I have a binding running that needs manually installing the openhab-transport-serial via the command:
feature:install openhab-transport-serial.
However after clearing the cache and tmp folder with a restart of the OpenHAB I loose the installation of the serial driver. So I need to reinstall it via the cmd line.
How can I prevent this from happening like putting the name of bindings into the addons.cfg File.
Is there also a cfg file where I can put those commands in?
First, you should not need to clear the cache other than on software upgrades.
Second, are you using latest OH ? All supported bindings I know of should have their dependencies set right, i.e. would take care of loading the serial module/driver.
No there is no file I know of where to simply put that command in, other than to create some script to auto-execute that on UNIX level.
I have the same issue with the unmerged Sony binding. It constantly needs a feature reinstalled by karaf console after I reboot. low on the to do list. My guess is it should have an extra line in the bindings feature.xml file before it is built to install the feature.
