Good afternoon, I have a problem with the Bticino mh201. It works well but after a few hours it stops working. Im using pc with 3.4.4 version and raspPi with 4.1.0 and in the too apears the same problem…
Thanks.
2024-01-02 04:30:19.769 [WARN ] [nwebnet4j.communication.BUSConnector] - INVALID FRAME: *#13**#1*0F*02*01*2024##, skipping it
2024-01-02 04:40:19.783 [WARN ] [nwebnet4j.communication.BUSConnector] - INVALID FRAME: *#13**#1*0F*02*01*2024##, skipping it
2024-01-02 04:44:41.136 [WARN ] [io.openhabcloud.internal.CloudClient] - Error during communication: EngineIOException websocket error
2024-01-02 04:44:41.137 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: transport error
2024-01-02 04:44:41.137 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 35...f9, base URL = http://localhost:8080)
2024-01-02 04:44:58.720 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- DISCONNECTED from gateway BUS_192.168.1.5:20000. OWNException: BUS-MON-Rcv got IOException: Connection reset
2024-01-02 04:44:58.725 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- Starting RECONNECT cycle to gateway BUS_192.168.1.5:20000
2024-01-02 04:45:06.229 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- ON CONNECTION ERROR for gateway BUS_192.168.1.5:20000: Could not open BUS-MON connection to 192.168.1.5:20000 (IOException: Connect timed out)
2024-01-02 04:45:16.231 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- ON CONNECTION ERROR for gateway BUS_192.168.1.5:20000: Could not open BUS-MON connection to 192.168.1.5:20000 (IOException: Connect timed out)
2024-01-02 04:45:31.233 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- ON CONNECTION ERROR for gateway BUS_192.168.1.5:20000: Could not open BUS-MON connection to 192.168.1.5:20000 (IOException: Connect timed out)
2024-01-02 04:45:51.274 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- RE-CONNECTED to bridge openwebnet:bus_gateway:MH201_000350ae8dca
2024-01-02 04:45:53.431 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 35...f9, base URL = http://localhost:8080)
2024-01-02 04:46:27.060 [WARN ] [communication.BUSConnector.handshake] - (HS) ... STEP-1: HANDSHAKE FAILED, no ACK recevied, received: null
2024-01-02 04:46:27.061 [WARN ] [nwebnet4j.communication.BUSConnector] - ##BUS-conn## openCommandConnection() returned exception (Could not open BUS-CMD connection to 192.168.1.5:20000 (no ACK received at STEP-1, received: null)) while opening NEW CMD connection
2024-01-02 04:46:28.843 [WARN ] [nwebnet4j.communication.BUSConnector] - (HS) ... handshake not completed but timeout expired, closing BUS-CMD channel
2024-01-02 04:47:52.388 [WARN ] [communication.BUSConnector.handshake] - (HS) ... STEP-1: HANDSHAKE FAILED, no ACK recevied, received: null
2024-01-02 04:47:52.389 [WARN ] [nwebnet4j.communication.BUSConnector] - ##BUS-conn## openCommandConnection() returned exception (Could not open BUS-CMD connection to 192.168.1.5:20000 (no ACK received at STEP-1, received: null)) while opening NEW CMD connection
2024-01-02 04:47:52.390 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- DISCONNECTED from gateway BUS_192.168.1.5:20000. OWNException: BUS-MON-Rcv - exception while checking if gw is still reachable: Cannot create NEW CMD connection to send message *#13**15##
2024-01-02 04:47:52.395 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- Starting RECONNECT cycle to gateway BUS_192.168.1.5:20000
2024-01-02 04:47:54.169 [WARN ] [nwebnet4j.communication.BUSConnector] - (HS) ... handshake not completed but timeout expired, closing BUS-CMD channel
2024-01-02 04:47:55.122 [WARN ] [communication.BUSConnector.handshake] - (HS) ... STEP-1: HANDSHAKE FAILED, no ACK recevied, received: null
2024-01-02 04:47:55.122 [WARN ] [org.openwebnet4j.OpenGateway ] - --Re-connect FAILED. OWNAuthException: Could not open BUS-MON connection to 192.168.1.5:20000 (no ACK received at STEP-1, received: null)
2024-01-02 04:47:55.123 [INFO ] [rnal.handler.OpenWebNetBridgeHandler] - ---- AUTH error from gateway. Stopping re-connect
2024-01-02 04:47:56.901 [WARN ] [nwebnet4j.communication.BUSConnector] - (HS) ... handshake not completed but timeout expired, closing BUS-MON channel
2024-01-02 05:04:35.592 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2024-01-02 05:04:35.593 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 35...f9, base URL = http://localhost:8080)
2024-01-02 05:04:39.363 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 35...f9, base URL = http://localhost:8080)
2024-01-02 05:05:03.726 [INFO ] [al.discovery.BusGatewayUpnpDiscovery] - Created a DiscoveryResult for gateway 'MH201' (UDN=upnp-IPscenarioModule-1_0-000350AE8DCA)
