device: Aeotec TriSensor, Z-Wave Plus S2 Motion, Temperature, Light Sensor, 3-in 1
The current version of this device is ZWA005-A (can it be that being a revision “A” means it is too different?). My openHAB is 2.5.2.
When the zwave binding searched for the device it correctly recognized it and marked it online. However, I couldn’t find any signs in the logs that it was receiving any events from the device. I removed the thing many times, pressed the device button to get the red light and wake it many times. Still there was no sign of events.
I took the battery out of the device, removed the thing, and searched for it again. Then I realized that apparently it was just re-finding it perhaps from a DB entry, not really communicating with the device. I wanted to more thoroughly clear it out so I could re-find it with debug on (though maybe it was already on). I removed the thing and the items and restarted openHAB. Now it doesn’t recognize the device at all. Maybe my logs here are missing the very beginning but if I knew how to reset the device/openHAB in regards to this device then I could get a fresh set.
2020-12-06 16:52:44.149 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Handler disposed. Unregistering listener.
2020-12-06 16:52:44.163 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 18
: Serialise aborted as static stages not complete
2020-12-06 16:52:51.904 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 18
: Device discovery completed
2020-12-06 16:52:51.905 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 18
: Device discovery resolved to thingType zwave:aeotec_zwa005_00_000
2020-12-06 16:54:41.424 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Controller status changed to ONLINE.
2020-12-06 16:54:41.425 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Controller is ONLINE. Starting device initialisation.
2020-12-06 16:54:41.429 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Channel zwave:device:af4338b8:node18:sensor_temperature linked - polling start
ed.
2020-12-06 16:54:41.430 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Channel zwave:device:af4338b8:node18:sensor_luminance linked - polling started
: Channel zwave:device:af4338b8:node18:alarm_motion linked - polling started.
: Updating node properties.
2020-12-06 16:54:41.432 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Updating node properties. MAN=881
: Updating node properties. MAN=881. SET. Was 881
2020-12-06 16:54:41.433 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Properties synchronised
2020-12-06 16:54:41.435 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Configuration synchronised
2020-12-06 16:54:41.440 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Initialising Thing Node…
2020-12-06 16:54:41.441 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Initialising cmd channel zwave:device:af4338b8:node18:sensor_temperature for Q
uantityType
: Initialising state channel zwave:device:af4338b8:node18:sensor_temperature for
QuantityType
2020-12-06 16:54:41.442 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Initialising cmd channel zwave:device:af4338b8:node18:sensor_luminance for Dec
imalType
: Initialising state channel zwave:device:af4338b8:node18:sensor_luminance for D
ecimalType
ecimalType
2020-12-06 16:54:41.443 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Initialising cmd channel zwave:device:af4338b8:node18:alarm_motion for OnOffTy
pe
: Initialising state channel zwave:device:af4338b8:node18:alarm_motion for OnOff
Type
2020-12-06 16:54:41.444 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Initialising cmd channel zwave:device:af4338b8:node18:battery-level for Percen
tType
2020-12-06 16:54:41.445 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18
: Initialising state channel zwave:device:af4338b8:node18:battery-level for Perc
entType
2020-12-08 08:45:05.630 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=IdentifyNode[65], type=Response[1], dest=255, callback=0, payload=53 9C 01 04 07 01
2020-12-08 08:45:05.630 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: ProtocolInfo
2020-12-08 08:45:05.631 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Listening = false
2020-12-08 08:45:05.631 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Routing = true
2020-12-08 08:45:05.632 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Beaming = true
2020-12-08 08:45:05.632 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Version = 4
2020-12-08 08:45:05.632 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: FLIRS = false
2020-12-08 08:45:05.633 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Security = false
2020-12-08 08:45:05.633 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Max Baud = 40000
2020-12-08 08:45:05.634 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Basic = BASIC_TYPE_ROUTING_SLAVE
2020-12-08 08:45:05.634 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Generic = GENERIC_TYPE_SENSOR_NOTIFICATION
2020-12-08 08:45:05.635 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 18: Specific = SPECIFIC_TYPE_NOTIFICATION_SENSOR
2020-12-08 08:45:05.648 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 18: Creating new instance of command class COMMAND_CLASS_NO_OPERATION
2020-12-08 08:45:05.652 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 18: Command class COMMAND_CLASS_NO_OPERATION, endpoint 0 created
2020-12-08 08:45:05.652 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 18: Version = 1, version set. Enabling extra functionality.
2020-12-08 08:45:05.653 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 18: Adding command class COMMAND_CLASS_NO_OPERATION to the list of supported command classes.
2020-12-08 08:45:08.810 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Device initialisation complete.
but now when I delete the thing and search I just get:
2020-12-08 21:35:47.795 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 1 : Serialise aborted as static stages not complete
2020-12-08 21:35:58.214 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 1 : Device discovery completed
2020-12-08 21:35:58.216 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 1 : Device discovery could not resolve to a thingType! Manufacturer data not known.
and it remains Unknown, even if I try to press the device for the 15s to get a reset blinking red light.
