Hey there,
I’m very new to OpenHAB and I’m trying to get my Aeotec Multisensor Gen5 to work. I have a Z-Stick S2 as a controller. The network used to work just fine under Home-Assistant.
Here’s what I do:
- I exclude any nodes from the network with the stick
- I plug in the stick
- I use the Z-Wave Binding to bind (?) the Z-Wave-Serial-Controller
- I look up the USB-Port and put it into the Serial Port Input Box
Everything works fine until here. Heres the event.log:
2017-07-05 23:34:46.319 [ItemChannelLinkAddedEvent ] - Link 'zwave_serial_zstick_9caea993_serial_sof-zwave:serial_zstick:9caea993:serial_sof' has been added.
2017-07-05 23:34:46.325 [ItemChannelLinkAddedEvent ] - Link 'zwave_serial_zstick_9caea993_serial_ack-zwave:serial_zstick:9caea993:serial_ack' has been added.
2017-07-05 23:34:47.599 [ItemChannelLinkAddedEvent ] - Link 'zwave_serial_zstick_9caea993_serial_nak-zwave:serial_zstick:9caea993:serial_nak' has been added.
2017-07-05 23:34:48.191 [ItemChannelLinkAddedEvent ] - Link 'zwave_serial_zstick_9caea993_serial_can-zwave:serial_zstick:9caea993:serial_can' has been added.
2017-07-05 23:34:49.473 [ItemChannelLinkAddedEvent ] - Link 'zwave_serial_zstick_9caea993_serial_oof-zwave:serial_zstick:9caea993:serial_oof' has been added.
2017-07-05 23:34:49.519 [ThingAddedEvent ] - Thing 'zwave:serial_zstick:9caea993' has been added.
2017-07-05 23:34:49.645 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9caea993' changed from UNINITIALIZED to INITIALIZING
2017-07-05 23:34:54.677 [ThingUpdatedEvent ] - Thing 'zwave:serial_zstick:9caea993' has been updated.
2017-07-05 23:34:54.684 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:9caea993' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2017-07-05 23:34:57.837 [ItemStateChangedEvent ] - zwave_serial_zstick_9caea993_serial_ack changed from NULL to 1
2017-07-05 23:34:57.841 [ItemStateChangedEvent ] - zwave_serial_zstick_9caea993_serial_sof changed from NULL to 1
2017-07-05 23:34:57.904 [ItemStateChangedEvent ] - zwave_serial_zstick_9caea993_serial_ack changed from 1 to 2
2017-07-05 23:34:57.907 [ItemStateChangedEvent ] - zwave_serial_zstick_9caea993_serial_sof changed from 1 to 2
weirdly, the sofs and acks stop after 10
and here’s the openhab.log
2017-07-05 23:34:54.653 [WARN ] [ome.core.thing.internal.ThingManager] - Initializing handler for thing 'zwave:serial_zstick:9caea993' takes more than 5000ms.
2017-07-05 23:34:54.664 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyUSB0'
2017-07-05 23:34:54.738 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2017-07-05 23:34:54.768 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2017-07-05 23:34:54.795 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2017-07-05 23:34:54.797 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2017-07-05 23:34:58.073 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 1: Node found
2017-07-05 23:34:58.075 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-07-05 23:34:58.076 [INFO ] [age.SerialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-07-05 23:34:58.077 [INFO ] [age.SerialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-07-05 23:34:58.078 [INFO ] [age.SerialApiGetInitDataMessageClass] - # Nodes = 1
2017-07-05 23:34:58.079 [INFO ] [age.SerialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
next:
- i go into my inbox and press the + symbol
- i press the z-wave button on my multisensor
- “unknown device - node 14” shows up, i add it
- it shows up in my list of things, with the proper name (multisensor)
i get the following in my opehab.log:
and this
and in the event.log file, theres no activity from any zwave devices, not even any sofs or acks from the stick..
And when I try updating the configs of the multisensor in the paperUI, i get a 500 - internal server error
In short, I cannot properly control my Z-Wave devices.. Home-Assistant automatically installs the openzwave control panel, but I haven’t been able to get that to work on my own. Is there maybe a good, UP TO DATE tutorial how to install that in openHAB? Or any other way to properly control z-wave?
I’m really thankful for any help I can get. I’m writing my thesis about different open source smart home systems and I’m running out of time haha
Regards
