After Upgrade from 3.3 to 3.4.1 backup file increased
after upgrading from 3.3 to 3.4.1 my backup file increased from 8MB up to 350MB.
(using /usr/share/openhab/runtime/bin/backup)
I found out, that under /var/lib/openhab/ a new folder “kar” was created, which includes all add_ons. Can I delete this folder to reduce my backup files size? Or is that folder needed? I use only the Map Transformation Add On.
Any ideas?
Florian
Any ideas? Or is this the wrong section?
Best
Florian
Section should be fine. Personally I do not have any idea.
I am not yet on 3.4.X. The kar folder that I see is empty in my installation.
Which kar files are located in your folder ? Are these manual copied ( not UI but on command line ) kar files ?
I can’t remeber exactly but there is a setting either in openhabian configuration tool or in MainUI where you can disable the local repository of addons
Do you mean UI: Settings => Add-on Management => Access to remote repository ?
Default is that access to remote repository is enabled.
I can‘t remeber. Need to check when I am back home tomorrow. But the poster could give it a try if the the file disappears.
I didnt copy them myself. It seems during the update the folder was created and has a size of 270MB. I guess all add on repositories are saved, which I dont need.
Exactly. Remote repository is enabled.
at least not by doing an update from 3.3.0 to 3.4.1.
I am on 3.3.0-1; have the folder but the folder is empty.
The linux package openhab-addons is installed thus all central deployed packages are locally available and do not need to be downloaded via remote repository.
Please create a list of these files so that we can get an idea about the exact content.
As far as I know remote only downloads what you really require and would like to install but it does not download all bindings in case you don’t want them.
Attached the list of all files of that folder.
612     ./openhab-addons-3.4.1/joda-time/joda-time/2.8.1
616     ./openhab-addons-3.4.1/joda-time/joda-time
620     ./openhab-addons-3.4.1/joda-time
2460    ./openhab-addons-3.4.1/mysql/mysql-connector-java/8.0.30
2464    ./openhab-addons-3.4.1/mysql/mysql-connector-java
2468    ./openhab-addons-3.4.1/mysql
580     ./openhab-addons-3.4.1/org/mariadb/jdbc/mariadb-java-client/3.0.8
584     ./openhab-addons-3.4.1/org/mariadb/jdbc/mariadb-java-client
588     ./openhab-addons-3.4.1/org/mariadb/jdbc
592     ./openhab-addons-3.4.1/org/mariadb
804     ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-extensions/4.3.3
808     ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-extensions
356     ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-experimental/4.3.3
360     ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-experimental
16      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-sasl-javax/4.3.3
20      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-sasl-javax
28      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-java7/4.3.3
32      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-java7
376     ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-core/4.3.3
380     ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-core
80      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-im/4.3.3
84      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-im
72      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-tcp/4.3.3
76      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-tcp
12      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-resolver-javax/4.3.3
16      ./openhab-addons-3.4.1/org/igniterealtime/smack/smack-resolver-javax
1780    ./openhab-addons-3.4.1/org/igniterealtime/smack
1784    ./openhab-addons-3.4.1/org/igniterealtime
5616    ./openhab-addons-3.4.1/org/bouncycastle/bcprov-jdk15on/1.69
5620    ./openhab-addons-3.4.1/org/bouncycastle/bcprov-jdk15on
5624    ./openhab-addons-3.4.1/org/bouncycastle
276     ./openhab-addons-3.4.1/org/bitbucket/b_c/jose4j/0.7.9
280     ./openhab-addons-3.4.1/org/bitbucket/b_c/jose4j
284     ./openhab-addons-3.4.1/org/bitbucket/b_c
288     ./openhab-addons-3.4.1/org/bitbucket
432     ./openhab-addons-3.4.1/org/jsoup/jsoup/1.15.3
420     ./openhab-addons-3.4.1/org/jsoup/jsoup/1.14.3
856     ./openhab-addons-3.4.1/org/jsoup/jsoup
860     ./openhab-addons-3.4.1/org/jsoup
44      ./openhab-addons-3.4.1/org/openhab/core/bundles/org.openhab.core.io.rest/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/core/bundles/org.openhab.core.io.rest
136     ./openhab-addons-3.4.1/org/openhab/core/bundles/org.openhab.core.semantics/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/core/bundles/org.openhab.core.semantics
192     ./openhab-addons-3.4.1/org/openhab/core/bundles
196     ./openhab-addons-3.4.1/org/openhab/core
924     ./openhab-addons-3.4.1/org/openhab/osgiify/com.amazonaws.aws-java-sdk-core/1.11.490
928     ./openhab-addons-3.4.1/org/openhab/osgiify/com.amazonaws.aws-java-sdk-core
112     ./openhab-addons-3.4.1/org/openhab/osgiify/io.socket.engine.io-client/1.0.1
116     ./openhab-addons-3.4.1/org/openhab/osgiify/io.socket.engine.io-client
168     ./openhab-addons-3.4.1/org/openhab/osgiify/com.amazonaws.aws-java-sdk-polly/1.11.490
172     ./openhab-addons-3.4.1/org/openhab/osgiify/com.amazonaws.aws-java-sdk-polly
68      ./openhab-addons-3.4.1/org/openhab/osgiify/io.socket.socket.io-client/1.0.1
72      ./openhab-addons-3.4.1/org/openhab/osgiify/io.socket.socket.io-client
1292    ./openhab-addons-3.4.1/org/openhab/osgiify
1548    ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.habot/3.4.1
1552    ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.habot
3076    ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.habpanel/3.4.1
3080    ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.habpanel
16      ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.cometvisu.php/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.cometvisu.php
336     ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.cometvisu/3.4.1
340     ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.cometvisu
752     ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.basic/3.4.1
756     ./openhab-addons-3.4.1/org/openhab/ui/bundles/org.openhab.ui.basic
5752    ./openhab-addons-3.4.1/org/openhab/ui/bundles
8       ./openhab-addons-3.4.1/org/openhab/ui/features/org.openhab.ui.features.openhab-ui-external/3.4.1
12      ./openhab-addons-3.4.1/org/openhab/ui/features/org.openhab.ui.features.openhab-ui-external
16      ./openhab-addons-3.4.1/org/openhab/ui/features
5772    ./openhab-addons-3.4.1/org/openhab/ui
180     ./openhab-addons-3.4.1/org/openhab/distro/openhab-addons/3.4.1
184     ./openhab-addons-3.4.1/org/openhab/distro/openhab-addons
188     ./openhab-addons-3.4.1/org/openhab/distro
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.omnikinverter/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.omnikinverter
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.feican/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.feican
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.velbus/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.velbus
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.unifiedremote/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.unifiedremote
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hdanywhere/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hdanywhere
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.guntamatic/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.guntamatic
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.venstarthermostat/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.venstarthermostat
180     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.plugwise/3.4.1
184     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.plugwise
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hydrawise/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hydrawise
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.bluez/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.bluez
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.opengarage/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.opengarage
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.irtrans/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.irtrans
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.sunspec/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.sunspec
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.homewizard/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.homewizard
3156    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.watsonstt/3.4.1
3160    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.watsonstt
160     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.satel/3.4.1
164     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.satel
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yamahamusiccast/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yamahamusiccast
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tradfri/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tradfri
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lgwebos/3.4.1
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lgwebos
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.airthings/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.airthings
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.firmware/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.firmware
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.androiddebugbridge/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.androiddebugbridge
308     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.netatmo/3.4.1
312     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.netatmo
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.russound/3.4.1
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.russound
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonyprojector/3.4.1
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonyprojector
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.xmltv/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.xmltv
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.homeassistant/3.4.1
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.homeassistant
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dlinksmarthome/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dlinksmarthome
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tplinksmarthome/3.4.1
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tplinksmarthome
448     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.velux/3.4.1
452     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.velux
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.volvooncall/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.volvooncall
3136    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ipp/3.4.1
3140    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ipp
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.playstation/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.playstation
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.alarmdecoder/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.alarmdecoder
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zoneminder/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zoneminder
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.prowl/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.prowl
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sagercaster/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sagercaster
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.somneo/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.somneo
512     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.miio/3.4.1
516     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.miio
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.epsonprojector/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.epsonprojector
360     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nibeheatpump/3.4.1
364     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nibeheatpump
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.semsportal/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.semsportal
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mecmeter/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mecmeter
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smaenergymeter/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smaenergymeter
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hyperion/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hyperion
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yioremote/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yioremote
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meteoblue/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meteoblue
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.remoteopenhab/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.remoteopenhab
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.qbus/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.qbus
160     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.heos/3.4.1
164     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.heos
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vitotronic/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vitotronic
960     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.jinja/3.4.1
964     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.jinja
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fronius/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fronius
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.javascript/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.javascript
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nzwateralerts/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nzwateralerts
152     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ecobee/3.4.1
156     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ecobee
10420   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.jellyfin/3.4.1
10424   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.jellyfin
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ojelectronics/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ojelectronics
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.mimictts/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.mimictts
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.radiothermostat/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.radiothermostat
1456    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.amazondashbutton/3.4.1
1460    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.amazondashbutton
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.ember/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.ember
31404   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.marytts/3.4.1
31408   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.marytts
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.openhabcloud/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.openhabcloud
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dominoswiss/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dominoswiss
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kaleidescape/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kaleidescape
360     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enocean/3.4.1
364     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enocean
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enturno/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enturno
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.teleinfo/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.teleinfo
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.groupepsa/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.groupepsa
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.generacmobilelink/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.generacmobilelink
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nanoleaf/3.4.1
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nanoleaf
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.neohub/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.neohub
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wifiled/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wifiled
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.unifi/3.4.1
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.unifi
120     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.caddx/3.4.1
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.caddx
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.phc/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.phc
29792   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.voskstt/3.4.1
29796   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.voskstt
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.haassohnpelletstove/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.haassohnpelletstove
352     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.metrics/3.4.1
356     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.metrics
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.pollytts/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.pollytts
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.luftdateninfo/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.luftdateninfo
1080    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.rfxcom/3.4.1
1084    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.rfxcom
152     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.powermax/3.4.1
156     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.powermax
156     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.network/3.4.1
160     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.network
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.icloud/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.icloud
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.exec/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.exec
172     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.loxone/3.4.1
176     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.loxone
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.buienradar/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.buienradar
204     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.hueemulation/3.4.1
208     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.hueemulation
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fsinternetradio/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fsinternetradio
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onebusaway/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onebusaway
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bosesoundtouch/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bosesoundtouch
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kvv/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kvv
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meater/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meater
160     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.livisismarthome/3.4.1
164     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.livisismarthome
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mcd/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mcd
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.heliosventilation/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.heliosventilation
336     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.twitter/3.4.1
340     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.twitter
1252    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.knx/3.4.1
1256    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.knx
536     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pushbullet/3.4.1
540     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pushbullet
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lghombot/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lghombot
152     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ihc/3.4.1
156     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ihc
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vizio/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vizio
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ntp/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ntp
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.helios/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.coronastats/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.coronastats
524     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hdpowerview/3.4.1
528     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hdpowerview
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meteostick/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meteostick
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.touchwand/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.touchwand
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tibber/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tibber
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.folderwatcher/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.folderwatcher
6568    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.boschshc/3.4.1
6572    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.boschshc
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.souliss/3.4.1
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.souliss
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.irobot/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.irobot
1524    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.minecraft/3.4.1
1528    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.minecraft
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.easee/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.easee
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yeelight/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yeelight
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.haywardomnilogic/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.haywardomnilogic
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wolfsmartset/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wolfsmartset
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sensebox/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sensebox
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.evohome/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.evohome
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openthermgateway/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openthermgateway
384     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pulseaudio/3.4.1
388     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pulseaudio
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.map/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.map
208     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lifx/3.4.1
212     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lifx
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.webexteams/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.webexteams
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.serialbutton/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.serialbutton
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.upb/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.upb
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.millheat/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.millheat
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.rme/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.rme
1380    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.actiontemplatehli/3.4.1
1384    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.actiontemplatehli
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.cc2531/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.cc2531
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.foobot/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.foobot
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vdr/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vdr
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.orbitbhyve/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.orbitbhyve
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.draytonwiser/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.draytonwiser
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bsblan/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bsblan
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mihome/3.4.1
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mihome
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vigicrues/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vigicrues
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mycroft/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mycroft
224     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zway/3.4.1
228     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zway
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.amplipi/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.amplipi
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sleepiq/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sleepiq
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.comfoair/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.comfoair
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.plugwiseha/3.4.1
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.plugwiseha
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mpd/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mpd
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.voicerss/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.voicerss
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.pidcontroller/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.pidcontroller
1396    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.generic/3.4.1
1400    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.generic
5464    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.dynamodb/3.4.1
5468    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.dynamodb
992     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.systeminfo/3.4.1
996     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.systeminfo
576     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.feed/3.4.1
580     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.feed
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.generic/3.4.1
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.generic
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.jeelink/3.4.1
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.jeelink
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.milight/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.milight
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.serial/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.serial
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dwdpollenflug/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dwdpollenflug
29624   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.jrubyscripting/3.4.1
29628   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.jrubyscripting
804     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.rrd4j/3.4.1
808     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.rrd4j
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onkyo/3.4.1
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onkyo
2792    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.porcupineks/3.4.1
2796    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.porcupineks
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.xslt/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.xslt
280     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lametrictime/3.4.1
284     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lametrictime
424     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.mapdb/3.4.1
428     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.mapdb
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gree/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gree
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pioneeravr/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pioneeravr
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sensibo/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sensibo
768     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.chromecast/3.4.1
772     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.chromecast
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.orvibo/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.orvibo
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.adorne/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.adorne
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ambientweather/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ambientweather
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.squeezebox/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.squeezebox
236     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.weathercompany/3.4.1
240     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.weathercompany
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.cbus/3.4.1
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.cbus
736     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.icalendar/3.4.1
740     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.icalendar
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.electroluxair/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.electroluxair
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.valloxmv/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.valloxmv
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.evcc/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.evcc
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.urtsi/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.urtsi
27212   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.googlestt/3.4.1
27216   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.googlestt
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lirc/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lirc
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solarlog/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solarlog
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.blukii/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.blukii
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.silvercrestwifisocket/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.silvercrestwifisocket
4440    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dbquery/3.4.1
4444    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dbquery
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.juicenet/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.juicenet
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lgtvserial/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lgtvserial
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.robonect/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.robonect
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.digiplex/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.digiplex
236     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nest/3.4.1
240     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nest
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.deutschebahn/3.4.1
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.deutschebahn
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.automower/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.automower
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.avmfritz/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.avmfritz
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gce/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gce
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.denonmarantz/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.denonmarantz
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.roku/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.roku
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.intesis/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.intesis
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meteoalerte/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.meteoalerte
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.mactts/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.mactts
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.daikin/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.daikin
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.networkupstools/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.networkupstools
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.luxom/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.luxom
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.energenie/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.energenie
616     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.mongodb/3.4.1
620     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.mongodb
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.surepetcare/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.surepetcare
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ecowatt/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ecowatt
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.broadlinkthermostat/3.4.1
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.broadlinkthermostat
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.linuxinput/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.linuxinput
26828   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.jsscripting/3.4.1
26832   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.jsscripting
352     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.logreader/3.4.1
356     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.logreader
4796    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.influxdb/3.4.1
4800    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.influxdb
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonos/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonos
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.weatherunderground/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.weatherunderground
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smhi/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smhi
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nibeuplink/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nibeuplink
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.senechome/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.senechome
2532    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smartmeter/3.4.1
2536    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smartmeter
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.darksky/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.darksky
148     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yamahareceiver/3.4.1
152     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.yamahareceiver
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nikohomecontrol/3.4.1
144     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nikohomecontrol
280     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.resol/3.4.1
284     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.resol
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ipobserver/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ipobserver
324     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lutron/3.4.1
328     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lutron
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pjlinkdevice/3.4.1
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pjlinkdevice
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fmiweather/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fmiweather
404     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mcp23017/3.4.1
408     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mcp23017
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kostalinverter/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kostalinverter
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enigma2/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enigma2
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.oceanic/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.oceanic
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.coolmasternet/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.coolmasternet
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.espmilighthub/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.espmilighthub
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.homie/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mqtt.homie
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.globalcache/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.globalcache
472     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.amazonechocontrol/3.4.1
476     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.amazonechocontrol
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dwdunwetter/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dwdunwetter
144     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onewire/3.4.1
148     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onewire
328     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee/3.4.1
332     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.imperihome/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.imperihome
560     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.shelly/3.4.1
564     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.shelly
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.danfossairunit/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.danfossairunit
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.daikinmadoka/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.daikinmadoka
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonyaudio/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonyaudio
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.deconz/3.4.1
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.deconz
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.ruuvitag/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.ruuvitag
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ecotouch/3.4.1
120     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ecotouch
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.etherrain/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.etherrain
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fineoffsetweatherstation/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.fineoffsetweatherstation
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.xmppclient/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.xmppclient
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tivo/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tivo
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.stiebeleltron/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.stiebeleltron
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.console/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.console
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bigassfan/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bigassfan
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dali/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dali
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tapocontrol/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tapocontrol
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.boschindego/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.boschindego
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.http/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.http
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hpprinter/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hpprinter
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pentair/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pentair
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solarmax/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solarmax
152     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dsmr/3.4.1
156     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dsmr
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pushsafer/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pushsafer
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.sbc/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.sbc
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smsmodem/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smsmodem
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.revogi/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.revogi
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.neato/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.neato
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solaredge/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solaredge
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enphase/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.enphase
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.airq/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.airq
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.helioseasycontrols/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.helioseasycontrols
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.herzborg/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.herzborg
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wundergroundupdatereceiver/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wundergroundupdatereceiver
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.anel/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.anel
504     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.proteusecometer/3.4.1
508     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.proteusecometer
228     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.rotel/3.4.1
232     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.rotel
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.publictransportswitzerland/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.publictransportswitzerland
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.atlona/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.atlona
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.konnected/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.konnected
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.elerotransmitterstick/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.elerotransmitterstick
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.telegesis/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.telegesis
172     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ipcamera/3.4.1
176     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ipcamera
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smartthings/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.smartthings
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.myq/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.myq
120     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.upnpcontrol/3.4.1
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.upnpcontrol
4172    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.allplay/3.4.1
4176    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.allplay
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.synopanalyzer/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.synopanalyzer
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onewiregpio/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.onewiregpio
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ism8/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ism8
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.oppo/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.oppo
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sinope/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sinope
204     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tado/3.4.1
208     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tado
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sncf/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sncf
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.serial/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.serial
588     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mielecloud/3.4.1
592     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mielecloud
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bticinosmarther/3.4.1
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bticinosmarther
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dscalarm/3.4.1
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dscalarm
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.xpath/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.xpath
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.renault/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.renault
1996    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.doorbird/3.4.1
2000    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.doorbird
360     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.omnilink/3.4.1
364     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.omnilink
388     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.digitalstrom/3.4.1
392     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.digitalstrom
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bondhome/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bondhome
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.googletts/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.googletts
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.spotify/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.spotify
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tplinkrouter/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tplinkrouter
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mercedesme/3.4.1
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mercedesme
316     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tacmi/3.4.1
320     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tacmi
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.novafinedust/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.novafinedust
1604    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.neeo/3.4.1
1608    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.neeo
812     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.telegram/3.4.1
816     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.telegram
1012    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.snmp/3.4.1
1016    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.snmp
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.qolsysiq/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.qolsysiq
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tankerkoenig/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tankerkoenig
7944    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.groovyscripting/3.4.1
7948    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.groovyscripting
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wlanthermo/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wlanthermo
180     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.somfytahoma/3.4.1
184     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.somfytahoma
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.seneye/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.seneye
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.plclogo/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.plclogo
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.magentatv/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.magentatv
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.warmup/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.warmup
204     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lcn/3.4.1
208     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.lcn
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.iammeter/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.iammeter
12      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.console.telegesis/3.4.1
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.console.telegesis
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gpio/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gpio
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.keba/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.keba
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mystrom/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mystrom
120     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.samsungtv/3.4.1
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.samsungtv
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.somfymylink/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.somfymylink
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.harmonyhub/3.4.1
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.harmonyhub
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.am43/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.am43
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.paradoxalarm/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.paradoxalarm
4992    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.rustpotterks/3.4.1
4996    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.rustpotterks
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.roaming/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.roaming
160     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.verisure/3.4.1
164     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.verisure
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hccrubbishcollection/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hccrubbishcollection
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pushover/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pushover
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.awattar/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.awattar
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.flicbutton/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.flicbutton
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.echonetlite/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.echonetlite
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.regoheatpump/3.4.1
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.regoheatpump
188     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.miele/3.4.1
192     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.miele
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.xbee/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.xbee
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.picotts/3.4.1
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.voice.picotts
144     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth/3.4.1
148     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth
3488    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.homekit/3.4.1
3492    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.io.homekit
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ahawastecollection/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ahawastecollection
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.enoceanble/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.enoceanble
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nobohub/3.4.1
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nobohub
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.iaqualink/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.iaqualink
256     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.bin2json/3.4.1
260     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.bin2json
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.siemensrds/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.siemensrds
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gpstracker/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gpstracker
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wled/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wled
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vesync/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vesync
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.km200/3.4.1
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.km200
12      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.console.ember/3.4.1
16      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zigbee.console.ember
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.exec/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.exec
440     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.airvisualnode/3.4.1
444     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.airvisualnode
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.linky/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.linky
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kodi/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.kodi
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.goecharger/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.goecharger
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonnen/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.sonnen
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.freebox/3.4.1
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.freebox
152     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.innogysmarthome/3.4.1
156     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.innogysmarthome
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.neeo/3.4.1
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.neeo
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.monopriceaudio/3.4.1
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.monopriceaudio
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.autelis/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.autelis
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wemo/3.4.1
120     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.wemo
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mail/3.4.1
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mail
348     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.homematic/3.4.1
352     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.homematic
268     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openwebnet/3.4.1
272     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openwebnet
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.windcentrale/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.windcentrale
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.govee/3.4.1
60      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.govee
96      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dmx/3.4.1
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.dmx
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.max/3.4.1
144     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.max
9492    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.jpa/3.4.1
9496    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.jpa
160     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mybmw/3.4.1
164     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mybmw
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.luxtronikheatpump/3.4.1
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.luxtronikheatpump
2188    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tellstick/3.4.1
2192    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tellstick
42388   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.jythonscripting/3.4.1
42392   ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.jythonscripting
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.airquality/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.airquality
52      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.e3dc/3.4.1
56      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.e3dc
444     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.jsonpath/3.4.1
448     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.jsonpath
292     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.insteon/3.4.1
296     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.insteon
2956    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.homeconnect/3.4.1
2960    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.homeconnect
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solarwatt/3.4.1
84      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.solarwatt
64      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pilight/3.4.1
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pilight
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.benqprojector/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.benqprojector
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.melcloud/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.melcloud
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tr064/3.4.1
140     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tr064
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.elroconnects/3.4.1
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.elroconnects
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vektiva/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.vektiva
100     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gardena/3.4.1
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.gardena
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.webthing/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.webthing
132     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openweathermap/3.4.1
136     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openweathermap
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.folding/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.folding
68      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.jablotron/3.4.1
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.jablotron
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.cm11a/3.4.1
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.cm11a
44      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ventaair/3.4.1
48      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ventaair
20      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.regex/3.4.1
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.regex
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nikobus/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nikobus
88      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nuki/3.4.1
92      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nuki
360     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.groheondus/3.4.1
364     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.groheondus
3824    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zwave/3.4.1
3828    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.zwave
196     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tesla/3.4.1
200     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.tesla
124     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.astro/3.4.1
128     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.astro
72      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nuvo/3.4.1
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.nuvo
76      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.opensprinkler/3.4.1
80      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.opensprinkler
248     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.bluegiga/3.4.1
252     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.bluetooth.bluegiga
1000    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ftpupload/3.4.1
1004    ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ftpupload
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openuv/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.openuv
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.studer/3.4.1
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.modbus.studer
192     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hue/3.4.1
196     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.hue
344     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.jdbc/3.4.1
348     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.persistence.jdbc
112     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.leapmotion/3.4.1
116     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.leapmotion
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pixometer/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.pixometer
36      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.pwm/3.4.1
40      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.automation.pwm
24      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.scale/3.4.1
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.transform.scale
104     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mikrotik/3.4.1
108     ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.mikrotik
28      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ekey/3.4.1
32      ./openhab-addons-3.4.1/org/openhab/addons/bundles/org.openhab.binding.ekey
328380  ./openhab-addons-3.4.1/org/openhab/addons/bundles
2984    ./openhab-addons-3.4.1/org/openhab/addons/features/karaf/org.openhab.addons.features.karaf.openhab-addons-external/3.4.1
2988    ./openhab-addons-3.4.1/org/openhab/addons/features/karaf/org.openhab.addons.features.karaf.openhab-addons-external
2992    ./openhab-addons-3.4.1/org/openhab/addons/features/karaf
2996    ./openhab-addons-3.4.1/org/openhab/addons/features
331380  ./openhab-addons-3.4.1/org/openhab/addons
5060    ./openhab-addons-3.4.1/org/openhab/com.caucho.quercus/4.0.45
5064    ./openhab-addons-3.4.1/org/openhab/com.caucho.quercus
343896  ./openhab-addons-3.4.1/org/openhab
772     ./openhab-addons-3.4.1/org/rrd4j/rrd4j/3.8.2
776     ./openhab-addons-3.4.1/org/rrd4j/rrd4j
780     ./openhab-addons-3.4.1/org/rrd4j
1028    ./openhab-addons-3.4.1/org/postgresql/postgresql/42.4.3
1032    ./openhab-addons-3.4.1/org/postgresql/postgresql
1036    ./openhab-addons-3.4.1/org/postgresql
116     ./openhab-addons-3.4.1/org/minidns/minidns-core/0.3.3
120     ./openhab-addons-3.4.1/org/minidns/minidns-core
124     ./openhab-addons-3.4.1/org/minidns
12      ./openhab-addons-3.4.1/org/jxmpp/jxmpp-util-cache/0.6.3
16      ./openhab-addons-3.4.1/org/jxmpp/jxmpp-util-cache
32      ./openhab-addons-3.4.1/org/jxmpp/jxmpp-jid/0.6.3
36      ./openhab-addons-3.4.1/org/jxmpp/jxmpp-jid
36      ./openhab-addons-3.4.1/org/jxmpp/jxmpp-core/0.6.3
40      ./openhab-addons-3.4.1/org/jxmpp/jxmpp-core
96      ./openhab-addons-3.4.1/org/jxmpp
1464    ./openhab-addons-3.4.1/org/hsqldb/hsqldb/2.3.3
1468    ./openhab-addons-3.4.1/org/hsqldb/hsqldb
1472    ./openhab-addons-3.4.1/org/hsqldb
88      ./openhab-addons-3.4.1/org/glassfish/javax.json/1.0.4
92      ./openhab-addons-3.4.1/org/glassfish/javax.json
96      ./openhab-addons-3.4.1/org/glassfish
12468   ./openhab-addons-3.4.1/org/xerial/sqlite-jdbc/3.40.0.0
12472   ./openhab-addons-3.4.1/org/xerial/sqlite-jdbc
12476   ./openhab-addons-3.4.1/org/xerial
72      ./openhab-addons-3.4.1/org/apache/servicemix/specs/org.apache.servicemix.specs.activation-api-1.1/2.9.0
76      ./openhab-addons-3.4.1/org/apache/servicemix/specs/org.apache.servicemix.specs.activation-api-1.1
72      ./openhab-addons-3.4.1/org/apache/servicemix/specs/org.apache.servicemix.specs.activation-api-1.2.1/1.2.1_3
76      ./openhab-addons-3.4.1/org/apache/servicemix/specs/org.apache.servicemix.specs.activation-api-1.2.1
156     ./openhab-addons-3.4.1/org/apache/servicemix/specs
32      ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.jsr305/3.0.2_1
36      ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.jsr305
704     ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.okhttp/3.8.1_1
708     ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.okhttp
160     ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.okio/1.13.0_1
164     ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.okio
132     ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.xpp3/1.1.4c_7
136     ./openhab-addons-3.4.1/org/apache/servicemix/bundles/org.apache.servicemix.bundles.xpp3
1048    ./openhab-addons-3.4.1/org/apache/servicemix/bundles
1208    ./openhab-addons-3.4.1/org/apache/servicemix
1336    ./openhab-addons-3.4.1/org/apache/httpcomponents/httpclient-osgi/4.5.8
1280    ./openhab-addons-3.4.1/org/apache/httpcomponents/httpclient-osgi/4.5.5
2620    ./openhab-addons-3.4.1/org/apache/httpcomponents/httpclient-osgi
680     ./openhab-addons-3.4.1/org/apache/httpcomponents/httpcore-osgi/4.4.9
680     ./openhab-addons-3.4.1/org/apache/httpcomponents/httpcore-osgi/4.4.10
1364    ./openhab-addons-3.4.1/org/apache/httpcomponents/httpcore-osgi
3988    ./openhab-addons-3.4.1/org/apache/httpcomponents
1272    ./openhab-addons-3.4.1/org/apache/opennlp/opennlp-tools/1.9.3
1276    ./openhab-addons-3.4.1/org/apache/opennlp/opennlp-tools
1280    ./openhab-addons-3.4.1/org/apache/opennlp
432     ./openhab-addons-3.4.1/org/apache/commons/commons-lang3/3.4
436     ./openhab-addons-3.4.1/org/apache/commons/commons-lang3
740     ./openhab-addons-3.4.1/org/apache/commons/commons-collections4/4.1
744     ./openhab-addons-3.4.1/org/apache/commons/commons-collections4
1184    ./openhab-addons-3.4.1/org/apache/commons
3164    ./openhab-addons-3.4.1/org/apache/derby/derby/10.14.2.0
3168    ./openhab-addons-3.4.1/org/apache/derby/derby
3172    ./openhab-addons-3.4.1/org/apache/derby
10836   ./openhab-addons-3.4.1/org/apache
56      ./openhab-addons-3.4.1/org/ow2/asm/asm/5.0.3
60      ./openhab-addons-3.4.1/org/ow2/asm/asm
64      ./openhab-addons-3.4.1/org/ow2/asm
68      ./openhab-addons-3.4.1/org/ow2
68      ./openhab-addons-3.4.1/org/json/json/20180813
72      ./openhab-addons-3.4.1/org/json/json
76      ./openhab-addons-3.4.1/org/json
380108  ./openhab-addons-3.4.1/org
40      ./openhab-addons-3.4.1/com/googlecode/soundlibs/mp3spi/1.9.5.4
44      ./openhab-addons-3.4.1/com/googlecode/soundlibs/mp3spi
136     ./openhab-addons-3.4.1/com/googlecode/soundlibs/tritonus-share/0.3.7.4
140     ./openhab-addons-3.4.1/com/googlecode/soundlibs/tritonus-share
144     ./openhab-addons-3.4.1/com/googlecode/soundlibs/jlayer/1.0.1.4
148     ./openhab-addons-3.4.1/com/googlecode/soundlibs/jlayer
336     ./openhab-addons-3.4.1/com/googlecode/soundlibs
340     ./openhab-addons-3.4.1/com/googlecode
684     ./openhab-addons-3.4.1/com/github/jnr/jnr-ffi/2.1.9
688     ./openhab-addons-3.4.1/com/github/jnr/jnr-ffi
240     ./openhab-addons-3.4.1/com/github/jnr/jnr-posix/3.0.47
244     ./openhab-addons-3.4.1/com/github/jnr/jnr-posix
92      ./openhab-addons-3.4.1/com/github/jnr/jnr-a64asm/1.0.0
96      ./openhab-addons-3.4.1/com/github/jnr/jnr-a64asm
860     ./openhab-addons-3.4.1/com/github/jnr/jffi/1.2.18
864     ./openhab-addons-3.4.1/com/github/jnr/jffi
36      ./openhab-addons-3.4.1/com/github/jnr/jnr-enxio/0.19
40      ./openhab-addons-3.4.1/com/github/jnr/jnr-enxio
220     ./openhab-addons-3.4.1/com/github/jnr/jnr-x86asm/1.0.2
224     ./openhab-addons-3.4.1/com/github/jnr/jnr-x86asm
540     ./openhab-addons-3.4.1/com/github/jnr/jnr-constants/0.9.11
544     ./openhab-addons-3.4.1/com/github/jnr/jnr-constants
2704    ./openhab-addons-3.4.1/com/github/jnr
932     ./openhab-addons-3.4.1/com/github/oshi/oshi-core/6.2.2
936     ./openhab-addons-3.4.1/com/github/oshi/oshi-core
940     ./openhab-addons-3.4.1/com/github/oshi
4128    ./openhab-addons-3.4.1/com/github/hypfvieh/bluez-dbus-osgi/0.1.3
4132    ./openhab-addons-3.4.1/com/github/hypfvieh/bluez-dbus-osgi
4136    ./openhab-addons-3.4.1/com/github/hypfvieh
7784    ./openhab-addons-3.4.1/com/github
52      ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.console.ember/1.4.7
56      ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.console.ember
1536    ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee/1.4.7
1540    ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee
120     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.console/1.4.7
124     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.console
12      ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.console.telegesis/1.4.7
16      ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.console.telegesis
568     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.ember/1.4.7
572     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.ember
136     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.telegesis/1.4.7
140     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.telegesis
216     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.cc2531/1.4.7
220     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.cc2531
132     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.xbee/1.4.7
136     ./openhab-addons-3.4.1/com/zsmartsystems/zigbee/com.zsmartsystems.zigbee.dongle.xbee
2808    ./openhab-addons-3.4.1/com/zsmartsystems/zigbee
2812    ./openhab-addons-3.4.1/com/zsmartsystems
648     ./openhab-addons-3.4.1/com/sun/mail/javax.mail/1.6.2
652     ./openhab-addons-3.4.1/com/sun/mail/javax.mail
656     ./openhab-addons-3.4.1/com/sun/mail
660     ./openhab-addons-3.4.1/com/sun
1728    ./openhab-addons-3.4.1/com/h2database/h2/1.4.191
1732    ./openhab-addons-3.4.1/com/h2database/h2
1736    ./openhab-addons-3.4.1/com/h2database
13336   ./openhab-addons-3.4.1/com
24      ./openhab-addons-3.4.1/javax/json/javax.json-api/1.0
28      ./openhab-addons-3.4.1/javax/json/javax.json-api
32      ./openhab-addons-3.4.1/javax/json
36      ./openhab-addons-3.4.1/javax
68      ./openhab-addons-3.4.1/commons-logging/commons-logging/1.2
72      ./openhab-addons-3.4.1/commons-logging/commons-logging
76      ./openhab-addons-3.4.1/commons-logging
580     ./openhab-addons-3.4.1/commons-collections/commons-collections/3.2.2
584     ./openhab-addons-3.4.1/commons-collections/commons-collections
588     ./openhab-addons-3.4.1/commons-collections
1828    ./openhab-addons-3.4.1/net/java/dev/jna/jna/5.12.1
1476    ./openhab-addons-3.4.1/net/java/dev/jna/jna/5.5.0
1456    ./openhab-addons-3.4.1/net/java/dev/jna/jna/4.5.2
4764    ./openhab-addons-3.4.1/net/java/dev/jna/jna
1332    ./openhab-addons-3.4.1/net/java/dev/jna/jna-platform/5.12.1
2280    ./openhab-addons-3.4.1/net/java/dev/jna/jna-platform/4.5.2
3616    ./openhab-addons-3.4.1/net/java/dev/jna/jna-platform
8384    ./openhab-addons-3.4.1/net/java/dev/jna
8388    ./openhab-addons-3.4.1/net/java/dev
8392    ./openhab-addons-3.4.1/net/java
8396    ./openhab-addons-3.4.1/net
405636  ./openhab-addons-3.4.1```
This directory is supposed to be in /var/lib/openhab/tmp/kar
Not sure if this is a bug.
I am on 3.4.0 M6
3.4.0 and 3.4.1 do not seem to be very reliable at the moment.
I have seen lots of problems…
I am on 3.3.0 and I see both directories but only the one under tmp has content:
ls -ld /var/lib/openhab/kar/ /var/lib/openhab/tmp/kar
drwxr-xr-x 2 openhab openhab 4096 Aug  6  2022 /var/lib/openhab/kar/
drwxr-xr-x 4 openhab openhab 4096 Jul  8  2022 /var/lib/openhab/tmp/kar
/var/lib/openhab/kar does not even exist on my system.
But it seems that /var/lib/openhab/kar has been created after your last update
I have the same issue - upgrading from 3.3.0 broke my SD card and when setting up Openhabian from scratch the huge kar file containing all add-ons was laying in the addons folder. I deleted the file, which broke the installation again, so not my recommendation… The question is if this file could somehow be excluded from the backup to keep it small
I have the same content also under /tmp/kar
In both folders are all add ons located.
drwxr-xr-x 3 openhab openhab 4096 Jan 20 09:52 /var/lib/openhab/kar/
drwxr-xr-x 3 openhab openhab 4096 Jan 20 10:01 /var/lib/openhab/tmp/kar
I also thought about editing the backup script. But I dont know exactly how to exclude the kar folder :frowning:
Seems to be a bug to me. I think you should create a ticket for this
I wrote a ticket. Lets see if it is accepted as a bug :wink:
No, this is not a ticket, just a double posting.
Bug reports are entered on github.
Ok thanks for the input.
I dont have a github account. Shall I delete the posting?
