Aeotec Multisensor 6 temperature units doesn't stay set
I see entries like this in the debug log
27-Oct-2018 07:16:45.402 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Application Command Request (ALIVE:DONE)
27-Oct-2018 07:16:45.402 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: resetResendCount initComplete=true isDead=false
27-Oct-2018 07:16:45.403 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
27-Oct-2018 07:16:45.403 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
27-Oct-2018 07:16:45.403 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 2: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
27-Oct-2018 07:16:45.403 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 2: Sensor Type = Temperature(1), Scale = 1
27-Oct-2018 07:16:45.403 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 2: Sensor Value = 67.5
27-Oct-2018 07:16:45.403 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
27-Oct-2018 07:16:45.403 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 67.5
27-Oct-2018 07:16:45.403 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating channel state zwave:device:512:node2:sensor_temperature to 67.5 °F [QuantityType]
27-Oct-2018 07:16:45.404 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Commands processed 1.
Thank you, that did it! I totally missed that I needed to add that information into the items file.
Looks perfectly ok to me :slight_smile:
this thread helped me get my stuff working 2
had the regional location language ect set but item configuration off
thanks for help
Thank you! This solved the issue for me. :slight_smile:
Number:Temperature on my OpenHab 2.4 system causes Basic UI to crash when accessed with a Java null pointer exception. I’ve been trying to solve the occasional jump to Fahrenheit on my Multisensor 6.
Chris
That’s odd. So, if you change the item from Number:Temperature to just Number, Basic UI doesn’t crash?
Can you post the complete item definition, as well as the NullPointerException that was thrown?
That is correct. I reverted to just Number and it no longer crashed. Here’s the log
 tail -f /var/log/openhab2/openhab.log
    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
2019-03-30 10:11:36.023 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2019-03-30 10:11:47.099 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-03-30 10:11:51.606 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2019-03-30 10:11:53.163 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2019-03-30 10:11:53.238 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2019-03-30 10:11:53.256 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2019-03-30 10:11:53.315 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-03-30 10:13:40.734 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Toronto'.
2019-03-30 10:13:40.842 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '43.99823657868967,-79.49491918087007'.
2019-03-30 10:13:40.877 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_CA'.
2019-03-30 10:13:40.886 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SIUnits'.
2019-03-30 10:13:42.169 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-03-30 10:13:43.619 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-03-30 10:15:40.997 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2019-03-30 10:16:30.929 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.rules'
2019-03-30 10:16:31.656 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-03-30 10:16:32.964 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2019-03-30 10:16:35.472 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
2019-03-30 10:16:35.896 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-03-30 10:16:36.295 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-03-30 10:16:36.611 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-03-30 10:16:36.616 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-03-30 10:16:40.404 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.12:8080
2019-03-30 10:16:40.441 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.12:8443
2019-03-30 10:16:43.070 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-03-30 10:16:44.677 [INFO ] [asonictv.internal.PanasonicTVBinding] - TV registered 'master_tv' with IP '192.168.1.134'
2019-03-30 10:16:44.910 [INFO ] [b.core.service.AbstractActiveService] - NetworkUpsTools Refresh Service has been started
2019-03-30 10:16:45.261 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2019-03-30 10:16:48.333 [INFO ] [.smarthome.model.script.DefaultRules] - Restart: Last value was [999999]
2019-03-30 10:17:15.729 [INFO ] [.smarthome.model.script.DefaultRules] - FR Luminance now [17], was [999999]
2019-03-30 10:24:01.947 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /basicui/app
    at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.convertStateToWidgetUnit(ItemUIRegistryImpl.java:431) ~[?:?]
    at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:404) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:121) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.render.TextRenderer.renderWidget(TextRenderer.java:61) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:181) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124) ~[?:?]
    at org.eclipse.smarthome.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:189) ~[?:?]
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[29:javax.servlet-api:3.1.0]
    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[82:org.eclipse.jetty.security:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
    at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
2019-03-30 10:24:28.642 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: org.eclipse.jetty.io.EofException
    at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
    at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [171:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [172:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
    at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
    at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
Caused by: org.eclipse.jetty.io.EofException
    at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.io.WriteFlusher.completeWrite(WriteFlusher.java:384) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.io.ChannelEndPoint$3.run(ChannelEndPoint.java:133) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:295) ~[87:org.eclipse.jetty.util:9.4.11.v20180605]
    ... 6 more
Caused by: java.io.IOException: Broken pipe
    at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
    at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:?]
    at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:?]
    at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:?]
    at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:?]
    at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:264) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
    ... 6 more
^C
Here’s the items file. It was on the first multisensor item.
String System_Mode "State [%s)"
Switch Presence_Mobile_Chris "Chris Galaxy Note 8" <network> { channel="network:pingdevice:36370fe7:online" }
Switch Wallplug_FF_FR_FloorLamp "Family Room Floor Lamp" <switch> { channel="zwave:device:59995961:node2:switch_binary" }
Number Wallplug_FF_FR_FloorLamp_kWh "Family Room Floor Lamp [%.1f kWh]" <energy> { channel="zwave:device:59995961:node2:meter_kwh" }
Number Wallplug_FF_FR_FloorLamp_Voltage "Family Room Floor Lamp [%.1f V]" <energy> { channel="zwave:device:59995961:node2:meter_voltage" }
Number UPS_B_LR_Battery "Main UPS Battery [%d %%]" <energy> { networkupstools="ups1:battery.charge" }
String UPS_B_LR_Status "Main UPS Status [%s]" <energy> { networkupstools="ups1:ups.status" }
Number UPS_B_LR_Voltage "Main UPS Line [%d Volts]" <energy> { networkupstools="ups1:input.voltage" }
Switch Wallplug_FF_LR_DeskLamp "Living Room Desk Lamp" <switch> { channel="zwave:device:59995961:node10:switch_binary" }
Number Wallplug_FF_LR_DeskLamp_kWh "Living Room Desk Lamp [%.1f kWh]" <energy> { channel="zwave:device:59995961:node10:meter_kwh" }
Number Wallplug_FF_LR_DeskLamp_Voltage "Living Room Desk Lamp [%.1f V]" <energy> { channel="zwave:device:59995961:node10:meter_voltage" }
Switch Sensor_FF_FR_Motion "Family Room Motion Sensor" <motion> { channel="zwave:device:59995961:node8:sensor_binary" }
Number Sensor_FF_FR_Humidity "Family Room Humidity [%.0f %%]" <humidity> {channel="zwave:device:59995961:node8:sensor_relhumidity" }
Number Sensor_FF_FR_Luminance "Family Room Luminance [%.1f]" <light> { channel="zwave:device:59995961:node8:sensor_luminance" }
Number Sensor_FF_FR_Temperature "Family Room [%0.1f °C]" <temperature> { channel="zwave:device:59995961:node8:sensor_temperature" }
Switch FF_K_Pendants "Kitchen Pendant Lights" <switch> { channel="zwave:device:59995961:node11:switch_binary" }
Switch Sensor_SF_MBR_Motion "Master Bedroom Motion Sensor" <motion> { channel="zwave:device:59995961:node9:sensor_binary" }
Number Sensor_SF_MBR_Humidity "Master Bedroom Humidity [%.0f %%]" <humidity> {channel="zwave:device:59995961:node9:sensor_relhumidity" }
Number Sensor_SF_MBR_Luminance "Master Bedroom Luminance [%.1f]" <light> { channel="zwave:device:59995961:node9:sensor_luminance" }
Number Sensor_SF_MBR_Temperature "Master Bedroom [%0.1f °C]" <temperature> { channel="zwave:device:59995961:node9:sensor_temperature" }
Switch TV_SF_MBR_Power "Power"                 { panasonictv="master_tv:POWER" }
Switch TV_SF_MBR_VolumeUp "Volume Up"             { panasonictv="master_tv:VOLUP" }
Switch TV_SF_MBR_VolumeDown "Volume Down"           { panasonictv="master_tv:VOLDOWN" }
Switch TV_SF_MBR_Input "TV input"              { panasonictv="master:TV" }
So, this one?
Just to see what happens, could you try changing it to this (drop the 0 before the dot)? I’m not sure at all if this will make a difference, but it’s worth trying just to see if anything different happens.
Number:Temperature Sensor_FF_FR_Temperature "Family Room [%.1f °C]" <temperature> { channel="zwave:device:59995961:node8:sensor_temperature" }
Or possibly this?
Number:Temperature Sensor_FF_FR_Temperature "Family Room [%.1f %unit%]" <temperature> { channel="zwave:device:59995961:node8:sensor_temperature" }
OK I tried the %unit% with the 0.1f and it was the same. I at first thought it was the %unit% that was causing the problem (i.e. perhaps it was null) but changing it back didn’t help, so Temperature was the problem.
I don’t know what to say. I have many items defined exactly like that (example below). The only difference is that there’s no 0 preceding the dot in [%.1f %unit%].
Number:Temperature  WS8482_Garden5SoilTemperature
                    "Garden 5 Soil Temperature [%.1f %unit%]"
                    <temperature>
                    { channel="ambientweather:ws8482:ws8482:remoteSensor5#soilTemperature" }
2019-03-30 17:51:34.474 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
Got a different error now - although I think is from Paper UI maybe. Anyway, neither are crashing completely after changing from 0.1f to .1f but neither are functional. Will restart and see what happens.
OK After a restart I’m back to the null pointer exception and Paper UI is working fine. Just Basic UI is a problem. The Android app is working, but reports that it is 71C in the room I’m sitting in right now. This from the browser (Chrome).
HTTP ERROR 500
Problem accessing /basicui/app. Reason:
    Server Error
Caused by:
java.lang.NullPointerException
	at java.lang.Thread.run(Thread.java:748)
Powered by Jetty:// 9.4.11.v20180605
What are you using for your sitemap?
sitemap default label="Sullivan sitemap"
    Frame label="Occupants" {
        Selection   item=System_Mode label="System Mode" mappings=[0="Home", 1="Asleep", 2="Out", 3="Vacation"]
        Switch      item=Presence_Mobile_Chris label="Chris's Note 8"
    Frame label="Basement" {
        Text   item=UPS_B_LR_Battery label="UPS Battery [%d %%]"
        Text   item=UPS_B_LR_Status label="UPS Status [%s]"
        Text   item=UPS_B_LR_Voltage label="UPS Line [%d V]"
    Frame label="Ground Floor" {
        Switch item=FF_K_Pendants label="Kitchen Pendant Lights"
        Switch item=Wallplug_FF_FR_FloorLamp label="Family Room Floor Lamp"
        Text   item=Wallplug_FF_FR_FloorLamp_Voltage label="Family Room Floor Lamp [%.1f V]"
        Text   item=Wallplug_FF_FR_FloorLamp_kWh label="Family Room Floor Lamp [%.1f kWh]"
        Switch item=Sensor_FF_FR_Motion label="Family Room Motion Sensor"
        Text   item=Sensor_FF_FR_Humidity label="Family Room Humidity [%.1f %%]"
        Text   item=Sensor_FF_FR_Luminance label="Family Room Luminance [%.1f]"
        Text   item=Sensor_FF_FR_Temperature label="Family Room [%.1f C]"
        Switch item=Wallplug_FF_LR_DeskLamp label="Living Room Desk Lamp"
        Text   item=Wallplug_FF_LR_DeskLamp_Voltage label="Living Room Desk Lamp [%.1f V]"
        Text   item=Wallplug_FF_LR_DeskLamp_kWh label="Living Room Desk Lamp [%.1f kWh]"
    Frame label="Second Floor" {
        Switch item=Sensor_SF_MBR_Motion label="Master Bedroom Motion Sensor"
        Text   item=Sensor_SF_MBR_Humidity label="Master Bedroom Humidity [%.1f %%]"
        Text   item=Sensor_SF_MBR_Luminance label="Master Bedroom Luminance [%.1f]"
        Text   item=Sensor_SF_MBR_Temperature label="Master Bedroom [%.1f C]"
        Switch item=TV_SF_MBR_Power label="Master Bedroom TV Power"
Since you have labels in the Items, there’s no need for them in the sitemap. If you choose to continue to use them, [%.1f C] should be [%.1f °C] or [%.1f %unit%]. Using %unit% will use your system settings for the unit. Hopefully that cleans up the error!
Good catch!
That was it. Thank you so much for your help. I had been wondering why I was supposed to replicate labels in the sitemap as it seemed rather tedious. I’ve fixed my mistaken assumption now and it is all good. It even exposed an exception due to the 0.1f which I guess was not showing previously because it was overridden by the sitemap.
I suspect I won’t see any 70C temps in the family room from now on. I can now move forward in my implementation and break something else!
Chris
