Added this device (ZWA009) which is a battery operated temperature and humidity sensor to my z-wave network. It seems to have been initialized properly, as the thing contains the 4 information types populated.
However, the device remains unknown.
I reviewed the list of supported devices listed here, but the ZWA009 is not listed. However, the list of supported devices here shows it listed. I did notice it was added 12/30/2020, so I assume it just hasn’t made it over to the list my network is reading (is it in the binding itself?).
If my assumption is correct, how do I update my binding’s database? Or is there a manual step required by someone to update the binding’s database.
Thanks Bruce. When would it be available in the OH2 binding install that’s found in the PaperUI? I likely will install the snapshot version, but wondering about other options
Installed the snapshot version. OH updated the sensor immediately. I did not delete and rediscover the things. Does the fact that it picked up the details without deleting indicate maybe it doesn’t need to be deleted and rediscovered? Or should I do that anyway (as the documentation explicitly states)?
It likely worked because the device was truly unknown. For firmware differences and other cases then deleting would be needed. I think you are ok though.
Commenting in a thread is not a substitute for reading it. If you followed the database link you would know you need a snapshot version of the binding.
