Aeotec Smart Switch 7 - Unknown Device
Hello:
I am new to OpenHAB(ian), but not to z-wave. I am unable to get OpenHAB to recognize the Aeotec Smart Switch 7 on OpenHAB 3. The Paper UI reports it is an unknown device. Other Z-wave devices have worked fine and were recognized instantly.
The UI says to “raise the issue” of and unrecognized device. Is this the place I do that?
Welcome! This is the place to get help, but there are a few other things you can do first to track down the problem so we can help you better.
  1. If you are in north america, I think the switch 7 is a fairly new version. The first thing to do is check the z-wave database and see if your device (exact model and firmware version) is listed.
If you discover that your device is not listed in the database then you can follow the guide on that site for submitting a new device.
  1. If your device is in the database and still not recognized, then follow the guide in the binding docs to produce debug logs which can help narrow down the problem.
One version if it is here.
But having the xml file can help confirm if that is your exact device. Device IDs vary by world region.
Thanks for the fast responses and helpful information. This is a North American Smart Switch It appears that the Smart Switch 7 in the database has a different ID.
<node>
<homeId>0xf9e687d4</homeId>
<nodeId>4</nodeId>
<version>4</version>
<manufacturer>0x371</manufacturer>
<deviceId>0x17</deviceId>
<deviceType>0x103</deviceType>
<listening>true</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_SWITCH_COLOR</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL</commandClass>
<commandClass>COMMAND_CLASS_CLOCK</commandClass>
<commandClass>COMMAND_CLASS_METER</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
<commandClass>COMMAND_CLASS_SCENE_ACTUATOR_CONF</commandClass>
<commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_SECURITY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<name>Lifeline</name>
<profile1>0x0</profile1>
<profile2>0x1</profile2>
<commands>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
</commands>
<associations>
<associationMember>
<node>1</node>
<endpoint>1</endpoint>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<name>Retransmit</name>
<profile2>0x0</profile2>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<name>Alert</name>
<profile1>0x32</profile1>
<commands>
</commands>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOT_USED</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>2</versionSupported>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>881</deviceManufacturer>
<deviceType>259</deviceType>
<deviceId>23</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__METER>
<version>3</version>
<versionSupported>5</versionSupported>
<meterType>ELECTRIC</meterType>
<meterScales>
<meterScale>E_V</meterScale>
<meterScale>E_KWh</meterScale>
<meterScale>E_W</meterScale>
<meterScale>E_A</meterScale>
</meterScales>
<canReset>true</canReset>
<isGetSupported>true</isGetSupported>
<isSupportRequestSupported>true</isSupportRequestSupported>
</COMMAND__CLASS__METER>
</entry>
<entry>
<COMMAND__CLASS__APPLICATION__STATUS>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__APPLICATION__STATUS>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<version>2</version>
<maxGroups>3</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTIVATION>
</COMMAND__CLASS__SCENE__ACTIVATION>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__COLOR>
<versionSupported>3</versionSupported>
<supportedColors>
<colorType>GREEN</colorType>
<colorType>BLUE</colorType>
<colorType>RED</colorType>
</supportedColors>
<refreshList/>
<colorMap>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
</colorMap>
</COMMAND__CLASS__SWITCH__COLOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__CLOCK>
</COMMAND__CLASS__CLOCK>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups>
<int>1</int>
<int>2</int>
<int>3</int>
</autoSubscribeGroups>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.12</protocolVersion>
<applicationVersion>1.3</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<multiLevelSwitchCommandClass>
<versionSupported>4</versionSupported>
<switchTypePrimary>DOWN_UP</switchTypePrimary>
<switchTypeSecondary>UNDEFINED</switchTypeSecondary>
</multiLevelSwitchCommandClass>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL>
<useDestEndpointAsSource>false</useDestEndpointAsSource>
<endpointsAreTheSameDeviceClass>false</endpointsAreTheSameDeviceClass>
</COMMAND__CLASS__MULTI__CHANNEL>
</entry>
<entry>
<COMMAND__CLASS__BASIC>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>POWER_MANAGEMENT</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__SECURITY>
</COMMAND__CLASS__SECURITY>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</COMMAND__CLASS__SCENE__ACTUATOR__CONF>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__SWITCH__BINARY>
</COMMAND__CLASS__SWITCH__BINARY>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
<entry>
<int>1</int>
<endPoint>
<deviceClass>
</deviceClass>
<endpointId>1</endpointId>
<entry>
<endpoint reference="../../../.."/>
<autoSubscribeGroups/>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<version>0</version>
<instances>0</instances>
<versionSupported>0</versionSupported>
</entry>
<entry>
</entry>
<entry>
<alarms>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
</entry>
<entry>
<meterScales>
</meterScales>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
</endPoint>
</entry>
<entry>
<int>2</int>
<endPoint>
<deviceClass>
<genericDeviceClass>GENERIC_TYPE_SWITCH_MULTILEVEL</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_COLOR_TUNABLE_MULTILEVEL</specificDeviceClass>
</deviceClass>
<endpointId>2</endpointId>
<entry>
</entry>
<entry>
<maxGroups>1</maxGroups>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<supportedColors>
</supportedColors>
<refreshList/>
<colorMap>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
</colorMap>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2021-02-19 22:38:38.549 UTC</lastReceived>
</node>
Here’s a link to the version I’m using: Smart Switch 7
