Hi, after installing a new 2.5.8 docker container with all bindings and configs like before i have an authentification problem " Error to connecting to openHab Clound instance: not authorized" and also alexa commands are not working “hub is not connected…” very strange… any idea ?
Regarding the alexa problem, how are you connected to it? I had a problem after the update because I cold not log onto the amazon via the amazon echo binding. Requesting a new password via the amazon page solved that one. Although you might not use this binding.
i didnt used the binding, i only installed the skill… it was working fine… now i maybe will check with the binding, but i didt want to configure all accessdata in openhab… therefor only the skill…
i was thinking this also… but what is going wrong? is the platform down ? i have replaced the uuid and the secret from the older installation… the accessdata ist ok. maybe i should generate on the platform new data ???
no chance… restarted openhab, deleted before the uuid file and replaced the new uuid in teh myopenhab website …s but still offline… strange … looks like it has something to do with the 2.5.8 version…
shit! how did you moved? do you use the addons file that it installs all bindings etc. automatically? i run the instance on a qnap nas in containerstation… so its not so easy to
thanks… due to the reconnect after hitting save again in the openhab cloud connector… now its working… so it seems that it needs a new uuid… now i will also check how to do with the ssl certs… to have a secure connection from wan…
nice… ok but thanks… working now… now i have to solute, why my doorbird is not working anymore… although in paperui it shows all things aer online… allways a mess to find the problems…
