my Raspi was running smoothly over weeks. I have today changed the location of the Raspi and for that I had to shut it down. I stopped the Influx and Openhab service, before I powered the Raspi off. Then started it again. In principle it is working, but not all - actually most functionalities don’t work - mainly because no Rule is triggered. But not only that, also data is not stored properly. What is very strange, that there is some data stored (in influx), but many THINGs data not.
What is strange:
- I don’t see trigger of any of my RULES in the log that includes sensor triggers, but also one CRON job for a speedtest
- I suggest to focus on the speedtest as it shows the problems pretty well. I post a picture of my speediest measurements (once from the openhab browser app and once from Influx). You see that after restart at around 1300 that most data is missing, but not all.
Pic below: Speedtest is not showing results after 1300 - no regular measurements anymore like before (blue line).
Pic below: you can see on the example of the temperature that one sensor is still properly shown, all others stopped being visible in the data recording.
Pic below: Influx is working also after 13:00 - you see this on the example of one temperature sensor.
In the logs I see that no RULES is triggered (the log looks similar as before, ie the yellow and red lines have been there before, meaning that some Netatmo sensors did not work - but that is here not the topic).
What works: I can trigger a manual speedtest via a panel and the results are shown - see pic below. However, the CRON job is not triggered. And secondly the results of even the manual measurements are not shown.
And what is specifically strange - and I suggest to focus on this problem as I assume the others are depending on this also is that after triggering a manual measurements on the page above, and seeing that the measurement results change, ie it works, I cannot look on this data. Meaning that if I press on the first item “Download Bandwidth” which I just measured now in the evening at around 23:00, this (and several I performed in the last 1h) ARE NOT shown in the graph (when I click on the “download Bandwidth” the window with data over time opens):
Is anything working as before? Yes, e.g. data from Raspi like CPU temperature, but also the Corona binding is working without problems. What I of course also checked is whether I can reach the Internet from the Raspi, worked also perfectly.
Does anyone have an idea how I can find out what the problem is after the restart and how I can get the data storing and rules properly working?
BR
Alex
runtimeInfo:
version: 3.2.0
buildString: Release Build
locale: de-AT
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.13
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.52+13-CA
osName: Linux
osVersion: 5.10.63-v7l+
osArchitecture: arm
availableProcessors: 4
freeMemory: 78926592
totalMemory: 246980608
bindings:
- coronastats
- fronius
- hue
- netatmo
- network
- speedtest
- systeminfo
- telegram
- tr064
clientInfo:
device:
ios: false
android: false
androidChrome: false
desktop: true
iphone: false
ipod: false
ipad: false
edge: false
ie: false
firefox: false
macos: true
windows: false
cordova: false
phonegap: false
electron: false
nwjs: false
webView: false
webview: false
standalone: false
os: macos
pixelRatio: 2
prefersColorScheme: light
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: N/A
language: de-DE
languages:
- de-DE
onLine: true
platform: MacIntel
screen:
width: 1512
height: 982
colorDepth: 24
support:
touch: false
pointerEvents: true
observer: true
passiveListener: true
gestures: false
intersectionObserver: true
themeOptions:
dark: light
filled: true
pageTransitionAnimation: default
bars: filled
homeNavbar: default
homeBackground: default
expandableCardAnimation: default
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15
(KHTML, like Gecko) Version/15.1 Safari/605.1.15
timestamp: 2022-02-27T21:47:29.316Z
