you have a look at http://www.cd-jackson.com/index.php/zwave/zwave-device-database/openhab-2-channel-types, you will find the command class alarm_general. First point: It’s defined as a SWITCH. So from my understanding, you have to define your item accordingly (not CONTACT). Second: When the list is reliable, OFF means alarm. Reliable because I had a similar case where the list said OFF=alarm, but chris posted something directly out of the binding code and there it was (as it is more logical) ON=alarm.
