After linux updates the connection to my influxdb is broken
after some linux updates I received a week ago on openhabian on raspberry the connection to my influxdb is broken. The configuration worked since Januar 21 last year without issues so I assume I has nothing to do with my configuration that has been untouched since then.Todays update to openHAB 3.2.0.M2 did not fix it. Can anybody please give give advice? Thanks a lot in advance.
2021-09-06 17:32:22.080 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.ConnectException: Failed to connect to /192.168.179.150:8086
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
	at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
	at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
	at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.net.ConnectException: Failed to connect to /192.168.179.150:8086
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:265) ~[bundleFile:?]
	at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:183) ~[bundleFile:?]
	at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224) ~[bundleFile:?]
	at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108) ~[bundleFile:?]
	at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88) ~[bundleFile:?]
	at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169) ~[bundleFile:?]
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41) ~[bundleFile:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
	at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
	at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
	at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
	at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
	at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
	at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
	at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
	at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
	... 10 more
Caused by: java.net.ConnectException: Verbindungsaufbau abgelehnt (Connection refused)
	at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:399) ~[?:?]
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:242) ~[?:?]
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:224) ~[?:?]
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
	at java.net.Socket.connect(Socket.java:609) ~[?:?]
	at okhttp3.internal.platform.Platform.connectSocket(Platform.java:130) ~[bundleFile:?]
	at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:263) ~[bundleFile:?]
	... 10 more
Have you updated openhabian itself, too ?
There recently were one or two issues with influxdb. If I remember right at least for one of them there is a workaround integrated into openhabian.
The error message that you show seems to say that influxdb is not running as the port is not served by the influxdb deamon.
Which influxdb version is installed ?
Can you check the journal by using sudo journalctl to see if there are hints about what is going wrong ?
Hi Wolfgang, Thanks for helping.
InfluxDB shell version: 1.8.9
sudo journalctl
Sep 06 18:54:04 openHABianDevice telegraf[532]: 2021-09-06T16:54:04Z W! [outputs.influxdb] Metric buffer overflow; 19 metrics have been dropped
Sep 06 18:54:04 openHABianDevice telegraf[532]: 2021-09-06T16:54:04Z E! [outputs.influxdb] When writing to [http://127.0.0.1:8086]: failed doing req: Post "http://127
Sep 06 18:54:04 openHABianDevice telegraf[532]: 2021-09-06T16:54:04Z E! [agent] Error writing to outputs.influxdb: could not write any address
Could you try to run
sudo apt-get install --reinstall influxdb
as suggested in this post and a later one in the same thread.
Thanks Wolfgang. Done, but unfortunately the same error as before. I have additionally uninstalled telegraf as I did not use it anyway. The service seems to be in a loop (crash restart) as the maximum time of the service running is just a few seconds:
Reddit - The heart of the internet - this post seems to be the issue. I remember there was an update a last week for influxdb. Nevertheless reinstall and
sudo chown -R openhab:openhab /usr/bin/influxdb
doesn’t fix it.
pi@openHABianDevice:~ $ sudo systemctl status influxdb.service
● influxdb.service - InfluxDB is an open-source, distributed, time series database
   Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
   Active: activating (start) since Tue 2021-09-07 09:40:22 CEST; 227ms ago
     Docs: https://docs.influxdata.com/influxdb/
Cntrl PID: 25291 (influxd-systemd)
    Tasks: 11 (limit: 4225)
   CGroup: /system.slice/influxdb.service
           ├─25291 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
           ├─25292 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
           └─25322 sleep 1
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.263820Z lvl=info msg="InfluxDB starting" log_id=0WRo3BTl000 version=1.8.9 bra
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.263903Z lvl=info msg="Go runtime" log_id=0WRo3BTl000 version=go1.13.8 maxproc
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: Merging with configuration at: /etc/influxdb/influxdb.conf
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.365704Z lvl=info msg="Using data dir" log_id=0WRo3BTl000 service=store path=/
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.365832Z lvl=info msg="Compaction settings" log_id=0WRo3BTl000 service=store m
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.365895Z lvl=info msg="Open store (start)" log_id=0WRo3BTl000 service=store tr
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.380663Z lvl=info msg="Opened file" log_id=0WRo3BTl000 engine=tsm1 service=fil
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.381078Z lvl=info msg="Opened file" log_id=0WRo3BTl000 engine=tsm1 service=fil
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.388761Z lvl=info msg="Opened file" log_id=0WRo3BTl000 engine=tsm1 service=fil
Sep 07 09:40:22 openHABianDevice influxd-systemd-start.sh[25291]: ts=2021-09-07T07:40:22.388994Z lvl=info msg="
Not nice but you may try if this helps: influxdb 1.8.9 fails to load via systemctl script on existing DB · Issue #22297 · influxdata/influxdb · GitHub
That fixed it for me - thanks so much :smiley:
