Please check out the README file for documentation on how to use the add-on.
Tested on OpenHAB v4.1.1
Changelog
Version 1.1 (2024-05-19)
Support local configuration for firmware version 3.1.1
Version 0.12 (2024-05-17)
The version that went into the official repository
Version 0.11 (2024-05-08)
Discover model
Discover local devices without the need for a bridge (less things)
Version 0.10 (2024-04-29)
Background (automatic) detection of sensors
Improved efficiency after heavy reviews
Version 0.9 (2024-04-27)
Added a “boot” channel which shows number of uploads since last reboot. Strange name, but kept in line with name used in AirGradient as it is often used for troubleshooting.
Version 0.8 (2024-04-27)
Changed to system types for temperature and humidity
Version 0.7 (2024-03-09)
Supports mDNS autodiscovery on beta devices(*)
Support reading and setting LED mode for cloud devices
Support triggering CO2 calibration for cloud devices
(*) If firmware is changed to only publish _airgradient service on port 80
Version 0.6
Bugfixes for local connections
Tested against I-9PSL running beta firmware v3.0.6
Updated documentation
Version 0.5
Supports OpenMetrics format, like the one from the latest v3 Beta firmwares
Version 0.4
Supports Prometheus format for locally access to air gradients
Version 0.3
Supports location discovery
Tested with O-1PST
Tested with I-9PSL
Version 0.2
Tested with many more devices
Support rco2
Support tvoc
Support reading single values (e.g. directly from sensors with firmware with a local web server)
Version 0.1
initial release
supports the most used data from the AirGradient API
Many thanks from my side too for the binding.
I would have some newby question to the AirGradient configuration:
I’m using the local web access (currently also pushing it to the cloud, but plan to stop that at one point in time). Do I get it right, that with the local access I need to create a separate API thing for every AirGradient device I use? So, if I have 3 indoor sensors, I will end up with 3 API things + 3 location things?
I have just installed and configured the AirGradient binding & sensors, with the AirGradient model I-9PSL-DE unit, for the first time. I have some notes/suggestions, and a question.
The display for the particulate sensors reads as (example): “4.8E-9 kg/m³”, instead of the more typical (and AirGradient referenced) “4.8 µg/m³”. The graph ranges from 0 to 1 with the plot at 0 in this case. The changes to fix this are to set the parameters:
Type: “Number”
Dimension: “Density (kg/m³)” (will stay this way, even with unit as below)
Metadata:
Unit: “µg/m³”
State Description Pattern: “%.0f µg/m³” (no decimal) or “%.1f µg/m³” (one decimal)
The TVOC sensor is meant to display as an index, with 100 being baseline. The default display however reads as (example): “0.0000078%”, with a chart that ranges from 0 to 1. The changes to fix this are to set the parameters:
Type: “Number”
Dimension: Empty
Metadata:
Unit: Empty
State Description Pattern: “%.0f” (no decimal) or “%.1f” (one decimal), which results in the display now reading “78”.
There is no channel in teh Thing for NOx, even though it’s on the AirGradient Dashboard and producing a reading. Is this a limitation o is something missing in the binding
