Following my previous post:
Long story short: after upgrading my openhabian from #1502 to #1524 (now #1525), all my Bindings have been canceled, and I’ve been forced to reinstall all of my Bindings.
That solved 99% of my issues, but Zwave is not working properly. All my nodes are in “REQUEST_NIF” if battery device, or “PING” if powered. Nothing is working.
Before revert back to #1502 (again), I would like to know if I can do something. The serial port of my controller is OK, I’ve already cleared the cache.
Any clue?
Please help, I’m out of ideas.
Andrea
edit: restart the Zwave Binding I see:
2019-02-19 11:54:13.727 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-02-19 11:54:21.448 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port '/dev/ttyACM0'
2019-02-19 11:54:21.498 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
2019-02-19 11:54:21.504 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2019-02-19 11:54:21.504 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2019-02-19 11:54:21.540 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.543 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.547 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.560 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.583 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.591 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.596 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.600 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.611 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.768 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.786 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:21.809 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.299 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.367 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.448 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.533 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.552 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.570 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.597 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.626 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.730 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.768 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.839 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.865 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:23.906 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.044 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.121 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.208 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.233 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.285 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.355 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 8: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:24.393 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 2: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:25.031 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 14: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:25.031 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 5: Not initialized (ie node unknown), ignoring message.
2019-02-19 11:54:25.032 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 5: Not initialized (ie node unknown), ignoring message.
