I have an Aeotec ZW096-B09 Smart Switch 6 that seems to persist the same value. I’m expecting the vales to change as the switch is powering a refrigerator that starts, stops and has a light. Here’s my setup:
home.items:
Group power "Power" <power> Switch Smart62 "Smart6 outlet 2" <socket> (ff,ALL,outlet) { zwave="7:command=switch_binary" } Number Smart6_Power2 "Smart6 power 2 [%.2f W]" (ALL,power) { zwave="7:command=meter,meter_scale=E_W" } Number Smart6_Energy2 "Smart6 consumption 2 [%.2f KWh]" (ALL,power) { zwave="7:command=meter,meter_scale=E_KWh" } Number Smart6_Volts2 "Smart6 voltage 2 [%.2f V]" (ALL,power) { zwave="7:command=meter,meter_scale=E_V" } Number Smart6_Amps2 "Smart6 amperage 2 [%.2f A]" (ALL,power) { zwave="7:command=meter,meter_scale=E_A" }
rrd4j.persist
power* : strategy = everyMinute, restoreOnStartup
home.sitemap
Chart item=Smart6_Amps2 service="rrd4j" period=12h
This is the result over a 12hr period on my refrigerator.
I get flat line values if I graph KWh or Watts. I can turn the switch on and off via the sitemap. Any ideas?
openHAB 1.8.3 on RPi2 with Aeotec Z-Stick Gen5
