Latest OH4.1 I believe as I just did a new install and updates last month.
I have the power monitor and everything works fine, it updates every 20 seconds or so which is fine, I have a really odd power setup at my house because it’s been upgraded with 3 additions over the years. So I have 5 electrical panels, and also a solar array, but finally found where to put on the main 225A breaker switch so it reads positive when using power and negative when the solar is providing more than is being used.
My problem is I just realized it’s always reading double for AMPs only. Watts are correct.
For example it was sitting at 15A usage roughly and around 1750W. So 15 * 120 is 1800, makes sense. Wasn’t running much in the house but a 15A constant draw doesn’t seem crazy with some lights and TVs.
Now I turn on the electric car charger. It peaks at 48A 240V, but usually runs at 40A.
The device instantly spikes to 91A, but it should be showing something like 15+40 or 55. Watts show around 11,000 which makes sense.
Is the A thing not able to understand the difference between 120 and 240V items and only W would be a correct reading?
