- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- OS: Raspbian GNU/Linux 8 (jessie)
- Java Runtime Environment: openjdk version 1.8.0_152
- openHAB version: openHAB 2.4.0~20180906111426-1 (Build #1351)
- ZWave binding: 2.4.0.201809060839
Issue of the topic:
I have added my new smartswitch, and I am able to control the power state (on/off) via OpenHab. However my issue is that when turning on / off the load at the switch manually, OH does not see the state change
Items
Switch WashingMachine "Washing Machine" (Basement) {channel="zwave:device:a2cab7b4:node10:switch_binary"}
Number WashingMachineEnergyW "Washing Machine Watts [%.2f W]" (Basement) {channel="zwave:device:a2cab7b4:node10:meter_watts"}
Number WashingMachineEnergyKwh "Washing Machine Energy Use [%.2f KWh]" {channel="zwave:device:a2cab7b4:node10:meter_kwh"}
Number WashingMachineEnergyA "Washing Machine Current [%.2f A]" {channel="zwave:device:a2cab7b4:node10:meter_current"}
Switch WashingMachineEnergyReset "Washing Machine Meter Reset" {channel="zwave:device:a2cab7b4:node10:meter_reset"}
Sitemap
Frame label="Washing Machine"{
Switch item=WashingMachine
Text item=WashingMachineEnergyW
Text item=WashingMachineEnergyKwh
Text item=WashingMachineEnergyA
Switch item=WashingMachineEnergyReset
One thing that I have noticed, but am not sure what it really means, or if it’s related to the issue
in Habmin, the device is shown as “Node initialising: STATIC_VALUES”
Does anyone have any thoughts on what I can do to get this working as expected?
Thanks!
