After upgrading to 2.5 system keeps running System started rule every min
hey guys, since upgrading to 2.5 mt System started rule keeps running every minute.
I have cleared the cache and rebooted multiple times with no difference.
the logs
2019-12-23 13:32:02.653 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.Timer 269 2019-12-23T13:32:02.633+13:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1c57eb (conditionalExpression: false)
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [bundleFile:?]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [bundleFile:?]
Caused by: java.lang.NullPointerException: cannot invoke method public abstract boolean org.eclipse.smarthome.model.script.actions.Timer.cancel() on null
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1160) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1150) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1136) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1081) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:861) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:231) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:215) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:239) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:471) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:255) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:201) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	at com.sun.proxy.$Proxy246.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:48) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
2019-12-23 13:32:02.661 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.Timer 271 2019-12-23T13:32:02.638+13:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
	... 1 more
the rule that keeps running
rule "House OFF switch on boot"
        System started
	Auto_Lock_Front_Door_On_Close.sendCommand(ON)
	Lounge_Heating_Cooling_Mode.sendCommand(0)
	Guests_Home.postUpdate(OFF)
	Allow_Guest_Unlock.postUpdate(ON)
	BYPASS_KitchenLightsTimer.sendCommand(OFF)
	BYPASS_Office_LightsTimer.sendCommand(OFF)
	BYPASS_Entry_LightsTimer.sendCommand(OFF)
	BYPASS_Backyard_LightsTimer.sendCommand(OFF)
	Heating_AC_Time_Switch.sendCommand(ON)
	Bedtime_Has_Run.sendCommand(OFF)
	Someones_Home.postUpdate(OFF)
	Front_Door_Lock_Vitrual.sendCommand(ON)
	Amys_Iphone_networkBinding.postUpdate(OFF)
	Ricks_Iphone_networkBinding.postUpdate(OFF)
	Alarm.sendCommand(OFF)
	House_Alarm_Alexa_TTS.sendCommand(OFF)
	House_Alarm_Lights.sendCommand(OFF)
Just because you mention every minute.. If there is an invalid addon in the configuration, it reloads addons every minute, trying to load the invalid one. I think it also triggers any system started rule. A common culprit is restdocs which moved from misc to ui.
Check addons,cfg and addons.config files.
Due to the amount of system started commands you may want to delay loading your rules until OH get fully loaded. You can set this using openhabian-config tool, not sure exactly what number it is but it’s not hard to find.
