Here’s a snippet from the log file as the zwave binding was starting up. I wasn’t sure how much you needed. If this isn’t enough just let me know and I can send you a longer file. Let me know if there’s anything more you need, and most of all - thanks for your help.
2018-10-01 16:49:27.276 [DEBUG] [inding.zwave.internal.ZWaveActivator] - Z-Wave binding started. Version 2.3.0
2018-10-01 16:49:27.277 [DEBUG] [org.openhab.binding.zwave ] - BundleEvent STARTED - org.openhab.binding.zwave
2018-10-01 16:49:27.282 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.events.EventFactory}={service.id=462, service.bundleid=219, service.scope=bundle, component.name=org.openhab.binding.zwave.event.BindingEventFactory, component.id=269} - org.openhab.binding.zwave
2018-10-01 16:49:27.284 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=463, service.bundleid=219, service.scope=bundle, component.name=org.openhab.binding.zwave.internal.ZWaveHandlerFactory, component.id=270} - org.openhab.binding.zwave
2018-10-01 16:49:27.286 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.ConfigOptionProvider, org.eclipse.smarthome.config.core.ConfigDescriptionProvider}={service.id=464, service.bundleid=219, service.scope=bundle, component.name=org.openhab.binding.zwave.ConfigDescription, component.id=271} - org.openhab.binding.zwave
2018-10-01 16:49:27.557 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2018-10-01 16:49:27.558 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller.
2018-10-01 16:49:27.559 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/tty-zstick’
2018-10-01 16:49:27.563 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=467, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.563 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=465, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.563 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=468, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.563 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=466, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.563 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=469, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.565 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Starting receive thread
2018-10-01 16:49:27.565 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2018-10-01 16:49:27.565 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Starting ZWave thread: Receive
2018-10-01 16:49:27.566 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initialising ZWave controller
2018-10-01 16:49:27.566 [INFO ] [mmandclass.ZWaveSecurityCommandClass] - Update networkKey
2018-10-01 16:49:27.566 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.566 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2018-10-01 16:49:27.566 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2018-10-01 16:49:27.566 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=470, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.567 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=471, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.568 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
2018-10-01 16:49:27.568 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Activating ZWave discovery service for zwave:serial_zstick:9d9a0120
2018-10-01 16:49:27.568 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Starting ZWave thread: Send
2018-10-01 16:49:27.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Starting ZWave thread: Input
2018-10-01 16:49:27.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-10-01 16:49:27.568 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
2018-10-01 16:49:27.568 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=472, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
2018-10-01 16:49:27.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-10-01 16:49:27.568 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 11: Command received zwave:device:9d9a0120:node11:switch_binary --> REFRESH
2018-10-01 16:49:27.568 [WARN ] [ssage.ApplicationCommandMessageClass] - NODE 5: Not initialized yet, ignoring message.
2018-10-01 16:49:27.568 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.569 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=473, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.576 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.577 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Command received zwave:device:9d9a0120:node5:switch_binary --> REFRESH
2018-10-01 16:49:27.578 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.578 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=474, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.579 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.580 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=475, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.580 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.580 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=476, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.581 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Command received zwave:device:9d9a0120:node6:switch_binary --> REFRESH
2018-10-01 16:49:27.581 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.581 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.584 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.585 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.585 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=477, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.585 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=478, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.586 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=479, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.586 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.587 [DEBUG] [org.openhab.binding.zwave ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.core.status.ConfigStatusProvider}={service.id=480, service.bundleid=219, service.scope=singleton} - org.openhab.binding.zwave
2018-10-01 16:49:27.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 9: Command received zwave:device:9d9a0120:node9:switch_binary --> REFRESH
2018-10-01 16:49:27.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.587 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 8: Command received zwave:device:9d9a0120:node8:switch_binary --> REFRESH
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 10: Command received zwave:device:9d9a0120:node10:switch_binary --> REFRESH
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Command received zwave:device:9d9a0120:node14:blinds_control --> REFRESH
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Command received zwave:device:9d9a0120:node17:alarm_motion --> REFRESH
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Command received zwave:device:9d9a0120:node17:sensor_luminance --> REFRESH
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Command received zwave:device:9d9a0120:node17:sensor_temperature --> REFRESH
2018-10-01 16:49:27.589 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Command received zwave:device:9d9a0120:node13:sensor_temperature --> REFRESH
2018-10-01 16:49:27.589 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Command received zwave:device:9d9a0120:node13:alarm_motion --> REFRESH
2018-10-01 16:49:27.588 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 17: Command received zwave:device:9d9a0120:node17:battery-level --> REFRESH
2018-10-01 16:49:27.589 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.589 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Command received zwave:device:9d9a0120:node13:sensor_luminance --> REFRESH
2018-10-01 16:49:27.589 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Command received zwave:device:9d9a0120:node13:battery-level --> REFRESH
2018-10-01 16:49:27.598 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler.
2018-10-01 16:49:27.598 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Command received zwave:device:9d9a0120:node20:sensor_temperature --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Command received zwave:device:9d9a0120:node20:alarm_motion --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Command received zwave:device:9d9a0120:node20:sensor_luminance --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 20: Command received zwave:device:9d9a0120:node20:battery-level --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Controller handler not found. Cannot handle command without ZWave controller.
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:9d9a0120:node19:sensor_binary --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:9d9a0120:node19:sensor_relhumidity --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:9d9a0120:node19:sensor_temperature --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:9d9a0120:node19:sensor_luminance --> REFRESH
2018-10-01 16:49:27.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 19: Command received zwave:device:9d9a0120:node19:battery-level --> REFRESH
2018-10-01 16:49:29.495 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
2018-10-01 16:49:29.496 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-10-01 16:49:29.497 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
2018-10-01 16:49:29.497 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
2018-10-01 16:49:29.497 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 05 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2018-10-01 16:49:29.498 [WARN ] [ssage.ApplicationCommandMessageClass] - NODE 5: Not initialized yet, ignoring message.
2018-10-01 16:49:30.568 [DEBUG] [.ZWaveController$InitializeDelayTask] - Initialising network
2018-10-01 16:49:30.568 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-10-01 16:49:30.568 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2018-10-01 16:49:30.569 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 15 E9
2018-10-01 16:49:30.569 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
2018-10-01 16:49:30.569 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 15 E9
2018-10-01 16:49:30.569 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
2018-10-01 16:49:30.570 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
2018-10-01 16:49:30.571 [DEBUG] [rialmessage.GetSucNodeIdMessageClass] - Get SUC NodeID
2018-10-01 16:49:30.571 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
2018-10-01 16:49:30.572 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
2018-10-01 16:49:30.572 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-10-01 16:49:30.573 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
2018-10-01 16:49:30.573 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 01 15 5A 2D 57 61 76 65 20 33 2E 39 35 00 01 99
2018-10-01 16:49:30.573 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=GetVersion[0x15], type=Response[0x01], priority=High, dest=255, callback=0, payload=5A 2D 57 61 76 65 20 33 2E 39 35 00 01
2018-10-01 16:49:30.573 [DEBUG] [serialmessage.GetVersionMessageClass] - Got MessageGetVersion response. Version = Z-Wave 3.95, Library Type = 0x01
2018-10-01 16:49:30.574 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=GetVersion[0x15], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2018-10-01 16:49:30.574 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=GetVersion[0x15], type=Response[0x01], priority=High, dest=255, callback=0, payload=5A 2D 57 61 76 65 20 33 2E 39 35 00 01
2018-10-01 16:49:30.574 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=GetVersion, callback id=0, expected=GetVersion, cancelled=false transaction complete!
2018-10-01 16:49:30.574 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-10-01 16:49:30.574 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 4ms/4ms.
2018-10-01 16:49:30.575 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
2018-10-01 16:49:30.575 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 20 DC
2018-10-01 16:49:30.575 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 20 DC
2018-10-01 16:49:30.577 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 01 20 F9 98 D7 26 01 47
2018-10-01 16:49:30.578 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-10-01 16:49:30.578 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 01 20 F9 98 D7 26 01 47
2018-10-01 16:49:30.578 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 08 01 20 F9 98 D7 26 01 47
2018-10-01 16:49:30.578 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=MemoryGetId[0x20], type=Response[0x01], priority=High, dest=255, callback=0, payload=F9 98 D7 26 01
2018-10-01 16:49:30.578 [DEBUG] [erialmessage.MemoryGetIdMessageClass] - Got MessageMemoryGetId response. Home id = 0xF998D726, Controller Node id = 1
2018-10-01 16:49:30.579 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=MemoryGetId[0x20], type=Request[0x00], priority=High, dest=255, callback=0, payload=
2018-10-01 16:49:30.579 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=MemoryGetId[0x20], type=Response[0x01], priority=High, dest=255, callback=0, payload=F9 98 D7 26 01
2018-10-01 16:49:30.579 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=MemoryGetId, callback id=0, expected=MemoryGetId, cancelled=false transaction complete!
2018-10-01 16:49:30.579 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2018-10-01 16:49:30.579 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 4ms/4ms.
2018-10-01 16:49:30.580 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
2018-10-01 16:49:30.580 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 07 FB
2018-10-01 16:49:30.580 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 07 FB
2018-10-01 16:49:30.584 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB
2018-10-01 16:49:30.584 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-10-01 16:49:30.584 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB
2018-10-01 16:49:30.585 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 2B 01 07 01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00 FB
2018-10-01 16:49:30.585 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SerialApiGetCapabilities[0x07], type=Response[0x01], priority=High, dest=255, callback=0, payload=01 00 00 86 00 01 00 5A FE 81 FF 88 4F 1F 00 00 FB 9F 7D A0 67 00 00 80 00 80 86 00 00 00 E8 73 00 00 0E 00 00 60 00 00
2018-10-01 16:49:30.585 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - API Version = 1.0
2018-10-01 16:49:30.585 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Manufacture ID = 0x86
2018-10-01 16:49:30.585 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Device Type = 0x1
2018-10-01 16:49:30.585 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Device ID = 0x5a
2018-10-01 16:49:30.585 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SerialApiGetInitData
2018-10-01 16:49:30.585 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SerialApiApplicationNodeInfo
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ApplicationCommandHandler
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: GetControllerCapabilities
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SerialApiSetTimeouts
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SerialApiGetCapabilities
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SerialApiSoftReset
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x09
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RfReceiveMode
2018-10-01 16:49:30.586 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SetSleepMode
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SendNodeInfo
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SendData
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SendDataMulti
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: GetVersion
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SendDataAbort
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RfPowerLevelSet
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SendDataMeta
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: GetRandom
2018-10-01 16:49:30.587 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: MemoryGetId
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: MemoryGetByte
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: MemoryPutByte
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ReadMemory
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: WriteMemory
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x27
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x29
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x2a
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x2b
2018-10-01 16:49:30.588 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x2c
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x2d
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: IdentifyNode
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SetDefault
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ReplicationCommandComplete
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ReplicationSendData
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: AssignReturnRoute
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: DeleteReturnRoute
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RequestNodeNeighborUpdate
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ApplicationUpdate
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: AddNodeToNetwork
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RemoveNodeFromNetwork
2018-10-01 16:49:30.589 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: CreateNewPrimary
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ControllerChange
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SetLearnMode
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: AssignSucReturnRoute
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RequestNetworkUpdate
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SetSucNodeID
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: DeleteSUCReturnRoute
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: GetSucNodeId
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: SendSucId
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ExploreRequestInclusion
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RequestNodeInfo
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: RemoveFailedNodeID
2018-10-01 16:49:30.590 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: IsFailedNodeID
2018-10-01 16:49:30.591 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: ReplaceFailedNode
2018-10-01 16:49:30.591 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x66
2018-10-01 16:49:30.591 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x67
2018-10-01 16:49:30.591 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: GetRoutingInfo
2018-10-01 16:49:30.591 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: LockRoute
2018-10-01 16:49:30.591 [DEBUG] [SerialApiGetCapabilitiesMessageClass] - Supports: Unknown Class 0x92
