Hi everyone,
i am trying to get a Aeotec Nano Shutter to work and can’t spot my error. I strongly assume it’s some error on my end, as i dont think these devices ship broken very often … I need four such devices and wanted to test it before ordering all four, so i only got one device to fiddle with.
I am using openhabian with Zwave Binding version 3.4.4.
I have shutters with a separate switch for up and down respectively. The actual switch makes mechanically sure up and down isnt “on” at the same time. They are switches with two states, not some momentary push buttons. Oh and the shutter works with just the normal switch
I wired everything up, connecting out1/out2 with the motor and s1/s2 with the external switch. I included the device in my zwave network (zwave secure), OH finds it, made items etc. - everything looks fine. If i press one of the switches it as the effect of the action button on the aeotec, as it should.
Except the damn shutter won’t move. No matter how i configurate the aeotec, i don’t get any control through to the motor. Not via the aeotec and OH, and not via the original switches. When using OH the best i get is the click of a relay in the aeotec - this is when using the configuration i’d call “correct”.
I read up the documentation, searched some boards but can’t spot my error. I also hard-resetted the aeotec (actually had to do that to integrate it into my network in the first place). I tried alot of different configurations out of desparation, with little to no change to the outcome (i can stop the device from clicking when using an action ). I also tried to somehow initiate calibration, but nothing happens.
My configuration (excerpt):
#20: 0
#22: 0
#85: 1
#120: 1
#121: 1
Does anybody have an idea of what to try? I want to get to the bottom of the problem, but i am out of ideas what to try next that might change anything …
Thanks alot for any hint
